Hot Rods Hot Rod Sports Cars
Discussion in 'The Hokey Ass Message Board' started by ghornbostel, Dec 27, 2014.
  1. loudbang
    It is pretty nice looking. I do not know what it is. :(
    1947knuck and enloe like this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    You asked; The little hatch is spairtire n tools,there was like a glove box in headrest/rollbar
    , Motor pic is with Bragz intake,front end ***m was from Triumph w/cross spring. I was so skinny WOW mid 1950s
  3. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Mr. Google says it's a one off that was built in Sweden patterned after a 1950s Ferrari.
    chriseakin, jimdillon, Deuces and 4 others like this.
  4. jebbesen
    jebbesen
    from Winona, MN
    @guffey please start a build thread on that car. That frame is the coolest thing I've seen in this whole thread. I'd love to see the engine sitting in the frame to better understand the layout. Those Alfin brake drums are awesome. Any more history as far as where the guy lived who built it or the year? From your Korean war comment I'm thinking early 50s? Red Ram power puts it at at least 1953. My Rocket powered car im working on was built between 53 and 54. https://www.jalopyjournal.com/forum/threads/1950s-tube-frame-sports-car.993579/
    chriseakin and loudbang like this.
  5. joeldriskill
    joeldriskill
    from Richmond
    I may have some info on those copper finned brakes for you. That is one wild ch***is, who was the builder and where was he from?
  6. loudbang
  7. joeldriskill
    joeldriskill
    from Richmond
    how were the front radius rods attached to the frame? Heim joints, tie rod ends?
  8. jebbesen
    jebbesen
    from Winona, MN
    Couldn't it still be early Ford cross steer like a 40 Ford box? It would still steer the same from the other side you'd just have to run the drag link to the left side. It would pull that side rather than pushing the right but still have the same effect on the front end. It looks like he mounted the box on the outside of the frame/bracket which would be the same as bolting it on the inside of the frame on the conventional left steer car. I might be way off. Just some thoughts.
    Atwater Mike, loudbang and guffey like this.
  9. wisdonm
    wisdonm
    Boy, did you luck out. There's plenty of thread left on those tires. [​IMG]
    slv63 and loudbang like this.
  10. foolthrottle
    foolthrottle
    Guffey
    I'm sure its not just me, I'm drooling over your car and then I see all this other crazy **** in the background of your pictures and I'm calling for a shop tour with pictures
  11. joeldriskill
    joeldriskill
    from Richmond
    So there are no ball joints at the radius rod attachment? I guess he used the rubber from the motor mounts as the flexure? This dude sure did things his own way, and I love it.
    Plus the brakes, I have found out a lot about a number of copper finned brakes that were made in that period, but these are different. They are literally just brazed to the iron drums, no tinning of copper around the drum first. I wonder if that would have worked?
  12. loudbang
    ***asination
    1947knuck, quick85, enloe and 5 others like this.
  13. loudbang
  14. movin/on
    movin/on
    Toying with the idea of putting a 427 Fe into a 1965 Volvo P1800. Bought 2 of them (a 65 and 66) both rust free 66VolvoLeftside.jpg from the local s****yard before they got crushed and started a search on putting a V-8 into one. Seems like Holman-Moody put a HiPo 289 into one with a stock body. It ended up without enough room in the drivers footbox for a clutch so an auto was installed.
    My solution (because I have 2) is to build a custom rectangular frame and stretch the body 6+ inches and then grafting two front sheetmetal fenders and hoods together. Narrowed Mustang II front suspension and then a Jag XKE rear axle. I do have all the suspension parts as well (this was a strategic purchase from the s****yard).
    Does anyone have a record or pictures of this type of swap?
    Thanks for any comments or thoughts.
    Movin/on
    AHotRod, scott27, Deuces and 2 others like this.
  15. jebbesen
    jebbesen
    from Winona, MN
    @movin/on
    You guys that live in places without crazy rust don't realize how lucky you are! Here in the Midwest any of those you'd find in the junkyard would be missing most of the car below the door handles! Lol
    Those P1800s are such awesome cars. I've seen V8 swaps but not a big block one before. Hope it all works out. I'm interested in seeing the body lines after you extend the hood. Looks possible. I'll be watching for updates.
    Deuces and loudbang like this.
  16. loudbang
  17. movin/on
    movin/on
    I did retire from SE Michigan in 2003 and cannot believe the rust free quality of 50's and 60's cars here, unless they are within 10 miles of the Pacific Coast (salt air)
    Movin/on
    jebbesen and loudbang like this.
  18. loudbang
    Strip Teaser II
    Lots of negative camber on the right front??
  19. Deuces
    Deuces
    How this be???? Took these this morning at Ford World Headquarters..... :cool: IMG_20180819_090753.jpg IMG_20180819_084015.jpg IMG_20180819_090838.jpg IMG_20180819_084034.jpg IMG_20180819_090737.jpg IMG_20180819_084116.jpg IMG_20180819_090804.jpg IMG_20180819_084132.jpg
    1947knuck, Offset, BAD ROD and 2 others like this.
  20. pirate
    pirate
    from Alabama
    Brunton Stalker 1962 Lotus Super 7 clone with 3.4 liter Chevy V6.
    1947knuck, Phillips, coneman and 5 others like this.
  21. loudbang
  22. tb33anda3rd
    tb33anda3rd
    ok, you got me......what is it?
  23. Offset
    Offset
    from Canada
    Cheetah. Nice.
  24. gnichols
    gnichols
    from Tampa, FL
    Also known as the fastest sauna bath on wheels. Gary
    Deuces, 64 DODGE 440 and loudbang like this.
  25. loudbang
  26. loudbang
  27. wisdonm
    wisdonm
    The car in reply #361 appears to be the same as the orange Cheetah. They are hot, and twitchy. Never lived up to their believed potential.
  28. rooman
    rooman
    The car in post # 361 is one of the original aluminum bodies Cheetahs and has some subtle differences from the orange car which may be one of the later fibergl*** units ( or even one of the more recent "continuation" cars).
    Roo
  29. loudbang
  30. ramblin dan
    ramblin dan
