The Official 1941-48 chevy picture thread
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Apr 30, 2012.
  1. Pete
    Pete
    DAMN!!! I love this car!!! I would trade my Merc for a '41 Chev!
    Pete-
  2. Yes!
  3. Which ?
  4. Ok changed,
    Theses are some beautiful cars.
  5. Von MoPar
    Von MoPar
    from Australia
    That's a perfect chop top, well done!
  6. DJLATIN
    DJLATIN
    :eek:I'd trade my '51 coupe for a '47-'48 chevy coupe.:eek:
  7. FastActon
    FastActon
    from Fresno, CA
    Here's my '47 coupe that I picked up at an auction recently. I'm missing the doors, though. Would the doors from any '41-48 coupe fit?
  8. 37_chevy
    37_chevy
    from Nebraska
  9. Hnstray
    Hnstray
    from Quincy, IL
    '42 thru '48.........'41 skins are different at front of door.....
    and, you can use doors form Pontiac and Olds coupes that shared the GM "A" body.........
    Ray
  10. Here's my 47....
    Rat
  11. six pack to go
    six pack to go
    from new jersey
    Here is my 41, It was pink and purple when I picked her up!!! I painted the pink flat black and left the purple top.. running a 1985 Buick V6. Its for sale so make an offer, trades welcome!
  12. triker ox
    triker ox
    My 47 Coupe project , has Chevelle front clip and 350/350 combo slowly coming along. 10151976_10205808649234806_8230605500769359664_n.jpg
    pckasmin likes this.
  13. mgtstumpy
    mgtstumpy
  14. pckasmin
    pckasmin
    from Florida
    My 48 Coupe. Has a Chevy 350, 350 trans and a Camaro clip.
  15. pckasmin
    pckasmin
    from Florida
    And my Sedan. My father bought this new in November of 1948.
  16. Jibs
    Jibs
    My 47 Chevy sedan, owned since 1992, 472 Cadillac, turbo 400, 9" Bronco rear, chopped 3.5", hood sectioned 1.5", 102 louvers. It gets 18-20 miles per gallon at 70 mph.
  17. Chavezk21
    Chavezk21
  18. BBFHY
    BBFHY
    from Texas
    48 Chevy sedan. Chopped, channeled over 65 El Camino frame, sectioned 4 inches, shortened 6 inches, steel lift off top, forward opening hood. 396, 3 speed, 10 bolt 3.36 posi. Need to start working on again.
  19. rusty1
    rusty1
  20. Dangerous Dan
    Dangerous Dan
    Getting closer with my 48, Whoopee 075.jpg 076.jpg 077.jpg 078.jpg .
  21. Ldogg53
    Ldogg53
    I've got a 47 really similar to this. Going on over a year on the build and almost done.
    My current conundrum is with the hood latch. I've replaced the cable but the bend is too much on it and it's basically useless. Doing some googling and it appears lots of people have issues with the latches. So what did you guys use?
    Also, any suggestions for a hood prop?
  22. Ldogg53
    Ldogg53
    Dangerous Dan likes this.
  23. IMG_3874.JPG Here's what I have to hold my hood up- basically a piece of 3/8" rod. and a couple of brackets. This is under the hood lip, using a couple of holes that were already there.
    This is the inside fender socket for the rod.
    And a small clip to hold the rod end up under the hood lip. The springs don't really hold the hood up high enough to work under without whacking your melon, so using the rod gives you a few more inches of headroom.
  24. Dangerous Dan
    Dangerous Dan
    I used the hood release knob and cable from a 89 Chevy PU. It bolts up just under the dash and look good. While you are at it remove the latch and drill or grind a oblong hole in the bottom of the latch mechanism so you can stick a screw driver in between the grill bars to push the latch if the cable ever breaks. I also just put new hood springs in and don't need a prop.
