Projects 1957 Chrysler Mild Custom
Discussion in 'Traditional Customs' started by Gotgas, Jan 15, 2018.
  1. Dan Hay
    Dan Hay
    Awesome! My Buick Nailhead kinda runs like that, and I know it's hitting on all 8, all the vacuum lines **** (literally) so it's good to know that it will probably run a lot better when I clean all that up.
  2. Peanut 1959
    Peanut 1959
    Hooray!
  3. RodStRace
    RodStRace
    Glad to hear you got it fixed! Will you be able to make the show?
  4. HEMI32
    HEMI32
    FYI ... The Lonestar Roundup was last weekend.
    That stated, now Danny has a whole year to get the rest of the car in paint for a “proper” LSRU debut :D
    eddie1, Gotgas and Hyfire like this.
  5. RodStRace
    RodStRace
  6. Hemihead_NHRA
    Hemihead_NHRA
    Your car is one to take examples from, and is drop dead gorgeous
    What clutch, transmission, throwout bearing, flywheel, adapter plates, bellhousing did you use?
    Im building up my ‘50 coronet with a 55 291 desoto hemi and id like to make it a manual, but for all i know is that they came with push ****on powerflites. Where did you get all the parts for it or from what other things?
  7. Gotgas
    Gotgas
    from DFW USA
  8. 48fordnut
    48fordnut
    Your Desoto grill really makes it pop. I'm not a custom guy, but what you have done with yours make it a winner
  9. InstantT
    InstantT
    from SoCal
    Oh man! When I put the 4barrel manifold on my Y block, I fought with it for days. Finally put a tube on the carb base, took a big drag on a stogie and blew into the tube. Smoke started rolling out of the open pipe bung in the back of the manifold. I hated myself[emoji23][emoji23]
    Sent from my LGLS992 using The H.A.M.B. mobile app
    dwollam likes this.
  10. Gotgas
    Gotgas
    from DFW USA
    Not a ton to update here. I've been focused on my house while the weather is good, but I have still been toying with the car some in my spare time. I put a set of CC spiders on the wheels, and a pair of taller L78s on the rear. I have ****oned up a couple of minor oil leaks. I have been working on wiring up the power windows - what a pain! I wired up an iPod stereo for some tunes. I still need to get a real alignment and take it on longer drives. But so far it has close to a hundred miles on it and it runs and drives pretty good! Here's a really short and boring video of it going through the gears.
  11. DIYGUY
    DIYGUY
    from West, TX
    cool times five man !!!
  12. Wraith
    Wraith
    from DFW
    Beautiful car and great work!
  13. Gotgas
    Gotgas
    from DFW USA
    Big shout out to my dad and my friend Dave for all their help in welding up the door handle holes!
    Who says you need a $80 3M PanelBond gun? We made it work with an old caulk gun, a couple of sockets, and some zip ties. :D
  14. porkshop
    porkshop
    from Clovis Ca
    Happy to see forward progress......
    chryslerfan55, Gotgas and hendelec like this.
  15. hendelec
    hendelec
    chryslerfan55, j hansen and Gotgas like this.
  16. oldwood
    oldwood
    from arkansas
    I think it might give your Mousestang a run for the money. Loookin Good
    chryslerfan55 and Gotgas like this.
  17. 48fordnut
    48fordnut
    Your ideas on your car rock.
    Gotgas likes this.
  18. Dan Hay
    Dan Hay
    What's the entry plan? Door poppers?
  19. Knghtcadi
    Knghtcadi
    Did you glue the filler panel in ?
  20. Dan Hay
    Dan Hay
    Oh, and I have a panel bond gun you can borrow if you do any more of that.
  21. Gotgas
    Gotgas
    from DFW USA
    It was tacked into position and then PanelBond was used to fill in the remaining small gaps.
  22. Peanut 1959
    Peanut 1959
    What did you expect from the Forward Look kustom? [emoji1]
  23. Arominus
    Arominus
    Sway away offered to make me custom torsion bars for the Plymouth/dodge/firesweep length if i sent them in for about the $500-600 range. IF the ends are the same size as the later bars it might be cheaper... Sizes available up to 1.24 diameter if i remember right. If you want big t-bars, thats your hot ticket vs a set of 300 bars and would be offer more spring rate than even the 300C/D bars did. My plan was 1.15 or 1.2 for my firesweep vs the hard as hell to get 1.11" 956/57 bars that sell for $500 anyways when they do pop up.
    Does the Hot Heads intake clear with that hood scoop? looking at something to clear it for my Firesweep...
  24. Gotgas
    Gotgas
    from DFW USA
    My scoop isn't open on the bottom. Even if it was opened it up, it wouldn't come close to fitting a HH intake and typical aftermarket carb and air cleaner. There's only about a quarter inch of clearance with the stock (flattened) intake and (laid over) air cleaner. Take a look at the picture and you'll see my scoop is only about a half-inch higher than the stock hood where the carburetor is.
    Thanks for the tips on the T-bars, I will look them up!
    VANDENPLAS, 40two, mgtstumpy and 7 others like this.
  25. James D
    James D
    This is so cool....and a manual Hemi too...perfect!
    scotty t and BigO like this.
  26. 48fordnut
    48fordnut
  27. RodStRace
    RodStRace
    Gotgas, really hoping the plan is solid, deep, blackest, BLACK.
    Since the trunk is already shot, do you have a specific brand/line/mix you'd like to share?
    It's always a good topic to cover with paint formulas constantly changing.
    Gotgas and chryslerfan55 like this.
  28. loveoftiki
    loveoftiki
    from Livonia,Mi
    Ummmmm ya might wanna grind that out of there and finish welding..any adhesive expands and contracts at different rates than the metal. It’s recommended for gluing flanges of body panels, not patch panels. It’s extremely strong, but when you open a tube of 3M 8115 up it shows the 1/4 panel
    Application and they show welding the sail panel cut for that very reason. Eventually a bond line may show up under your paint work.
    There was a very nice mild Kustom done Here years ago and the owner glued the headlight rings of his 54 ford on. I gave him a heads up...about 3 months later I saw the finished car...could see the bond line plain as day...he said....I know..I know..
    Great car btw, just wanted to give you a heads up
  29. Gotgas
    Gotgas
    from DFW USA
    It's PPG, I'll have to look up the code. It's just straight black.
    Thanks for the heads up. I think we're gonna rock it. It's welded about 80% of the way around and this is just to fill the small gaps. It will have plenty of time to shrink, we won't be doing finish body work for a few months.
  30. safetythird
    safetythird
    A few months? What do you expect us to do? Work on our own cars?
