Hot Rods Forming Brake Lines with NiCopp
Discussion in 'The Hokey Ass Message Board' started by kbuhagiar, Aug 17, 2018.
  1. kbuhagiar
    kbuhagiar
    I will be installing some new brake lines shortly on my 47 Plymouth. I have the tubing and all of my bending/flaring tubing tools ready, but this is the first time I've worked with a coil of NiCopp, as opposed to sticks of straight steel tubing.
    I'm big on neatness and appearance, so I'm concerned about how nice and straight a line I can achieve after un-coiling the NiCopp.
    Should I invest in a tubing straightener? Or is patience and determination enough to create a nice straight line out of NiCopp? I've got several other brake line projects lined up after this, so I wouldn't mind investing in a useful tool if it makes a difference.
    Thanks.
  2. sliceddeuce
    sliceddeuce
  3. Speedy Canuck
    Speedy Canuck
    I have seen guys use patience to get sections straight enough for never mind. Perfectly straight might be a bit subjective. I can say it's much easier to straighten than steel lines are.
    However, if you are a perfectionist, then a tubing straightener might be the right investment. I've also seen a couple of home built straightener units (including a hole drilled lengthways through a a 1' section of 2x4) that have worked with good/great results.
    My girlfriend does the same thing. I ask her an either/or question, and she responds with yes. :rolleyes:
  4. sliceddeuce
    sliceddeuce
    I like your girlfriend.
    kbuhagiar and VANDENPLAS like this.
  5. Blue One
    Blue One
    from Alberta
    Yes to the tubing straightener and also yes to some good quality benders like the Imperial lever type benders I have.
    Some random shots of my brake lines all done with ni cop.
    433F147D-DA8E-49CA-9BBD-D9DE632B59DE.jpeg C74A2A52-F0D1-4B26-A6F0-468FA322B4C3.jpeg CC4A5436-191B-42B7-8594-83220F8372AB.jpeg 5A8B0CD0-2737-4BC9-96E8-357FE6848473.jpeg 68A70FE4-4599-4746-99AF-DB1988E79623.jpeg C6846834-57E2-4EA1-824B-5259EA0AA15B.jpeg 5054D0B5-8EE1-4E43-8A16-84CFDA2C8E66.jpeg BC6EE92D-810E-4BEC-A194-2DF78C0CAC15.jpeg 1C9E116E-FB12-4733-B0A9-B59B0E2EA71A.jpeg 677883B5-2239-4BDC-8F95-20FDF494AC37.jpeg 719FFFA7-8B9C-480A-B9F3-7DFD98174C69.jpeg 3D7B7C1D-57F6-4618-BEB9-3CB0F41E69A3.jpeg 4F568F76-AA9A-47A1-BC89-3A399D337F83.jpeg
    Dino 64, dwollam, Texas Webb and 16 others like this.
  6. lothiandon1940
    lothiandon1940
    ^^^^^Nice work^^^
    scotty t, Slopok and seb fontana like this.
  7. man, I thought I did a good job with my tubing but now I know the truth....
    HunterYJ and Slopok like this.
  8. flatheadpete
    flatheadpete
    from Burton, MI
    Dang...That looks great!
  9. oldolds
    oldolds
    I usually uncoil the roll out on the floor first, it gets pretty straight. Just push it against the floor and unroll. The first and last little bit might not straighten out but the rest should be ok. It will twist because of it's own weigh as you put it on if you are not careful.
  10. Beanscoot
    Beanscoot
    Very nice tubing work. What is the source of the clamps?
    I ***ume the larger CuNi tube is for fuel?
  11. Who has a source or even better a part # for a quality straightener ?
  12. I've found that after straightening, keeping the tubing straight is the trick! It is so soft that any length over about 3 feet will bend from its own weight.
    46international likes this.
  13. hotrodA
    hotrodA
    I used it on my 32 but just bought straight lengths close to what I needed measuring from joints, fittings, etc. No straightening, only bending and flaring one end. Very minimal waste. Local parts store has every length (12-72") in several diameters. Also used it for fuel line.
    bct, dwollam, 54vicky and 1 other person like this.
  14. I've had good luck just rolling the coil of tubing out against the cement garage floor. It's better if you have a "helper" stand on the first little bit with soft soled sneakers while you work the roll.
    I'd be tempted to try that first before buyin' mo' 'quipment.
    lothiandon1940 likes this.
  15. LongT
    LongT
    It looks like some tight bends. Maybe NiCopp would work for my master cylinder/ x-member issue.
  16. Russco
    Russco
    from Central IL
    Kugel Komoonents has really nice stainless clamps.
  17. Slopok
    Slopok
    Eastwood had a nice one for not much money if I remember correctly.
    scotty t and lothiandon1940 like this.
