Technical Opinions on copper zinc brake line
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Aug 5, 2018.
  1. Blue One
    Blue One
    from Alberta
    No confusion at all from this side :D
    Cunifer and ni cop are just different ways of saying the same thing.
    Same alloy, same material.
    It’s all an alloy of copper, nickel and ferrous.
    loudbang, lothiandon1940 and Dino 64 like this.
  2. Blue One
    Blue One
    from Alberta
    I have 3 different benders, they are all Imperial benders.
    Industrial quality and only bend one size of tubing.
    Way better than the benders that bend multiple different sizes.
    They typically (cheap hardware store multiple size benders) don’t bend to a nice tight radius.
    And sometimes they are difficult to use.
    The single size Imperial benders are favored by tradesmen like instrument fitters etc.
    https://imperial-tools.com/products/364-fha-lever-type-tube-benders/
    A111C014-B41F-4B0E-9510-EF48479D6C27.jpeg 539CAC0B-2D59-4F64-B972-62BBD6175649.jpeg
  3. mediumriser
    mediumriser
    from Ohio
    In my opinion that stuff NEVER looks as nice as some carefully thought out and bent steel line. Looks cheap and to me always looks like it was rushed putting it in and an after thought.
    DRD57 likes this.
  4. Dino 64
    Dino 64
    from Virginia
    I was the one confused, just for the record.
    lothiandon1940 likes this.
  5. lothiandon1940
    lothiandon1940
    Confusion, delusion..........I get the two mixed up!:D;)
    lothianwilly71 and Dino 64 like this.
  6. slowmotion
    slowmotion
    I deliver coils of the stuff weekly. It's all the pro-shops use now days. Good stuff. As far as looks, I'd go with stainless if that's your bag. o_O
    Bandit Billy and lothiandon1940 like this.
  7. Dino 64
    Dino 64
    from Virginia
    Huh ? What ?
  8. Blue One
    Blue One
    from Alberta
    Of course you are en***led to your opinion even if you’re wrong. :p
    Check out all the pictures of my plumbing on my RPU build thread and then try to tell me it looks cheap ,rushed or an after thought :rolleyes:
  9. Dino 64
    Dino 64
    from Virginia
    You did a great job on those lines, only one dissenting post, I think he’s outnumbered
  10. Fortunateson
    Fortunateson
    Well I meant for anyone in general that was confused. But now I am a bit confused as NiCopp should be Nickel/Copper alloy whereas Cunifer is Copp/Nickel/Iron alloy if the manufacturers are being honest with the periodic table.
  11. Bandit Billy
    Bandit Billy
    Out numbered yes, but this thread wasn't ***led "which looks cooler, Stainless or Nicopp". If it has been there likely would have been overwhelming support for the shiny :cool: stuff. I know I like it better on the right car.
  12. dirty old man
    dirty old man
    My question is about a straightener, for cunifer or any other tubing bought in a coil. What works good without breaking the bank?
    Bandit Billy likes this.
  13. Bandit Billy
    Bandit Billy
    I bought one from Eastwood, it worked very well. It was just for 3/16 line but they offer one for multiple sized lines, no idea if it works or not.
  14. Drill a hole in a piece of hardwood. Pull it through. Straight pipe. I also made a straightener using six patio door pulleys on an angle iron frame. Looks just like the ones you can buy but only cost ten quid.
  15. Blue One
    Blue One
    from Alberta
    I messed around with a variety of different over the years flaring tools and never really liked any of them.
    This time around I wanted easy and professional results.
    So I ordered the Eastwood flaring tool that does 3/16”-3/8”.
    Probably one of the best tool purchases I’ve ever made.
    Really easy to use and perfect flares, not a single leak in any of my self made brake lines.
  16. Bandit Billy
    Bandit Billy
    ^^^Same tool, I love that thing. I also got their AN die set for the flaring tool and used it on my fuel lines.
    loudbang and Dino 64 like this.
  17. Dino 64
    Dino 64
    from Virginia
    Well, it wasn’t [emoji6][emoji41][emoji106]
    lothiandon1940 and Bandit Billy like this.
