Hot Rods 1950 Ford Club Coupe - my new project
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 1, 2018.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I prematurely announced I pulled the trigger last week and had second thoughts after I discovered rust that was my own fault for not doing a thorough in depth inspection.
    I decided I needed to talk to my friend and be a man of my word, it's fixable and something that can be fixed in the future.
    Rene' & I came to a agreement today and I have the ***le in my hand.
    First things first,I'm going to get the car up in the air & remove the gas tank and have it vatted,then blow out the metal gas lines and replace the rubber hose & filter.
    Next I will rebuild the carburetor or replace it depending on what I find and tune it up replacing what it needs and hopefully being it back to life.
    I will also check the brakes and service where needed,after I get the car running I need to get some wheels & tires, and adjust the doors,it came with some new latches.
    I plan on cleaning,doing some minor repairs & driving the coupe until this winter and then start the rust repair. HRP
  2. Ford52PU
    Ford52PU
    from PA
    Really like those Shoeboxes. Good luck with it.
    HOTRODPRIMER and 3W JOHN like this.
  3. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    I love it when a plan comes together. Glad you got a deal worked out. Now just grab a 1958 R&C magazine, flip the pages to the first shoebox Ford for inspiration and go to town on it. WWW's, 56 Olds Starfire flippers, skirts , lake pipes you name it. I have an old J.C. Whitney catalog if you want to look it over to really jazz it up;) On second thought, don't listen to my silly **** and do what turns you on and drive the hell out of it and have a ball!
  4. HOTRODPRIMER
    HOTRODPRIMER
    I'm not keeping the Hildebrand wheels so I need to find some steelies.
    What size wheels were originally on these cars? HRP
  5. Slopok
    Slopok
    Some came with 6.70 x 15's and others with 6.00 x 16's. Whatever size is currently on the front of your car now appears to be too small, even if you are goin' for the big & little look!
  6. flatford39
    flatford39
    Really happy you straightened out your mess. That's a pretty nice car and we all know you will do it proud. Congrats. The really hard work has been done in my mind. You just need to clean it up.
    hotrodharry2 and HOTRODPRIMER like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir,the front wheels are 14" and the rear are 15",thank you for the information. HRP
    ladyhrp, 3340 and 3W JOHN like this.
  8. wicarnut
    wicarnut
    Congrats Again ! Kool !
  9. 3W JOHN
    3W JOHN
    I'm looking forward to seeing you do your magic.
    HOTRODPRIMER likes this.
  10. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Glad it all worked out. Have fun and maybe you can get it road worthy and be able to take Rene' for a ride. :) Larry
  11. HOTRODPRIMER
    HOTRODPRIMER
    Thank you, picking Rene' up and taking him for lunch is something I am really looking forward to. HRP
    Mtn Goat, ladyhrp, 3W JOHN and 2 others like this.
  12. 41rodderz
    41rodderz
    from Oregon
    Neat car. I like the club coupes . Looking forward to your tech on what you decide to do. Just like" 5 alive" i need input. I am always ready to learn from one with experience. :cool:
  13. BamaMav
    BamaMav
    from Berry, AL
    Cool beans! Glad y’all got it worked out. The one in the other thread with the Torque Thrusts on it looked pretty good to me. If you’re planning on steel wheels, at least think about some chrome reverse. Have fun with it!
  14. HOTRODPRIMER
    HOTRODPRIMER
    I am a complete novice when it comes to shoebox Fords and have a lot to learn but
    I'm really looking forward to getting started on the repairs and making it derivable again. HRP
  15. With steel wheels, a rake, big 'n littles and spun aluminum moon discs would be perfect!
  16. HOTRODPRIMER
    HOTRODPRIMER
    Brenda just happened to be outside her flower shop when we drove by on the way home, HRP
  17. warhorseracing
    warhorseracing
    from cameron wv
    OK then;), it has happened:D, best of luck with this new car. As I stated before HRP check out the Shoe Box Hambers Social Forums. A lot of technical information there especially the doors and proper alignment and re-building your hinges if need be rather than buying new ones at $200.
  18. Hombre
    Hombre
    I know that "slopok" already answered your wheel question, but I just went out and looked at my 50 Ford Coupe and it does in fact have 6.70x15's all the way around. I am pretty sure that the wheels and probably the tires on mine are original.
    Glad you finally got this car, it's going to be a blast just you wait and see.
  19. The37Kid
    The37Kid
    Glad you reloaded and pulled the trigger. Not many "Curb finds" out there. Bob
  20. 9927B997-A274-4562-8667-93815E46045D.jpeg For the wheels, Summit has stock-looking ones with the correct bolt pattern. The offset is 3” instead of the original 3 1/2” but it works for me, because the Maverick 8” rear in mine is a tad narrower than original. I think they look good. If you go with semi-cheap radials, 205/75R-15 is close to stock. I used 215/75R-15 Hankooks on mine and I’m happy with the ride, and the look isn’t half bad for radials. Easy on the bank account too.
  21. Oh, and my other wheels are red. I painted these Wimbleton White just because.
  22. HOTRODPRIMER
    HOTRODPRIMER
    I have joined the social forum and have already received helpful information.
    I failed to mention that when Rene' bought the car it had the multi pattern chrome reverse wheels,they were at another friends house and I picked them up last night,I was told the rears have a little more offset to the inner body since Gary installed the new rear axle.
    I'll have to get it up on a rack and do some measuring and see if a small spacer will help,if not I will look for some steelies,paint color is yet to be decided for the wheels if I go that way.
    I also have a set of Cadillac hub caps I have had for more than 30 years that might end up on the coupe. HRP
    ladyhrp, 3W JOHN, catdad49 and 11 others like this.
  23. Old-Soul
    Old-Soul
    Love me a shoebox coupe.
    My '49 tudor had 15" stock wheels. Seen below with firestones and an al***ude adjustment. Selling that car may go down as one of the dumbest things I have ever done (so far).
  24. tubman
    tubman
    See? You bought those Caddy caps for a reason!
  25. dwollam
    dwollam
    Mine has stock wheels and 205/75/15 tires. Aerostar front springs, 1 1/2" lowering blocks in the rear on nicely sagging rear springs.
    Dave
  26. BrerHair
    BrerHair
    Glad it finally worked out Danny. I know Rene must be relieved. Guess you're a Ford man all the way!
  27. verde742
    verde742
    might have to get different wheels for those Cad hubcaps,,, ( think white spoke trailer wheels )
    CHEAP, & 5 x 4 1/2 bolt pattern, center is "sunk in"
    Jalopy Joker likes this.
  28. loveoftiki
    loveoftiki
    from Livonia,Mi
    You can never......ever go wrong with chrome reverse wheels...just sayin
  29. jim snow
    jim snow
    I'm glad it worked out for both you guys. Get after it so you can take Rene for his ride to lunch. Snowman
    lo c dan and flatford39 like this.
