Hot Rods Jerry 's 32 5 Window Project
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Sep 7, 2016.
  1. 2bubbas
    2bubbas
  2. HomemadeHardtop57
    HomemadeHardtop57
    Purchased a cool oversized Moon tank which came with a neat story. Going to use it as my fuel tank. Dean Moon made it for his engine dyno set up. Cool info....
    Hey Jerry ,
    ok so my Uncle, Alan Welch, had a engine balancing business named Automotive Balancing Service which goes back to the 50's. His Partner Richard Bauman also had a mail order engine shop named Speed O motive which was sold to George Ullrich in the early 90's. So My uncle purchased the dyno From Dean Moon so he could test some motors that they would be selling through Speed O Motive. this was in the late 70's and I remember that dyno room and that ol tank with several others set up there. I was about 10. I will try to track down some old photos but to be honest don't know if we have any. To bad cause that would be great all around. So the mail order shop was sold and both Alan and Richard have p***ed on. Years ago that dyno was parted out as it was old school stuff by then. The tank was all that remained from that program. My pops has been cleaning out some stuff from his shop/man cave and yea now it's going to a great home.
    cheers Screenshot_20180801-234509_Gallery.jpeg Screenshot_20180801-234500_Gallery.jpeg Screenshot_20180801-234451_Gallery.jpeg Screenshot_20180801-234440_Gallery.jpeg Screenshot_20180801-234418_Gallery.jpeg
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    Tman, chryslerfan55, AHotRod and 8 others like this.
  3. bowie
    bowie
    That’s one heck of a cool tank Jerry!
  4. HomemadeHardtop57
    HomemadeHardtop57
    Made an upper steering support for the extension Andy Kohler fab'd for me. Made from s****s I had laying around in the garage. Had a buddy machine some nylon bushings. Worked out great. The support is hung off a couple bolts from the cowl steering box. The inner steering shaft turns freely inside.
    IMG_20180802_204450_634.jpeg IMG_20180730_224741_568.jpeg 554915928.jpeg 20180802_134157.jpeg IMG_20180802_204450_663.jpeg 20180802_134416.jpeg IMG_20180802_204450_661.jpeg IMG_20180802_204450_665.jpeg 20180802_134507.jpeg IMG_20180802_204450_678.jpeg IMG_20180802_204450_671.jpeg
  5. Hendee
    Hendee
    loudbang and HomemadeHardtop57 like this.
  6. frdsuperduty
    frdsuperduty
    from Lewes De
    That's cool!
    Sent from my SM-N950U using The H.A.M.B. mobile app
    chryslerfan55, loudbang and Stogy like this.
  7. HomemadeHardtop57
    HomemadeHardtop57
    Boling brothers finned edge drums came in today. It's a neat product they are making. Steel drum with Buick sides. They fit right over top a stock 40 hub with no machine work needed. They should work great with the B*** brakes. IMG_20180806_122915_197.jpeg IMG_20180806_122915_184.jpeg 20180806_122202.jpeg
    ls1yj, Hank37, chryslerfan55 and 8 others like this.
  8. HotRodMicky
    HotRodMicky
    Wow, nice !!!!
    New Product from them ?
    Look great!
    You gonna chrome them ?
    If you dont mind the question....how much are they?
  9. Runnin shine
    Runnin shine
    I’ll be watching how the drums perform. I’ve had my eye on this for a little while for my 32pu.
    Your brakes are turning out beautiful!
  10. HomemadeHardtop57
    HomemadeHardtop57
    Thanks, I've heard good things about them and they look very nice. I have heard that sometimes that these drums will need to be checked and turned a bit, even though they're brand new so I will have them checked. The drums themselves are the MT ones. Boling Bros. machines and presses a new cast Buick outer on overtop and pins it to the drum for safety. Its a great idea. A buddy of mine purchased a pair when they first came out and they seem to perform very well on his car. The B*** brakes basically function as good F1 units so they should work really well.
