Technical new heat shrink solder and shrink tube terminals
Discussion in 'The Hokey Ass Message Board' started by olcurmdgeon, Aug 3, 2018.
  1. olcurmdgeon
    olcurmdgeon
    I did a search, couldn't find reference to these terminals. Has anyone used them? Put the two wires in, apply heat gun and solder the two wires together as well as shrink tube both ends. For somebody who is not skilled at wiring and connectors, this looks like a good idea IF they work.
    https://chicdelta.com/products/waterproof-solder-wire-connectors
  2. H380
    H380
    from Louisiana
    3M™ Scotchlok™ **** Connector, Heat Shrink Seamless
    is what you want
  3. olcurmdgeon
    olcurmdgeon
    H380, thanks for the info, do you use the dry or the sealant filled?
  4. hinklejd
    hinklejd
    from Fort Worth
    Been using those in aviation for years. Far easier, faster, and more reliable than hand soldering, and not hard and subject to over- or under-crimping. Excellent connection, and as vibration proof as you're going to find in a wire connection.
    Kinda pricey. Can't have everything.
  5. partssaloon
    partssaloon
    I've been selling them for about 20 years now. They work great. Lengthened the wires going between engine and the computer (like 30 wires) and never had a issue or failure. They are also available in all the wire terminal ring sizes.
    CudaChick1968 and loudbang like this.
  6. cajunfirehawk
    cajunfirehawk
    from Gulf Coast
    FWIW, I think they have these in Chinese knock offs too on amazon, like everything spend more and buy quality items made in the USA.
  7. 41woodie
    41woodie
    I purchased a slightly different style from Del City, I've had to replace several due to oxidation and crumbling of the melted solder. I just looked at Del City's online products and notice that several of this series of connectors are labeled obsolete.
    Also I looked at your website link "Chicdelta" the other items in their catalog includes detoxing m***age cream and a rotating curling iron brush, as well as a ton of other similarly useful items. If you want to try this style connector out you might want to find a domestic source.
  8. tubman
    tubman
    I would think you must have to have a hell of a good heat gun to melt the solder with these. I'm sure the ole' ladies hair dryer ain't gonna do it. Perhaps that have developed a new type of low temperature solder that might come with it's own problems. Just thinking out loud.
    54vicky likes this.
  9. 41woodie
    41woodie
    It is low temp solder my heat gun handled it ok but you have to be careful because it goes from solid to melting through the shrink tube in a hurry.
  10. settoon3
    settoon3
    I used a small butane torch, worked fine once you got the hang of melting the solder and not melting the coating
  11. GeezersP15
    GeezersP15
    from N.E. PA
    Yep....first saw and used these nearly 50 years ago when I worked at Kodak Apparatus Division in Rochester, NY. They work great, and are pretty easy to use.
  12. Been using them for years. Difficult to impossible to find locally.
    Ben
  13. tubman
    tubman
    Do you have a source? Online, mailorder, etc.?
  14. dirty old man
    dirty old man
  15. bobss396
    bobss396
  16. squirrel
    I wonder how the flux works on this? Apparently, it does...
  17. 41rodderz
    41rodderz
    from Oregon
    I questioned the stability and reliability of the solder. I would want to do it right the first time. Pain to have redo a complete wiring job because if one or few connections failed , I wouldn't trust the rest.
  18. 41rodderz
    41rodderz
    from Oregon
    Plus I want to drive not be worried about it.
  19. When the first one of mine fails, I will let you know. Been holding for over 10 years and half a million miles.
    Ben
    Hnstray, Blue One and settoon3 like this.
  20. pat59
    pat59
    been/seen alot of advertising of these lately. didn't notice weather it was the American made ones or the imports.
    seb fontana likes this.
  21. olcurmdgeon
    olcurmdgeon
    checked out link from bobss396, and they emailed me that all their heat shrink terminals are US made and the shrink tube is 3M. At my age (75) I want to make a good connection, not find myself in the dark on the side of the road with a flashlight in my teeth fixing a connection that came loose.
    Hnstray, scotty t and CudaChick1968 like this.
  22. Sporty45
    Sporty45
    Interesting info, I'm in! :cool:
  23. Mike Colemire
    Mike Colemire
    All kinds of tools come up on FB, recently these have been coming up, I'll check the brand next time I see them. I'd want the 3M and USA made.
  24. pat59
    pat59
    I don't trust solder that melts with a heat gun. I mean realy how strong can it be?
  25. Crimps for me.... A properly done crimp is equal to or better than a solder job any day....
    Muttley likes this.
  26. gimpyshotrods
    gimpyshotrods
    Hundreds of millions of cars have hundreds of crimps.
    If they were a problem, this wouldn't be the case.
    This is a solution, looking for a problem.
    Muttley likes this.
  27. ejgloss
    ejgloss
  28. bobss396
    bobss396
    I started using them 25+ years ago, we would get them at work and some had a shelf-life on them, so they would give them away to us for home use. Like any other electrical connection, you need some strain relief so the connection is not stresses. Under the hood they hold up well and I sleeve them with black shrink tubing.
  29. bobss396
    bobss396
    I love crimps too. I've invested in a variety of crimp tools and wire strippers. So I'll use either depending on where on the car it is. .. and what terminals/splices I have on hand. Harbor Fright makes a very nice set of shrink splices.
  30. H380
    H380
    from Louisiana
    We use the dry and use tinned copper marine wire. I also use Thomas & Betts Kopr-Shield on regular non shrink terminals before you crimp. Also coat the terminal studs and screws.
    Hnstray likes this.
