Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. madmike3434
    madmike3434
    I also posted a wanted in the RUSTY BOWTIES, and also the VCCA.ORG CHAT.
    hopefully somebody will have something for you.........bummer thought was , u had 2 rights.
    mike lynch
  2. Joseph Allen
    Joseph Allen
    Turbo57, mgtstumpy, biggeorge and 8 others like this.
  3. TFoch
    TFoch
  4. madmike3434
    madmike3434
    I have seen NOS front fenders for the 35 master appear on ebay usa over the last few years.
    Put a search into ebay for it and then SAVE THE SEARCH and ebay system will tell you by email that one has appeared, whether nos or used.
    parts are out there, you just need to be patient over time. There is a single NOS running board on now and a pair of NOS running boards also.
    mike lynch :D
  5. Lowbuck DR
    Lowbuck DR
    Thanks Mike I will do. I appreciate the help and info. Not in a huge hurry but I do like to have the big pieces before getting to involved.
    Thank again Don
  6. Joseph Allen
    Joseph Allen
    Break frustrations!! Can’t seem to get my breaks to lock up , plenty of pedal, and no air in the lines ???
  7. madmike3434
    madmike3434
    Joe, your BRAKES , are they disc all 4 , or disc drum.
    If drum, are back brakes adjusted properly.
    Are you using right size line, 3/16 for disc and 1/4 for drum.
    Pedal ratio, what do you have. 5--1 , 6-1 , 7-1
    Master cylinder what size is the bore, is it for power or non power brakes
    Combination proportioning valve for disc disc, or disc drum .
    Using 8" booster dual diaphram
    Whats is vacuum of motor to operate vacuum booster...........need 18--21 inches steady
    mike lynch
    biggeorge, Bowtie Coupe and 6inarow like this.
  8. 6inarow
    6inarow
    Did you break the brakes??
  9. Joseph Allen
    Joseph Allen
    [emoji15]‍♂️
  10. Joseph Allen
    Joseph Allen
    Yes with a power bleeder
  11. Joseph Allen
    Joseph Allen
    Did not run different size break lines
  12. madmike3434
    madmike3434
    Have you checked the engine vacuum at idle with vacuum gauge and using the rear of the intake port. Steady 18--21 inches of vacuum is needed to make a booster function properly.
    Its about applying plenty of line pressure to the brakes.
    Dual diaphragm small 8" boosters produce more braking power than single small 8" boosters
    mike
  13. madmike3434
    madmike3434
    So JOE , what ever ended up with the 32 landau Chevrolet. I understand that Jack recently p***ed away and his son is selling some things ??
    mike
  14. jnaki
    jnaki
    Hello,
    Old Chevy parts? The neighborhood of the "surf ghetto" in South Orange County must be the location of the shop that has tons of parts. It is called Cl***y Chevy. These cars are usually seen outside on the main drag from the freeway to the ocean. It is a great way to advertise the business. (nice looking trucks as part of the business.) No, I do not work for Cl***y Chevy.
    This yellow/white 1942 Chevy pick up truck looks like a custom truck, but there are clues that it is a shop truck, carrying packages and boxes of parts to be shipped across the USA. It is a work truck for light weight parts and boxes.
    For the heavy stuff, the friend behind the 42 custom yellow truck, looks like it could carry a lot more, large and bulky car parts for delivery everywhere. The stake bed helps for larger items. A 38 Chevy stake bed truck?
    Jnaki
    This whole area is the old industrial area of the city that goes back historically, many years... (with Rainbow Sandals being the most popular industrial building known to most people. ) The newest industrial area is just a few miles up the street, on the other side of the freeway.
  15. I didn't follow threw on the 32 landau as I was too conflicted as to it being what I really wanted in a car . I have not heaed anything about Jack p***ing ! , but I certainly will look into to it !!
  16. jgrohio
    jgrohio
    from NE Ohio
    713C6F40-B871-4F29-9A07-18E098A277E1.JPG IMG_0491.JPG IMG_2699.JPG IMG_2732.JPG Not much progress since it's motorcycle season. But cowl finally patched and getting door aligned and hung.
    Turbo57, Fern 54, 31chevymike and 2 others like this.
  17. madmike3434
    madmike3434
  18. jgrohio
    jgrohio
    from NE Ohio
    Best part is I hung the door and it fits really well and will be able to get away with very little if any shimming looks like. Of course body will be off and on a few more times.
    31chevymike, TFoch and Joseph Allen like this.
  19. madmike3434
    madmike3434
    Its all about winning JOE, even one battle at a time.
    mike lynch
    Joseph Allen likes this.
  20. Chuck Craig
    Chuck Craig
    from Ocala FL
    I had to shim the doors on my 34 STD under the sill plate to get the back side of the door to come up to make the body lines fit. Depending on where you put the shim you can raise of lower the back of the door.
  21. madmike3434
    madmike3434
    shimming spots.jpg shimming spots for our cars
    Turbo57 likes this.
  22. Six Ball
    Six Ball
    from Nevada
    That is a great page.
    31chevymike likes this.
  23. Chuck Craig
    Chuck Craig
    from Ocala FL
    You can get a 33/36 Fisher Body book on this stuff, great book.
  24. Those are '29-'30 drawings- my favorite years of Chevrolet's roadster!
  25. Turbo57
    Turbo57
    Hope you dont mind if i jump in this thread. Seems here is a lot of knowledge for us with oldies.I have an 1935 sedan master without floor. I will start to make a new now but need some measurement if someone can help me?? Have a few pictures in my album on the build
  26. speeddemon469
    speeddemon469
    images-1,415.jpg Hi turbo57 here you go GDluck on your build .cheers p.s View attachment 4006688 images-1,417.jpg View attachment 4006688 you can use these pics as templates just hav them inlarged at a local print shop 1.1 scale then transfer to cardboard then to steel sheet afterwards. The measurements you need are in pdf.:cool:
    Bowtie Coupe likes this.
  27. Turbo57
    Turbo57
    Ty for your answer speeddemon, GM heritage is a great place to find info for us with old chevy, and old chevy manual have also much info. I cant use orginal floor measurement, it will be a little different. I only need 2 measure between left and right side where i have marked, those i havent find anywhere, hope someone can help me with this DSC05951_LI.jpg DSC05945_LI.jpg
  28. speeddemon469
    speeddemon469
    Fern 54, Bowtie Coupe and jgrohio like this.
  29. madmike3434
    madmike3434
    FIGURE 217 PICTURED IS FOR A 1934 CHEVROLET STANDARD SERIES CH***IS. 35 STANDARD HAS AN X MEMBER...............mike
    Turbo57 likes this.
  30. Turbo57
    Turbo57
    Yep and my master has a Y- K member, but i am greatful for all tips i get