  18. Happydaze
    Happydaze
    I've heard of folks rolling pieces between two pieces of plywood to straighten it, but not tried it myself.
    I've found it can be straightened pretty well just by hand (if it's not too long and unmanageable) but when I've wanted it as straight as possible I've very gently squeezed it in a bench vice with the flexible, urethane jaw covers installed, section by section.
    Chris
  19. Blue One
    Blue One
    from Alberta
    Thanks, they’re called T clamps from Made for you products.
    Really nice product. I used them all over my ch***is for everything from the brake lines to the battery cable.
    https://www.made4youproducts.com/t-clamp
    Yes, the 3/8 ni cop is my fuel line.
    I also used 5/16” ni cop to plumb my carbs.
    8590B818-29E4-4EE9-AFB7-A239C0593C70.jpeg 50DD9F47-2F11-48DD-AE19-E9603E8CE318.jpeg 767570EC-DDA0-42E3-AAFB-5FDF3C314EA5.jpeg DC36EAE4-81F1-4C09-B4FF-594CA6877D15.jpeg
  20. Rich S.
    Rich S.
    Rigid makes some really nice benders, they have little mandrels and you can bend 180 without any flat spots. It has a little tab at the bottom so you can mount in vice, which I like. But they are a little pricey. I use a straightener IMG_1975.JPG IMG_1977.JPG
    Hightone111 likes this.
  21. Mike Colemire
    Mike Colemire
    Very nice work and engine Blue One. I'd like to have a fuel block like that for 2 4 barrels.
  22. Blues4U
    Blues4U
    from So Cal
    What did you use to secure the lines to the frame?
    32SEDAN likes this.
  23. Mr48chev
    Damn I was going to accuse Blue one of showing off with that beautiful work but the rest of you raise the bar just as high or higher.
    It would take two hours to dig out all of the tube benders I have out of their hiding places in that little garage and most of them don't get the job done the way I want it done. That's the first thing, cheap tube benders are a waste of money if you want a nice job.
    I don't know what parts house that HotrodA goes to but they don't have short lengths of that good stuff here, all they have is that green (i think it is green) coated **** that kinks as often as it bends.
    Rich S does that Rigid bender have a number on it? I think my tool box needs one of those.
    I have the Eastwood 25304 flair tool and it makes life so much easier when it comes to getting good flairs compared to my old SnapOn that is probably so worn out anyhow. I have had it since the early 70's and have done hundreds of flairs with it but it is pretty tired.
    On the original question, I have several rolls of tubing in the garage but haven't bought or made a tube straightener. I was thinking about buying some inexpensive pulleys at the Hardware store and using the sheaves to make my own straightener but would have to balance the cost against buying one.
  24. kbuhagiar
    kbuhagiar
    Thanks for the replies.
    I've decided to go ahead and purchase a tubing straightener. I'm sure I'll get a lot of use out of it.
    Hope my results are as nice as Blue One's.
  25. swade41
    swade41
    from Buffalo,NY
    You can make your own straightener using a piece of wood and sliding patio gl*** door wheels in the configuration shown above.
    You can also use common things like water pump pulleys to bend around, just take your time and use your imagination. Screenshot_20180817-232508_Facebook.jpg Screenshot_20180817-230853_Photobucket.jpg
    TagMan, Blues4U and Rich S. like this.
  26. Blue One
    Blue One
    from Alberta
    I used T clamps from Made for you products.
    They’re mounted in the ch***is using the 10/32 stainless steel machine screws they come with going into 10/32 Rivnuts installed in the frame.
    Blues4U likes this.
  27. Rich S.
    Rich S.
    It’s Rigid 600 series. They make about 6 different sizes. If you google Rigid 600 series tube bender you will see different suppliers (that was stainless that I showed in the pic)
  28. Blue One
    Blue One
    from Alberta
    Rigid makes some very nice benders however for the smaller tubing I have developed a preference over the years for the Imperial benders.
    They offer a lever style bender for 1/8” tubing if you need it.
    Bend radius.
    In the 3/16” tubing size the Imperial bender bends to a tighter radius (7/16”) than the Rigid (5/8”).
    Imperial benders will also bend 180 degrees.
    Next is cost , Imperial benders can be found for less $ in most cases than the Rigid ones and the Imperial benders are by no means lesser quality.
    Rich S. likes this.
  29. Rich S.
    Rich S.
    I agree with you on the smaller tubing. I like the Rigid for 5/16, 3/8 and 1/2 AC lines and as I said they are pricey
  30. bobss396
    bobss396
    I'm a freak when it comes to things like brake lines... they have to look perfect. I used NAPA steel lines on my Ford, this is what I know for many years. I do have a bad flare on one of my lines at the master that has a real small leak... annoying. I'm going to give the copper stuff a go.
