Event Coverage The XO/PP Virginia HAMB Special Is Ready for Bonneville!
Discussion in 'The Hokey Ass Message Board' started by TomT, Aug 4, 2018.
  1. dirty old man
    dirty old man
    See that, but just want to know details:):cool:
    old flopper likes this.
  2. Mr48chev
    The radio broadcast/online link doesn't get much if any communication from course 1 aka rookie course prior to the runs. He reads the speeds off the screen after they are posted but that may be well after the fact.
  3. Atwater Mike
    Atwater Mike
    I'm witnessing all the drama of the old 'Cisco Kid' series...
    "Mystery...Adventure...Romance..." This is great, HAMBers covering...Winduptoy, you're making it just like being there!
    The unfolding saga in this thread...Wow! Coil wire...
    Well, just like the times I was there... Loving it!
    By the way...the old longish former Lakes car of Muroc (Leroy Newmeier) then became Chrisman's ol' #25: Lookalike...operated by 'Anderson team'?
    Fooled me for a few seconds at Pomona... thought it was #25...front axle gave it away. Amazing tribute!
  4. GMC BUBBA
    GMC BUBBA
    Is the truck alright , no contact ??????????
  5. brett4christ
    brett4christ
  6. 57Trucker
    57Trucker
    Talk to my brother about an hour ago. They are not sure they have the tune right, but if you hum a few bars... plus might change rear gear. Don't know if they will make another p*** today.
  7. Mr48chev
    It's Tuesday so some of the guys who went down for the weekend probably headed home and aren't around the truck or the pits anymore. Good thing is a lot of the posers went home too and you get a lot better chance to see or be around the race cars.
  8. old flopper
    old flopper
    The plug readings should help with tune, but with density al***ude ranging from ~ 6k ft in morning to over 7k ft in afternoon they’ll need to tune to time of day of run. Gear change should depend on exit speed (last measured point) and what driver felt plus RPM’s at that point, plus was that at end of 2 mile or 3 mile course (unknown to us).
    Edit: They might also consider losing some of that ballast weight from the bed.
  9. ClutchDumpinDan
    ClutchDumpinDan
    Everything is going great gentleman! We’re just busy working. Crew is getting in the zone and things are running smooth. Video to follow if we find some WiFi.
  10. gsnort
    gsnort
    This is great stuff. Fantastic. Just to be able to run on the salt is a dream come true.
  11. john mullen
    john mullen
    I'll try to fill in the days details .
    We got in a run around 8ish the truck went out really good ran out through first gear Dave shifted at 6000 RPM to high at around the 3/4 mile marker the shift point got us closer to the power band this way and was accelerating slowly but ok and was on a really good run when the coil wire decided it wanted to fall off. Totaly my fault for not catching that beforehand. Next...
    We went back to the pit and checked everything out, changed jets and headed back out around 10.45 got in another run and ran 111.6 and picked up a sputter about 3/4 in to the second mile. Just a tiny bit lean but a really clean run. We spent the rest of today debriefing and making plans for tomorrow. Didn't want to run this afternoon because the corrected alt. Was way over 7000 feet and the humidity and temps were not good. We plan to run tomorrow morning around the same times so we can get good data and compare it to the two runs we got today.
    Learning as we go and hope to go faster. Stay tuned and I will try to keep posting when I and crew are not thrashing on the truck.
    Thank you all for your interest and well wishes... John
  12. ClutchDumpinDan
    ClutchDumpinDan
  13. XXL__
    XXL__
    No need to post. Just click "Watch Thread" on right side just below ***le on any page in the thread.
    dirty old man and loudbang like this.
  14. Joel Reeves
    Joel Reeves
    STUPID QUESTION OF THE DAY: Is there a limit on push truck speed? (I was just wondering if the race truck could be pushed fast enough to start in high gear. I have no idea at what speed Dave is shifting)
  15. jimmy six
    jimmy six
    High gear only works ok on the 5 mile course with about 80% nitro in the tank. There is no speed limit on the truck when pushing off only after going to the return road and when on the return roads. Running a 2 speed trans with quite a drop between gears has its drawbacks and is why most vintage engine compe***ors use multiple gear transmissions. Today many are at 5 speeds. These have other drawbacks as in parasitic load/drag. OD's are hard without the extra HP to overcome the extra loads they cause.
    Bonneville is a lot tougher on naturally aspirated gasoline in general and it's taken me years to find a way to overcome the al***ude and high daily temperature consistently. For the most part I still haven't but that has never stopped me, Rich, or many of us... Either we are just hard headed or d--b... I'll go for the hardheaded.
  16. old flopper
    old flopper
    Great info John, thanks from sharing. You guys are pulling through problems well that are often experienced with racing when far away from home.
    Total spark advance correction may help with weather related performance also. If you can get good enough reading of color change point on plug ground strap..... Heck.... Just remove all traction weight and tell Dave to drive though wheel spin to keep engine revs up at shift change! :D
  17. Scott_Rod
    Scott_Rod
    Jimmy Six says;
    “ There is no speed limit on the truck when pushing off”
    Interesting,,,,,
    How about we put a twin turbo LS motor in Doug Dyer’s push truck. That should be good for at least a 75 mph shove off.
    The SCTA folks might have an issue with that idea,,,,,, Something about the “spirit of the rules”.
  18. Mr48chev
    With those guys the push truck wouldn't be LS powered but there would be a late Shelby Mustang sitting in a local wrecking yard with an empty engine compartment.
    I'd imagine that there are a couple of push rigs that can match the race car for speed out there though..
  19. RichFox
    RichFox
    There have been very small bikes that had push trucks faster than the bike. I think it was Rick Yacoucci who slowed down after the push turned out and still got some BMST award for speed compared to displacement.
    flyin-t, Stogy, dirty old man and 3 others like this.
  20. GMC BUBBA
    GMC BUBBA
    Best Bonneville story ever !!!!! Theres a reason a "record" is called a record!!!
  21. winduptoy
    winduptoy
  22. winduptoy
    winduptoy
  23. winduptoy
    winduptoy
  24. brett4christ
    brett4christ
  25. cmbrucew
    cmbrucew
    from Socal
    Maybe not good to post pictures of rental trucks on the salt.
    Just saying.
    Bruce
    LBCD, XXL__ and dirty old man like this.
  26. old flopper
    old flopper
    That’s good news to me, maybe get to run through 3 mile marker and have time to get engine up into power band in high gear. :cool:
  27. john mullen
    john mullen
    10 back on course 3
    Should run around1100
  28. old flopper
    old flopper
    Good info John,….Tell Dave to run it all way through end of 3 mile marker!.... Don’t know why but they didn’t even post your 2 mile speed in results from yesterday.
  29. Mr48chev
    Thanks John, I've been listening for the number of the Mustang ahead of it to be called so I could pay closer attention
  30. revkev6
    revkev6
    from ma
    I know this isn't a proper reply to what you guys are doing, but could you run this cl*** with a newer body truck with the old motor?? from my reading the PP cl*** isn't "cl***ic" so you could run something like a 96 f150 and drop that six into it and still be in the same cl***??
