Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. Will do Matt, just sent some parts to get media blasted so hopefully I can move forward soon!
  2. x77matt
    x77matt
    Today I picked up my gauges after a fresh resto! They turned out beautiful and I can't wait to see how they look mounted up!
    V8-m, Okie Pete, jalopykid and 5 others like this.
  3. Nice. Al.
  4. CTaulbert
    CTaulbert
    from Detroit
    Are they mounted yet???
  5. x77matt
    x77matt
    Ha! Not until I decide if I'm adding a second temp gauge or not
  6. alchemy
    alchemy
    Is the volt gauge one of the new Cl***ic Instruments?
  7. x77matt
    x77matt
    No- Chris made it for me out of Stewart Warner bits. I know they didn't make one original, but I thought it would be handy to have volts rather than amps.
  8. x77matt
    x77matt
    This week I worked in the exhaust quite a bit. Man do I hate welding stainless tube. I finally bought a Y valve so I could run a purge line inside the tube and it was like night and day easier to weld and with better quality. Once complete I'll be able to out the body back on for final mockup. I'm going to run chambered tube mufflers like on my sedan and 2" stainless, but for mockup I have just a set if straight pipes in there.
  9. 3blapcam
    3blapcam
    Where did you buy that pipe and did it already come in pre-bent sections? Is it 2"?
    3blap.
  10. x77matt
    x77matt
  11. alchemy
    alchemy
    But is food grade good enough to use on a hot rod? o_O
    Atwater Mike likes this.
  12. 3blapcam
    3blapcam
    Thank you sir!!!
    You're right... that's not that expensive! I acquired a few s**** pipes from Freescale when they were moving that look to be the same quality. I was worried that it would cost a fortune to use it...
    3blap.
    loudbang and x77matt like this.
  13. x77matt
    x77matt
    I think it sanitizes the exhaust fumes
  14. town sedan
    town sedan
    More importantly were the welds polished so bacteria can't hind there and sour the exhaust? Nobody wants sour exhaust.
    -Dave
  15. x77matt
    x77matt
    Ha- yes actually. It's the only way to make my stainless welds look tolerable before I figured out to backpurge it :)
  16. 3blapcam
    3blapcam
    Are you TIG welding the pipes together? Are you using the flanges from that eBay link also? I looked up 2" flanges and they're more expensive than 2.5"... I'm guessing price is completely based off demand.
    3blap.
  17. x77matt
    x77matt
    Yes- tig welding everything. flanges from eBay also. You are right too- they are crazy expensive but really handy and clean compared to standard clamps.
    sko_ford and loudbang like this.
  18. x77matt
    x77matt
    Worked on the driver side exhaust this weekend. Learned something else new- I had tacked several sections in place and them removed them to fully weld. Stainless moves around enough with the heat that i had to cut back apart a few welds and realign . From now on I will fully weld one section at a time.
    20180811_203534.jpg 20180811_203527.jpg 20180811_203513.jpg 20180811_203508.jpg 20180811_171948.jpg
    deluxester, Okie Pete, Gotgas and 3 others like this.
  19. brEad
    brEad
    Exhaust looks GREAT! Nice work!
    x77matt and loudbang like this.
  20. fishslayer82
    fishslayer82
    Great job Matt!
  21. Matlack
    Matlack
    Great work! Thanks for the ideas.
  22. x77matt
    x77matt
    Hey guys- well, this exhaust has taken me 4 times longer than anticipated but I was able to wrap it up today. I hung it with 4 rubber hangers but I may add one more per side to make it bulletproof. Now that this is done, I can cut the hole in the floor for the model A crossmember and set the body back on.
    For the mufflers, I used the identicaluffler that I used on the sedan from Cl***ic Chbered exhaust: http://cl***icchambered.com
    He is local and does a nice job.
    For the hangers, I used stainless on the pipe side and steel on the frame side. On the frame side I doubled the bars for stiffness like we would on a typical OEM application.
    Tomorrow I am going to a friends house to have him help me cut down the torque tube. Stay tuned...
    20180901_134335.jpg 20180901_134402.jpg 20180901_224946.jpg 20180901_225033.jpg 20180901_225003.jpg
  23. magnus13
    magnus13
    Looks sharp!
    Sent from my SM-T530NU using The H.A.M.B. mobile app
  24. Shadow Creek
    Shadow Creek
    Really like the “OEM” style exhaust hangers, that’s a nice touch
  25. x77matt
    x77matt
    Thank you!
    Shadow Creek likes this.
  26. x77matt
    x77matt
    Yesterday CTaulbert helped me cut down the torque tube using his gigantic band saw, and bad *** torque tube welding jig. I put the torque tube in, cut the rear crossmember hole, and set the body on for another mockup. Seems like no matter how you brace these roadster bodies, every time I take it off and put it back on, all the gaps go to hell!
    This week I will probably pull the rear out and start doing the final fab with the '36 bones and get the rear end ready to build out.
    IMG_20180902_223455_979.jpg IMG_20180902_223455_978.jpg 20180902_201439.jpg 20180902_200410.jpg 20180902_200340.jpg 20180902_172754.jpg
  27. x77matt
    x77matt
    Rear axle:
    The standard 36 bones are quite long for the 32 and they must be cut shorter. Also the quick change snout puts the torque tube lower than a banjo so you need to do some surgery to get everything to fit right.
    I cut off the bones at the weld and then grabbed a set of curved 46 Ford front bones that I had in stock, and shortened them up. I like the looks of the curved bones and it should give me a little more clearance to the frame rails as they transition under the frame.
    20180907_203907.jpg 20180907_203913.jpg 20180907_230546.jpg 20180907_230556.jpg 20180907_232329.jpg 20180907_232049.jpg 20180908_002916.jpg 20180908_002942.jpg
  28. louisb
    louisb
    Wish my welds were that nice.
    —louis
    kidcampbell71 and x77matt like this.
  29. x77matt
    x77matt
    Tonight I wanted to test fit the rear back in the car but the quick change really gets in the way of spreading the spring. I grabbed an idea from a past thread on the HAMB and built a dropped spring spreader out of s****s to clear the quick change. Worked pretty good!
    deluxester and louisb like this.
  30. 51box
    51box
    from MA
    Nice work car looks great, the later front bones on back is a pretty trick idea
