Technical A Big Paint No No (I told you so)
Discussion in 'Traditional Customs' started by Paint Guru, Aug 17, 2018.
  1. Paint Guru
    Paint Guru
    from Bowdon, GA
    So we have been in the process of restoring my wife's 1961 Chrysler Imperial. The guy that is doing the majority of the work for me debated with me on how to paint the car. He wanted to paint the car apart so that the jambs do not have a tape line. I wanted the car jambed out first, ***embled then painted together with a good back tape job done in the jambs.
    Regardless if all the paint is in the same can, air pressure, spray technique can all change the color.
    I let him paint his way, and this week I helped ***emble the doors on the car.
    Well now we will be respraying the car Saturday the way I originally wanted it done. Just wanted to share with you guys if you have never seen this first hand. The paint on the door and fender is the exact same paint out of the same gallon can and sprayed the same day. Needless to say my last comment to him was, "I told you so." 20180816_093706.jpeg
    Sent from my SM-G955U using The H.A.M.B. mobile app
  2. BJR
    BJR
  3. john worden
    john worden
    from iowa
  4. revkev6
    revkev6
    from ma
    no first hand experience, but I've been told metallics are good for that, especially if the doors are layed flat or hung at a different angle from how they will be mounted. the flake flows out in a different pattern and that's the result. IF you wanted to do it his way, hang the doors upright.
    Blade58, jvo, dwollam and 6 others like this.
  5. Never would have believed it, same paint, same can, same day .
    ****s to be him but Atodaso
  6. You[emoji19]
    Him[emoji30]
    Its always fun doing something twice
    loudbang and Paint Guru like this.
  7. flatheadpete
    flatheadpete
    from Burton, MI
    Ya mean to tell me "Paint Guru" isn't just words? It actually means something? Huh.
  8. Paint Guru
    Paint Guru
    from Bowdon, GA
    The doors were upright, if I were to bet, it's a air pressure change, or pressure build up in the disposable cups, causing a pressure difference even if he was spraying the same air pressure. As the disposable cups collapse it reduces the amount of paint coming out.
  9. Dave Mc
    Dave Mc
    The Gravity Feed spray guns with the cup above allow the metallic to settle , must be emptied between coats , can also lead to spitting chunks if not thoroughly cleaned and strained between coats.
    Hamtown Al, 49ratfink and loudbang like this.
  10. Model A Gomez
    Model A Gomez
    I don't mind painting non-metallic in pieces but never metallic. Even on non-metallic you have to be careful on the number of coats or you can see a color difference.
  11. onetrickpony
    onetrickpony
    from Texas
    Even air temp and humidity can change the color. When I was mixing paint for a living, it was a never ending battle. Try to match a car sprayed in Detroit in January when you are in Texas in the summer.
    Blues4U, dwollam, loudbang and 2 others like this.
  12. Paint Guru
    Paint Guru
    from Bowdon, GA
    Yea when I teach a color match and blending cl***, I make them use 4 different spray out cards and spray each one at different air pressure, then give them 4 MORE, reduce the paint with faster reducer and 4 different air pressures and we end up with 8 different color. That's another reason why we say, "PANEL PAINT AT YOUR OWN RISK"
    Blues4U, KoolKat-57, dwollam and 3 others like this.
  13. squirrel
    I thought everyone knew that.
    (yes, I just sprayed some doors this morning, and expect them to look quite different than the rest of the car. But it's just an old race car so it don't matter)
    deadbeat, Paint Guru and dana barlow like this.
  14. Rich S.
    Rich S.
    To all of the above...Yep...Yep...Yep,Yep,Yep...Yep,Yep...Yep,Yep.Yep,Yep,Yep...YEP!
  15. loveoftiki
    loveoftiki
    from Livonia,Mi
    Lesson 1- don’t panel paint!!!!
    Lesson 2 - refer to lesson 1!
  16. Model A Gomez
    Model A Gomez
    I've done several Model A's and always paint them in pieces and they come out fairly close but can see a difference from different angles. Almost impossible to paint together but try to paint as many parts as possible each time such as doors, decklid, cowl and body shell at once. I did paint the top on My 60 T-Bird 2010 Ford Kona Blue separately but it had a 2" chrome piece where it meets the quarter panel.
      261.7 KB
      198.7 KB
    deadbeat and loudbang like this.
  17. badvolvo
    badvolvo
    I screwed one up like that myself. Too upset to redo so I've been driving it screwed up for 5 years. I will redo it next year when I get my current project done.
  18. When art meets science, sometimes art wins.
    "Itoad yaso." :eek:
    deadbeat, loudbang and Paint Guru like this.
  19. Bleach
    Bleach
    Who's eating the cost of the F-up?
  20. Paint Guru
    Paint Guru
    from Bowdon, GA
    I will. I don't mind he's a good guy, and I know he feels just as bad as I do about it, plus I will never let him forget about it either!
    And it's my wife's car, the only time she calculates cost is when it comes to my car, never hers.
  21. '51 Norm
    '51 Norm
    from colorado
    Thank you for sharing. I've found that the screw ups are where I learn the most.
  22. oldolds
    oldolds
    Some colors are better than others to spray in pieces. That light silvery blue color can be a ****** where you overlap paint at the end of a coat. Always a whole car and think about how you spray so that you are not spraying the last swipe of paint over something that was painted with the first swipe.
  23. belair
    belair
    Your posts are always useful. As a driveway painter, I really appreciate you willingness to share some hard-experience.
  24. Jalopy Joker
    Jalopy Joker
    "Mama said there'll be days like this" (Shirelles)
  25. tb33anda3rd
    tb33anda3rd
  26. Aaron63Nova
    Aaron63Nova
    Thank you for posting this. Going to attempt to spray my own truck eventually and did not want to learn this the hard way.
    Paint Guru and loudbang like this.
  27. BJR
    BJR
    Since you are the "Paint Guru" is there a reason you didn't spray it? Not trying to be an ***, just curious.
    papadaddio likes this.
  28. Paint Guru
    Paint Guru
    from Bowdon, GA
    I am a technical rep and my territory is from Virginia to Louisiana. So I am on the road every week. The guy doing the car, does only one car at a time and charges by the hour. I was out of town that whole week, I don't think it's fair for him to go without a weekly pay because of me being out of town and wanting to paint it. He did all the body work so if the paint job comes out great it's because of the prep work he did not really the painter.
    And to be honest I paint damn near every day, in hot *** paint booths in the South, so I don't mind a break from time to time, however I did want to paint my own car. But if I would have screwed it up I might not have told any of you lol.
  29. safetythird
    safetythird
    Paint Guru and tb33anda3rd like this.
  30. buffaloracer
    buffaloracer
    from kansas
    Thanks. It was a mistake that I was about to make.
    Pete
    Paint Guru likes this.
