Technical Small block identification help
Discussion in 'The Hokey Ass Message Board' started by Ryan Kelly, Jul 31, 2018.
  1. Ryan Kelly
    Ryan Kelly
    Guys..... I have a weird one (to me anyway) I bought a 65 Impala knowing the engine was not a numbers motor, but it’s driving me crazy trying to confirm what it is.
    Casting is 3849852 which point to 283.
    Block code is FOI2ID which says spec high performance 1966 327.
    What on earth is sitting in the frame rails of my car?!!!! I’ll take any advice I can get.
    Thanks,
    Ryan
  2. Ryan Kelly
    Ryan Kelly
    Pics of what I’m seeing
  3. squirrel
    Did you find the casting date on the back of the block?
    Sent from my Trimline
  4. All SBCs came from vettes
    54vicky, 2FordGuy, weemark and 3 others like this.
  5. Looks like a good set of heads
    May want to pull them and measure the bore
  6. All small blocks are 400’s. It looks like it has double hump heads on it.
    54vicky likes this.
  7. Ryan Kelly
    Ryan Kelly
    Yep
  8. Ryan Kelly
    Ryan Kelly
    Hahahahaha so I hear
  9. Ryan Kelly
    Ryan Kelly
    It does have double humps
    Deuces likes this.
  10. Ryan Kelly
    Ryan Kelly
    Haven’t pulled heads but boroscope does confirm dome tops hiding in there.
    Deuces and anthony myrick like this.
  11. Ryan Kelly
    Ryan Kelly
    Yep
  12. Do the heads have screw in studs?
  13. partsdawg
    partsdawg
    from Minnesota
    You have a rebuildable engine.
    Grind all the numbers off and then tell everyone it's a experimental engine GM let slip out the door.
  14. Its a 283. I can tell by the rib in the picture showing the numbers stamped on the pad. If you can catch your finger in that rib its a 283. one exception the 67 283 had the same small rib as a 327. Those heads likely are not the desirable 300 hp 327 heads. most likely a truck head. pull a valve cover & get casting numbers of f the heads
    Deuces likes this.
  15. However those Bacturin camel hump heads have a lot of space between the humps and the rectangle they set on is longer and narrower than the genuine article. They just don't look correct? Possibly some one altered a set of power pack heads ?
    Hnstray likes this.
  16. Ryan Kelly
    Ryan Kelly
    283 is what I’m thinking too. The block code threw me off
  17. Ryan Kelly
    Ryan Kelly
    Touché good sir
  18. Ryan Kelly
    Ryan Kelly
    Haven’t gone that far yet. Just got a hold of the car and started to identify what is really here
  19. Ryan Kelly
    Ryan Kelly
    I’m still curious as to what this block is. Knowing when I bought it that’s it’s non numbers, I’ll throw vortecs on it and be content. The heads will become shop art.
  20. Fordors
    Fordors
    They look like late ‘186 or ‘492 heads. Those have the camel humps cast almost right at the deck of the head, not on a rectangle. Can’t see it in the photo but does that p***enger side head have a 3/8-16 bolt hole for an accessory mount?
    If ‘186’s I think they could be either 1.94 or 2.02 intakes. If ‘492’s they would be 2.02’s with screw in studs and guide plates. But 2.02 valves interfere with the small bore 283.
    Deuces likes this.
  21. Ryan Kelly
    Ryan Kelly
  22. Fordors
    Fordors
    D1C60D90-BD70-4890-B5D3-9B4AD1284921.jpeg I just checked the “ D” suffix here, it either started life as a 283/170 in a 1960-‘62, or a 283/185 from a ‘58-‘59.
    And your latest photo confirms that they are likely 1.94 valve ‘186’s.
    Deuces likes this.
  23. Deuces
    Deuces
    Huh?????.... :confused:o_O:rolleyes:
  24. Deuces
    Deuces
    Domes are good!!..... :):D
  25. The old school period correct 327 camel hump heads never had any accessory bolt holes in them. I have some in my hoard . both kinds the 194 and 202. On a 283. 602 casting 305 heads work great they are small chamber and set up for unleaded fuel.
  26. DDDenny
    Accessory bolt heads, 1969 and later, I had a set of 2.02's that were the "186" version, but the same castings could also be 1.94's.
    54vicky and Deuces like this.
  27. Deuces
    Deuces
    They look like 186s....
  28. Fordors
    Fordors
    Nobody mentioned they had to be period correct, the question was could we ***ist in identifying what he has.
    Hnstray and egads like this.
  29. Deuces
    Deuces
    Might be poked out to 301/302 cubes....
