Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. Tim_with_a_T
    Tim_with_a_T
    Maybe you could find a red lens that will fit in there off an old boat?
    Doctorterry and patmanta like this.
  2. Gavin Tittle
    Gavin Tittle
    That’s damned brilliant! The type of thinking that keeps these threads interesting
  3. Doctorterry
    Doctorterry
    I love this idea so much. I've been thinking about getting a cab light off of an early truck and using it on a mini bike fender.
  4. patmanta
    patmanta
    from Woburn, MA
    Tim_with_a_T likes this.
  5. rusty rocket
    rusty rocket
    There was a thread about a month or so ago about ww2 era wooden aircraft seats and it got me to thinking. I,m a trim carpenter by trade so lets build a wood bomber seat. This is what I ruffed out, I will paint it O.D. green and I want to find some old galvanized sheet metal to build brackets that bridge the seams in the wood. IMG_3009.JPG IMG_3011.JPG IMG_3014.JPG IMG_3019.JPG IMG_3020.JPG IMG_3022.JPG
    LSJUNIPER, brEad, Okie Pete and 12 others like this.
  6. sodakmini
    sodakmini
    Okie Pete and Doctorterry like this.
  7. Doctorterry
    Doctorterry
  8. rusty rocket
    rusty rocket
    IMG_3024.JPG IMG_3025.JPG IMG_3026.JPG I found an old piece of galvanized gutter this afternoon. Its going to be perfect for the old time gusset look on the bomber seat.
  9. plym_46
    plym_46
    from central NY
    Maybe make up some od green stain or thin out some of that green coating used on interior air craft pieces instead is solid paint. Faded old tent canvas for upholstery. Holes to make it lighter???
  10. rusty rocket
    rusty rocket
    The few pictures I have seen of the originals they looked to be O.D. green I'm throwing in the galvanized because I like the look of it. The light green in aircraft interiors is zinc chromate it was used as a metal sealer/primer since the seat is wood there would have been no reason to zinc it. As far as holes the only ones I will put in will be for the lap belts. I will also have some O.D. green cushion made for it.
  11. rusty rocket
    rusty rocket
    I have half of my gussets built and fit. I scrounged around and found some old panhead screws to attach everything. My daughter came down to the shop to test fit the seat, looks like she has plenty of room my big ole fat *** is a different story though. IMG_3029.jpg IMG_3030.jpg IMG_3028.JPG P.S. had to get the step ladder out so she could get in!:)
    brEad, Okie Pete, brad2v and 12 others like this.
  12. rusty rocket
    rusty rocket
    I havent had much time to work on the car lately but tonight after work I took the seat apart, cut holes for the seat belts did some routing and final sanding. I stained the seat with some english chestnut and after that drys I will stain it with some O.D. green solid hide stain. My thought was if the solid stain wears thru the darker color will look a bit more vintage. IMG_3053.JPG IMG_3054.JPG
    Greenblade, brEad, brad2v and 8 others like this.
  13. AmishMike
    AmishMike
    That rod is an ***ume build - congrads
  14. AmishMike
    AmishMike
    Hay that was “awesome”. Fat fingered or spell check screwed me.... awesome build love it
    Greenblade and Peanut 1959 like this.
  15. Tim
    Tim
    from KCMO
    We cool, just got all caught up. Lots of cool ideas in this one :)
  16. rusty rocket
    rusty rocket
    Thanks, My head is always swimming with all sorts of weird ideas.
    Thanks man.
  17. rusty rocket
    rusty rocket
    Well the seat is pretty much done, O.D.ish green colored solid stain applied. IMG_3057.JPG IMG_3058.JPG
    brEad, Okie Pete, brad2v and 7 others like this.
  18. rusty rocket
    rusty rocket
    I got my dropped floor tacked together and fit. Still need to add a tunnel in the back for drive shaft clearance. IMG_3062.JPG IMG_3063.JPG IMG_3064.JPG
    brEad, Okie Pete, brad2v and 4 others like this.
  19. AmishMike
    AmishMike
    Did u tack the floor to frame? How attach? Guess a stupid question but do not see how u did it.
  20. Tim
    Tim
    from KCMO
    I believe it’s attached to the sectioned torque tubes that are welded to the angle iron. I’d ***ume the angle iron is bolted to the frame but I’m curious as well
  21. rusty rocket
    rusty rocket
    I built a frame that will be drilled and tapped to the bottom of the frame rail. I,m attaching the body in the same fashion.
    Stogy likes this.
  22. rusty rocket
    rusty rocket
    Ding ding ding you are correct Tim! This last January at the Denver swap meet I bought several hundred slot head stainless 10-32 machine screws. The body, grill shell and dropped floor will be attached with these fastners.
    Tim likes this.
  23. rusty rocket
    rusty rocket
    I built a recess in my floorpan for driveshaft clearance and notched the front so the transmission can drop thru. IMG_3065.jpg IMG_3066.jpg IMG_3067.JPG
    brEad, Okie Pete, brad2v and 2 others like this.
  24. rusty rocket
    rusty rocket
  25. the oil soup
    the oil soup
    from Tucson,AZ
    Here is a source for all sorts of lenses. http://taillightking.com
  26. Billy_Bottle_Caps
    Billy_Bottle_Caps
    great build, you are very creative and talented.
  27. verde742
    verde742
    Has your Dad moved from Mesa yet?
  28. rusty rocket
    rusty rocket
    Hmm dont know what you are talking about my pops live 6 miles from me in the good ol black hills of South Dakota.
  29. verde742
    verde742
    Ooooooooooo k I thought yer POP was Dutch, who lives in Mesa Az.
    NEEEEEVVVVERRRRRRMMMMIND
