Technical ***August 2018 Banger Meet - Banger Driving Weather***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 31, 2018.
  1. winduptoy
    winduptoy
    Been pushing it off by hand, yes, Danny put his hands on the trunk lid and pushed until I popped the clutch. What a real nice guy....had lunch with him today....just like one of the boys.
    Sent from my XT1254 using The H.A.M.B. mobile app
    surf10, Binger, Old Dawg and 3 others like this.
  2. winduptoy
    winduptoy
    Danny says it takes a whole team to start the two motors, first on alcohol, then when it's warm over to nitro. He said there are 47 fuel lines per motor.
    Binger, Old Dawg, Jet96 and 1 other person like this.
  3. Just returned from B'villle, absolutely the best it has been a a long time.
    The coupe made 1 p*** at 108 and just about fried #3 due to clogged injector. It will be back soon.
    The tank ran 174+ mile 3 with 178+ exit, personal best so far.
    Next run 155-ish, just laid over, lost compression on all four. Nothing in oil, valves all leaking like running toilet.
    Keep an eye out for the final results, it looks like a shootout between 5 top cars for the Fast time trophy.
    J
  4. callcoy
    callcoy
    Bonneville
    Returned yesterday, best salt in years, 2 long courses, one could be used for a short course. Plus a short course and a rookie for a total of four courses. Attendance was down, big mistake, at one time no one ran on course 1 for an hour.
    My daughter worked Impound, said it was full of cars starting Saturday on that exceeded a record, They had 4 hours only to fix or make adjustments, then wait to run first at 7AM the next morning.
    Saw Thompson run 457, setting the AA record, then Poteet and Main that had bad two days when they blew up their E engine, put in a B engine and ran 458 but not over the cl*** record. This ended Thompson's chance to score the Hot Rod Magazine trophy for the meets fastest speed. Danny is retiring the car and I was told he was't going to run it again. But hold the presses Vesco then ran his Turbinator and put down a 470 mph p*** before I had to leave.
    There were 7 pre registered bangers, I didn't see any make a p*** as our pit was off the #1 course. The only one I know set a record was Bill Lattin whose pit ajoined ours. He had Bantam 2 door with a banger overhead. I didn't run into John Neilson, did see that the Dodge Boys out of Montana had a pit but I could never make it over to see what they had.
    When the final results are published I will post any banger records.
  5. V4F
    V4F
    from middle ca.
    great ! im glad the salt was good this year . hope all had a great time !
  6. modelAsteve
    modelAsteve
    Callcoy- sorry we never got that picture- maybe next year! Good seeing you!
  7. callcoy
    callcoy
    Another should have - could have - would have! Appreciate the vintage ride, wish I could make a meeting, will be out for El Mirage in Nov. don't have Nelson's date in my head, may run down to see them tomorrow, got to plan Birthday Lunch. The door is always open, good touring roads and a few banger guys and etc.
  8. Binger
    Binger
    from wyoming
    Started the new motor tonight. A few more things to put together and a test drive tomorrow morning.
    Jet96, winduptoy, G Baese and 7 others like this.
  9. V4F
    V4F
    from middle ca.
    glad you got it done . looks good . should be fun !
    Binger likes this.
  10. Binger
    Binger
    from wyoming
    Thanks. I hope to be able to put 300-400 miles on it over the next couple of weeks. I am planning on driving it up to the hot rod hill climb in a month.
  11. My modernish pick up needs a starter so I've been commuting my coupe to work all week. It's only 4 miles but sure is a nice drive when I'm just banging along 31.jpg
    Jet96, Old Dawg, Binger and 4 others like this.
  12. V4F
    V4F
    from middle ca.
    very nice '31
    Tiny likes this.
  13.
  14. ^^That's ONE CLEAN BANGER!^^
    Binger likes this.
  15. JT1930
    JT1930
    Hey 4 bangers I have a question. Just got a new radiator in the car went with aluminum one. Anyway being a stock 4 banger should I still run a non-pressurized cooling system? Reason I ask is because the radiator I got came with a 16lb radiator cap on it. Thanks Joe
  16. Crazydaddyo
    Crazydaddyo
    I ran a 13 lb cap on mine for a while. Figured it might run too hot with a lower one. Switched to a 7 lb cap and didn't see a difference in temp. It still ran 145* @ 80* ambient temp. The biggest thing I noticed with the lower pressure cap was that I wasn't blowing head gaskets as much. Went to a 3 lb cap and still didn't see a significant increase in engine temp. Broke something in the drive train shortly after. Still sitting were I parked it 4 yeas ago
    Sent from my SM-J320P using The H.A.M.B. mobile app
    Dannerr and JT1930 like this.
  17. Crazydaddyo
    Crazydaddyo
    JT1930 likes this.
  18. JT1930
    JT1930
    Crazydaddyo. Thanks. I just saw a company that sells a pressurized radiator specifically for model a. They run a 4lb. I’ll see what happens on a test drive tomorrow.
    Dannerr likes this.
  19. V4F
    V4F
    from middle ca.
    im non-pressurized and never had a problem . just info
    Herb Kephart likes this.
  20. Herb Kephart
    Herb Kephart
    Same here. Even run 0 pounds in my "every day" Honda, and Ford truck with 7.3 Diesel "Course it's about 365 ASL here- but have gone 2500-3000 with no problem. Model A's were meant to run anywhere with NO pressure cooling.
    Herb
    barrnone50 and JT1930 like this.
  21. Street Is Neat
    Street Is Neat
    Napa sell a 7 lb
    JT1930 likes this.
  22. V4F
    V4F
    from middle ca.
    ere with NO pressure cooling .
    AMEN ……….………….
    Herb Kephart, JT1930 and barrnone50 like this.
  23. edfueler
    edfueler
    [​IMG] This year's Gresford mud run. Twin EJ Holden Stromberg single barrel carbs on a diamond block A. 4.11 diff with 6.00.17s on the rear We howled around the bullpen:)
    gas pumper, Jet96, Binger and 5 others like this.
  24. edfueler
    edfueler
    [​IMG]Home and hosed...complete with a trophy and all.
    Jet96, Binger, JT1930 and 4 others like this.
  25. V4F
    V4F
    from middle ca.
    are you seeking directions to the car wash ? ………. must be good fun
    edfueler likes this.
  26. Steve,
    Hosed means just that, hosed. Kind of like kids when young, washing involves soap.
    Looks like fun to me!!
    J
  27. Crazydaddyo
    Crazydaddyo
  28. V4F
    V4F
    from middle ca.
    john , yea ive been hosed b 4
  29. Herb Kephart
    Herb Kephart
    Hey Craze--First look I thought boring bar too short to go all the way thru-then I realized that it probably was that far already in the pix. Sorry for thinking that, because Jimmski told me you knew what you were doing. (and I'm not sure that I do---was just about to write something in that last sentence that for sure would be censored--and me in trouble.)
    Naughty Herb
  30. Crazydaddyo
    Crazydaddyo
    No problem Herb,
    That picture is of cutting the valve seats for inserts
    Dannerr likes this.
