Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. I haven't mowed my yard any at all this year. I put up temporary electric fence around stuff I wanted to not be eaten. And let the cows in the yard. they dont mow evenly but they keep down the jungle.
    swade41, JOYFLEA and 34 GAZ like this.
  2. Boneyard51
    Boneyard51
    Old Wolf, you are spinning your wheels! Don’t you know that even though cows eat the gr***... they fertilize at the same time! Kinda perpetual gr*** thing, ya know......
    Bones
    Old wolf likes this.
  3. UNSHINED 2
    UNSHINED 2
    Fought with :mad::mad::mad::mad::mad:yblock distributor:mad::mad::mad::mad::mad: for a good hour today. Air chisel finally got it out. A little brrrrrrp----brrrrrp is all it needed:oops:. Got the heads on and timing chain installed. Then off to work.....sorry no pics
    j-jock and Max Gearhead like this.
  4. Yea you gotta watch your step when the cow chips are down
  5. Ok I went and unloaded my truck when it cooled down this evening. used the lift on the three point hitch to pull the Pontiac remains off the Pk. Worked out like I wanted. I even rode the bicycle a little bit. Bike cost me $2.50
    34 GAZ and UNSHINED 2 like this.
  6. 2bubbas
    2bubbas
    Drove a 90 year old neighbor into town to get a hair cut- he loved the truck- liked the wing windows as he called them- said steering looked like Armstrong to him- we both had a blast-
  7. UNSHINED 2
    UNSHINED 2
    Good stuff, right there!!!
    Wrench666 likes this.
  8. I recharged the air conditioning system in the primary O/T vehicle. No immediate problems, and it is working like a hot damn. A big success, considering that the system had been opened up and required purging and the whole enchilada.
    Put some new rubber on my O/T hauler, and after a week I am noticing I have a bead leak on one of my tires. I am really choked, because I cleaned the rim myself, and have to look in the mirror to blame the responsible party. I could attempt to hammer the bead to see if I can make it seal, but I will probably break it apart and refinish the rim. In the longer term, that is the best solution.
    I also did a bunch of research on the linkage setup I am going to use for my 9 inch rear end that I am building to replace the 12 bolt. I am going to be making two 3 link systems to replace the leaf springs on my truck and my son's 47 International.
    Back in action!
    Bob
    UNSHINED 2 likes this.
  9. Regarding mowing, It is so dry here, that I am going to have to wait for rain just to mow and trim. Otherwise, I'll just make a big dust cloud.
    Bob
  10. NWRustyJunk
    NWRustyJunk
    I put the front suspension back on my 40 Plymouth Sedan. So far it's going back together pretty well...no major problems so far. Now to decide what engine I want to run. IMG_20180810_160643424_LL.jpg
    Terrible80, JOYFLEA and UNSHINED 2 like this.
  11. Went to a estate auction just a few miles away . The folks grandson had murdered them!?. Bought a small truckload but nothing HAMB worthy. a couple of chainsaws, a handicap 4 wheeler and the carrier for it that attaches to a receiver hitch. a wide front end for a vintage tractor. a tractor radiator and a large hyd bottle jack.
  12. garage2small
    garage2small
    Swapped the Offy valve covers on the Y block for T Bird covers. 20180515_161327.jpg 20180811_155138.jpg
  13. UNSHINED 2
    UNSHINED 2
    Wanted to get my engine sealed up so I went at it today.... 20180811_205222.jpg
    mkebaird, 32Dan, j-jock and 1 other person like this.
  14. Max Gearhead
    Max Gearhead
    from Wisconsin
    :cool: Progress, progress, progress. :cool:
  15. UNSHINED 2
    UNSHINED 2
    Something everyday!
  16. swade41
    swade41
    from Buffalo,NY
  17. alwaysamopar
    alwaysamopar
    No joke... up early this morning after a late night trying to get to the salt to watch Danny Thompsons back up run. My brother and I are flying down the salt on our shovels when I hear and feel this rumble. .I thought it was another bike..I looked over to my right to see Danny Thompson making his back up run. ...it was so cool seeing it next to us(but far away)...This place is soooo bad ***.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  18. lumpy 63
    lumpy 63
    Got to the shop around 9 , Finished up the 350 roller motor and mounted it on the run stand . Fired right up and sounded sweet, My buddies all ribbed me and said I didn't do it right cause flames didn't shoot out of the carb like on TV:confused: My buddy Butch installed the vent windows and regulators in my 37, Thanks again Tag Man! After that we helped Daniel, the youngster in the shop drop his fresh 283 into his 64 c10. And last but not least we went over the 55 chevy 4dr my friend Bob just bought , one family car came with an ***load of NOS parts including freaking NOS front fenders and hood! Still in the crate! It was a good day:D
  19. The37Kid
    The37Kid
    [​IMG]This may turn into a frame table, reversed that wheel so the tire doesn't rub. Rolled it down hill and around and into the back yard all by myself, ****er is heavy. Bob
  20. Did some cleaning on the new front axle for the 55. I need to find a pattern for and adapter to bolt the Blazer disk brake calipers I am presently using, to fit the 55 spindles. My son was trying to convert me from the TH400 to a 700R4, but I can't see giving up my overdrive. I have all I need to install a super T-10, and think if I change transmissions, that is the way I'll go. I can still use my Hone-O-Drive overdrive unit.
    Got the excavator running today. It needed a new fuel pump and I had to bleed the complete fuel system, ***** of a job. I also changed all the filters and greased the machine. Start clearing the area for the garage foundation tomorrow.
    Very content for the small victories. I had to quit because I was getting eaten alive by mosquitoes.
    Bob
  21. UNSHINED 2
    UNSHINED 2
    Went from bad ......to fixed... 20180813_130539.jpg 20180813_130654.jpg 20180813_130624.jpg 20180813_130816.jpg 20180813_130918.jpg
    JOYFLEA, swade41, j-jock and 2 others like this.
  22. UNSHINED 2
    UNSHINED 2
    Made the cab mount, just have to grind the welds. Installing it tomorrow... 20180813_131126.jpg
    JOYFLEA, j-jock and Max Gearhead like this.
  23. Max Gearhead
    Max Gearhead
    from Wisconsin
  24. Deuces
    Deuces
    Went back to work today.... After a 5 month leave of absence.... :confused:
    And my body is killin' me.....:confused:
    I must be getting old...:(:oops::rolleyes:
    swade41 likes this.
  25. blowby
    blowby
    from Nicasio Ca
    Managed to pinch two wires while bolting a generator back together. The ironic thing is when I need a wire to stay under a nut it takes three hands to hold it there.
  26. swade41
    swade41
    from Buffalo,NY
    Roughed in a template for my mirrored stainless insert
  27. UNSHINED 2
    UNSHINED 2
    Boy, that should look good!
    swade41 likes this.
  28. swade41
    swade41
    from Buffalo,NY
    I've never had a car with one so I figure let's put one in the Henry J, it's an extra 7-8 lbs probably but what the hell, that tunnel ram will look good in it..hahaha FB_IMG_1510380826010.jpg
    UNSHINED 2 and Max Gearhead like this.
  29. UNSHINED 2
    UNSHINED 2
    Now yer gonna have to scrub off the backside of your engine like you do the front....
    swade41 likes this.
  30. UNSHINED 2
    UNSHINED 2
    Was able to get cab mount installed, just have some final welding to finish up on.... 20180814_132330.jpg IMG9529571.jpg 20180814_132319.jpg
    JOYFLEA, swade41 and Max Gearhead like this.