  11. HomemadeHardtop57
    HomemadeHardtop57
    Thanks. Going to polish the aluminum Buick outsides. http://www.bolingbrothers.com
  12. Runnin shine
    Runnin shine
    Thanks Jer’ I had planned for awhile to do Brian’s conversion myself after I first sold a set of 48 plates I re-did and made scoops for. I sold those cause I didn’t like the dimples. Then bought a set of drilled 40 style off the cl***ifieds. Then gave those away to help another H.A.M.B. members project. Then I was going to do Lincoln bendix with Buick 45s. Then I saw the cool drums a while ago and said time to just by another set of smooth “40s”, drill’m, scoop’m, B*** mod’m, and some black.
    Your chrome stuff is da’bomb.
    All your stuff is great inspiration.
    chryslerfan55, Stogy and brEad like this.
  13. Runnin shine
    Runnin shine
  14. HomemadeHardtop57
    HomemadeHardtop57
    I was also able to make a bit more progress on the homemade Pines grill insert IMG_20180806_174301_989.jpeg
  15. Runnin shine
    Runnin shine
    Did you see how I flattened the sides of a 7/16” stainless tube for the center strip for my pines clone?
    I will weld the top and bottom pieces into it
    Don’t know why I haven’t put this together since the shutters and everything is done[emoji848]
  16. HomemadeHardtop57
    HomemadeHardtop57
    That looks great. What diameter did you use for the perimeter piece?
  17. Runnin shine
    Runnin shine
    My outside piece is an original stock insert I got for a hundo. Most of the bars were messed up or missing. I hooked up other HAMB’rs with what was salvageable and was off to the races on this project. I’m confident that the Pines were at least a 1/2”. I am now planning on making a more accurate outside for ct1932ford from scratch if I could find out how thick they really are.
    You let me know or I’ll let you know?
    I made my bars out of copper(gonna piss on’m) with my bead roller. It’s all on my thread.
    Wyatt
  18. HomemadeHardtop57
    HomemadeHardtop57
  19. loudbang
    Drums and backing plates look GREAT.
    brady1929 likes this.
  20. brEad
    brEad
    That is one bad *** cheese grater! Sweet!
  21. HomemadeHardtop57
    HomemadeHardtop57
    The moon tank that was on Dean Moon's engine Dyno showed up today. At first I didn't think it was going to fit in the car because it's huge. It actually tucked in nicely right behind the seats
    Threw it in and mocked it up
    IMG_20180808_170317_528.jpeg 20180808_143327.jpeg 20180808_143452.jpeg 20180808_135257.jpeg
    51box, chryslerfan55, AHotRod and 6 others like this.
  22. HomemadeHardtop57
    HomemadeHardtop57
    Got a set of 40 hubs set up with new bearings and seals. Wanted to see how the brakes and drums fit up when hung on the spindles. Seems like everything fit up nice.
    chryslerfan55, Runnin shine and Stogy like this.
  23. HomemadeHardtop57
    HomemadeHardtop57
  24. Mike Colemire
    Mike Colemire
    I just ran across this thread and read it all the way through. You've got some skills man, the detail in this car is out of this world. Thanks for sharing.
    IowaMercMan, loudbang and Stogy like this.
  25. HomemadeHardtop57
    HomemadeHardtop57
    Thanks Mike. Its coming together.
  26. HomemadeHardtop57
    HomemadeHardtop57
    Mounted my tach in a neat old chrome cup, I believe the tach is early thirties Auburn 20180813_160841.jpeg 20180813_160726.jpeg 20180813_161517.jpeg
  27. brEad
    brEad
    Tank fits perfect! Looks just right with the seats. Brakes are pretty *****en, too.
  28. HomemadeHardtop57
    HomemadeHardtop57
    Made up some original 50s style spring hold downs enclosed in some clear tubing IMG_20180820_204333_700.jpeg
    chryslerfan55, AHotRod, Stogy and 2 others like this.
  29. HomemadeHardtop57
    HomemadeHardtop57
  30. HomemadeHardtop57
    HomemadeHardtop57
    Fire in the hole. Pat had a nice old chrome plated housing and base that vertex would take around to shows when they would set up displays. He set up the internals and cut the shaft for my caddy motor and topped it with the aluminum cap cover I picked up. Wild IMG_20180821_133155_189.jpeg 20180821_132237.jpeg
    kadillackid, ls1yj, Hank37 and 9 others like this.
