Technical ***August 2018 Banger Meet - Banger Driving Weather***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 31, 2018.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    September 9th, El Mirage
    September 14-16, Hot Rod Hill Climb
    Central City, Colorado
    September 28-30 ECTR-LSR THE ARKANSAS 1-MILE CHALLENGE
    The event is held at the Arkansas Aeroplex (The Blytheville-Gosnell Regional Airport) at 4701 Memorial Drive in Blytheville, Arkansas.
    October 2nd -5th, SCTA/BNI Bonneville Race World Finals
    October 21st, El Mirage
    November 10th - 11th, El Mirage
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $31.00 for color, $24.00 for B/W (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    deathrowdave likes this.
  2. Binger
    Binger
    from wyoming
    Checking in for the month! I will keep everyone posted with details about my new engine install.
    knowskool, brjnelson, Jet96 and 2 others like this.
  3. winduptoy
    winduptoy
    Checking in.....working on the Cragar OHV/T-5 install....slowly. It is cooling season and it is hot.
    barrnone50 likes this.
  4. yep, checking in
    loading trailer..........
    brjnelson and Crazydaddyo like this.
  5. noboD
    noboD
    Binger, we need pictures.
    knowskool likes this.
  6. denis4x4
    denis4x4
    from Colorado
    Just dropped off the Zipper engine to be refreshed along with two cores at Bert’s. Deadline is May first next year so I can get it in and be ready for the Speedster Reunion at Speedway. Will be driving the rare ‘29 Supercab a lot.
  7. Crazydaddyo
    Crazydaddyo
    No word except "it is getting closer" Patience is all I've got.
    Herb Kephart likes this.
  8. I'm here. Still gathering the parts to do my juice brake conversion.
    ROCKER77 likes this.
  9. barrnone50
    barrnone50
    from texas
    Yes John please post on your progress!! Thanks George
  10. RussTee
    RussTee
    Im here from the sth seas
  11. Crazydaddyo
    Crazydaddyo
    Good luck. May the Gods of Speed favor you.
  12. Thanks Dan, that place is humbling.
    Crazydaddyo likes this.
  13. fourd
    fourd
    from Colorado
    Checking in. I found some inspirational pictures from GNRS to share. I saw four 4 Ports in one day. Art's 32's are fantastic!
    chriseakin, brjnelson, GuyW and 8 others like this.
  14. surf10
    surf10
    Hi guys checking in from New Zealand, here is a pic of my junk, manage to get it running from a pile of parts in time for my wedding last March. Now we’re getting ready for our honey moon to speedweek!
    It’s a cut down phaeton plan is to add the sheet metal for the rear tub now and remove the tray to make the car a bit more social.
    Question for you more experienced banger owners. Fitting new head gaskets,mine didn’t seem to seal properly what’s everyone’s preferred method.
    I replaced the gasket with a composite type torqued to 45ft/lb put it through a heat cycle then torqued to 50ft/lb. had the car sitting for a month then check oil and noticed water in it[emoji24]
    Should be a simple process I know, but it’s tripped me up.
    Cheers Craig
  15. I finally finished the work on the race car. After Sonoma's race in June the car had no brakes and the engine was rough, coughing and back firing. This last month (mostly waiting for parts) my buddy Max rewired the whole ch***is; while I made modifications to the front suspension (AGAIN!), overhauled the brakes and worked on the engine. All the basic engine needed was an oil change. The ignition and the carburetors got most of the attention. We'll be ready to go at Monterey the end of the month!
  16. winduptoy
    winduptoy
    Stock head? Block, A or B?
  17. Binger
    Binger
    from wyoming
    I will post some along the way. not much to see yet. Just ****oning up the engine and getting it painted. the swap starts tomorrow by pulling the old one out.
  18. surf10
    surf10
    Hi sorry, yes stock model A engine.
    First aim is to get everything working in stock form then modify from there so I have a bench mark.
    Cheers
    Old Dawg likes this.
  19. railcarmover
    railcarmover
    Helped a friend of mine with his Miller Serr head with Serr header,he had an issue with the petronix (timing ****ter,first time I saw that,they usually just fail) and squaring away the fuel lines with a solenoid and remounting the fuel pump.We fired it open header and it woke the dead.Its in a stock 29 fordor with etched wind wings,AC and a luggage rack,so he decided to switch out to a cast iron header and an Aries exhaust( his wife was behind the change as well)..So I asked what he was going to do with the header and he said "You want it?" in my zeal I couldn't take it quick enough the header is dead ***y and I'm building a banger, so loud is fine with me. I go to hang it last night along with my 94...and low and behold the ****er don' t fit a stock model A. Now I have to change my avatar. On the bright side the 94 runs nice.. 20180801_193627.jpg 20180801_174111.jpg
    JT1930 and Jet96 like this.
  20. winduptoy
    winduptoy
    Re torque to 55 ft-lb, following tightening sequence band see what happens. You likely will have to re-torque several times. On side note....might not be head gasket
    Sent from my XT1254 using The H.A.M.B. mobile app
  21. IMG_2186.JPG IMG_2187.JPG Big Brother's Banger, 1964. It "bit" me at 12years of age (15 in photo).
    But I'm here today to give thanks...Crazydaddyo, 97, V4F, Binger, Charlie...you successfully penetrated my thick scull and solved my problem. Obviously I'm in the right Joint! You led me to turn my HOT (144*) upside- down coil, right-side up...118* now, which ain't so hot which is cool!
    Will be pestering you from time to time. Thx in advance!
    Art
    Dannerr, Jet96 and Binger like this.
  22. Kiwi 4d
    Kiwi 4d
    Any pics of the cragar conversion ?
    Likewise a stock A header wont fit an OHV as they are too short.Nothing a little welding wont fix though.
  23. denis4x4
    denis4x4
    from Colorado
    This is an original 1935 CRAGAR head. The Headers came from Bert’s in Denver
    JT1930, Dannerr, Jet96 and 3 others like this.
  24. RussTee
    RussTee
    Also here in NZ the steering box is on the other side and in the way headers are the best solution
  25. Binger
    Binger
    from wyoming
    [​IMG][​IMG]
    My Model A exploded! About ready to put the new engine in!
    woodz, winduptoy, JT1930 and 8 others like this.
  26. Dustyp489
    Dustyp489
    Just checking in hope everybody has a good August we've had a lot of rain here for the month of July and looking forward to some days withe no rain.
    Went to the show in Hanover Pennsylvania at Maaco did not see any bangers there
    Skip
  27. railcarmover
    railcarmover
    Nah,gonna keep the brothers stuff on the down low,he's a standup guy Ill let him choose to post up.Full pressure counter balanced B engine,all the goodies,sitting in a 29 fordor,bone stock...kinda...A/C, stereo full insulation,a touring guys touring car..As for the header is too pretty to cut up,I think Ill sell it cheap and use the dough to get a reds for my A...cest la vie..you know,I looked at that OHV engine for three days working on it and didnt realize it was taller..
    chriseakin and Kiwi 4d like this.
  28. fine29
    fine29
    from Des Moines
    Scored a 32 front axle today as well as the column. Do any of you know, would the 32 box be much of an upgrade over the A box? Mine has a lot of up and down movement on the pitman arm shaft.
    chriseakin and Dannerr like this.
  29. Anyone ever had this happen to them?
    Keep ‘em kruzin!
    Dannerr
  30. JT1930
    JT1930
    It’s August already.
    Any go fast goodies for sale. Head, Header or intake ????
    Shutter Speed likes this.