  18. Blue One
    Blue One
    from Alberta
    As for a tubing straightener I thought about making my own but as you can see from my build thread I had plenty of other stuff to build.
    So I just went onto eBay and ordered this one for $120.
    Works really good.
  19. Dino 64
    Dino 64
    from Virginia
    Is that the Eastwood tool ?
  20. It depends greatly on the installer and their personal commitment to professionalism and craftsmanship.
    Then, when the guys work truck hlows a rear line we can spend all day on bending a line or an hour on snaking it and pull it thru A to B easy as pie. We get paid, he's back on the road with good brakes, his kids still get dinner and that line ain't well thought out or pretty. The situation is though.
    vtx1800, loudbang, Randall and 3 others like this.
  21. Blue One
    Blue One
    from Alberta
    No, straight off eBay and shipped to me directly from Singapore.
    Dino 64 likes this.
  22. tb33anda3rd
    tb33anda3rd
    yep, many times i have repaired a broken brake line, late at night cold and snowy. with a plow and sander the truck can't go on the lift so i would have to slide under, clip the old line at either end, take out the fittings, tape the end of the new line and send it along the frame, attach the ends, zip tie it to the old line, bleed and the guy is back tearing up curbs, pealing back gr*** and moving gravel into the yards...........strung like christmas lights but cheap and solid repair.......
  23. Fortunateson
    Fortunateson
    I was going to mention your effort but I can't recall the thread ***le. Time to bump it up I guess if you would.
    Dino 64 likes this.
  24. Three bearings mounted on a piece of wood can do the job of straightening line
    Bending and flaring lines can be an art form or a pain in the ***!
    I spent hours and hours on my Lincoln to get the lines arrow straight and the bends perfect so I could reuse all the stock mounting points and make it all look oem.
    I’ve also basically thrown line at the bottom of some of my winter beaters and zip tied it to the old rusty line.
    They both work to get my brakes working correctly, but why waste time when the vehicle is not worth the effort ?
  25. dirty old man
    dirty old man
    Blue One, that's a nice straightener you show in the pic, and my being a retired machinist with a fairly well equipped shop, I think I could make that pretty easily.
    Approx. what is overall length and what is approx OD of wheels? Also, does the adjustment knob move both the wheels in together?
    I've got "more time than money" so that might be a good Winter project to keep me busy.
  26. Rocky
    Rocky
    Classified Editor
    I used it on my 34...won't use anything else now.
  27. Beanscoot
    Beanscoot
    I searched, but could not find on the internet the comparison of genuine Cunifer to other similar CuNi products.
    This may have been posted in a previous brake line thread. As I remember it, some of the other brands were a little bit thinner wall, resulting in not so good flares and other possible problems.
  28. metlmunchr
    metlmunchr
    DOM, if you search tubing straighteners on Eastwood's site there's a near identical unit that has pics of both front and back. The lower wheels are fixed and the upper pair is adjustable. One pic shows a man's arm behind the straightener that gives a pretty good perspective of overall size.
    I'd make a wild guess that the bearings may be inline skate wheel ball bearings as they're made by the millions and dirt cheap, like 100 pieces for 20 bucks. Those bearings are 22mm OD, 7mm wide, with a 8mm bore. A pair of them pressed into one of the wheels with a couple mm space between would work out about right for what the overall width appears to be based on the max 1/2" tube diameter.
    They say the wheels are ABS plastic which is about as cheap a plastic as you can find. Would seem to me most any plastic would work without marking the tubing, and if you can't come up with suitable plastic I can't see any reason why some hardwood wheels wouldn't work as the loads aren't high at all.
  29. RICH B
    RICH B
    I looked at one where the rollers appeared to be patio door wheels.
  30. bobss396
    bobss396
    I have mixed emotions on it as well. A shop I know did a suspension upgrade on an OT car and used it. It is hard to straighten out and it looked cheesy in this application. If it was made in straight sticks, I would give it a go.
