'32 Roadster top pics needed
Discussion in 'The Hokey Ass Message Board' started by bardahl1, Nov 9, 2006.
  1. bardahl1
    bardahl1
    I am building a traditional style bow top for my roadster (car is sort of early 50's style). I cut the windshild down by eye, something like a 3 3/8 chop and laid it back an inch. I bought a stock repop top kit from LeBaron Bonney and fabricated the bows and frame down to fit (sectioned everywhere). Now that the bows and frame are done I have a local buddy that has a trim shop and speacializes in convertable tops and will be doing the material. The problem is that he's a shoebox/muscle car guy and doesn't really know the details of how roadster tops were done, especially in a traditional way. Although I have an idea I'm not even sure myself so I'd like to get some pics, especially up close, detailed, and inside for reference. Any help would be greatly appreciated!
  2. Bruce Lancaster
    Bruce Lancaster
    This is '31 info, not '32, but most things are done about the same way:
    http://www.abarnyard.com/roadster/roadster.shtml
    Scroll down to the "details" section, top in and out.
    Stock '32 tops have LOTS of little details and tricks in the construction of the cloth parts, like the way back window can be swung up, pads, flaps, etc. You really need to find a complete roadster to look over! It's possible that best way might be to buy the top cover and pad kit and just have your guy rip out the seams and use it as raw material to be adjusted.
  3. Roadsters.com
    Roadsters.com
    Here's the top that **** Rodwell came up with to go with his curved-gl*** windshields for '32 roadsters. The tops and the windshields are described on http://www.roadsters.com/rodwell/
    I like the lines of these tops. I've asked him to also build tops for '32s with stock-style windshields, and he will someday.
    Dave
  4. 32 top set up for 2" chop.
    Sitting temporarily on a 31 roadster to check fit, so don't be confused.
    Mel Bergman likes this.
  5. hotrodA
    hotrodA
    I just finished installing a LB 32 top on my 31 roadster with a 3" chop and forward rake:D
    PM your e-mail address and I can send some pics. They're too large to post on here, and I'm too ignorant to reduce them.:eek:
    Did LB not send the instruction sheet with the top? If I can do it with no prior experience, your buddy should breeze on with it. It's basically 7 major pieces that have to go on in a specific sequence.
    One tip: use a pneumatic stapler instead of the tacks.
  6. Bruce Lancaster
    Bruce Lancaster
    The details I mentioned are mostly nifty but not necessary. What is necessary is to get the padding right. I've seen streetrods with no or badly done pads, and they have the cl***y look of a sack of potatos.
  7. Did you use 32 top irons?
    Looks to me like sectioning 2" out of the single horizontal bar that connects to the windshield post would do it.
    Sent the pics to me, I'll resize and post.
    C9Mach@msn.com
  8. av8
    av8
    Nice early '50 shape and proportions with a 3-inch chop . . .
  9. hotrodA
    hotrodA
    Thanks! If i have the file here at work, otherwise tonight from the house.
    I used the 31 irons. Unfortunately the 32 irons were a little different and the 32 top leaves a brace exposed, but to the unwashed it isn't obtrusive. I cut 3" off the main irons where they mount to the body for the height, and about 2" off the horiz side bars that rivet to the cast corner pieces for the rake. I also lowered the #2 bow some, and this required recontouring the short pieces that it attaches to.
    New top on an old car, but I got tired of battling the elements after 10 years.
  10. Here's the pics from hotrodA.
  11. I need one of those Rodwell tops. Tired of getting rained on. Gotta save some cash before getting drowned again. IMG_0621.JPG
    hiboyroadsterboy likes this.
  12. This is mine with a 2" chop and modified irons and bows.
    It folds down like a stock 32.
    a boner likes this.
  13. krylon32
    krylon32
    from Nebraska
    When I did my last top I did the irons and bows to the shape I wanted and took the trimmer top pictures of the Veda Orr roadster and the Bob McGee Roadster. He used them as to get an idea of the details I wanted.
  14. CheatersPete
    CheatersPete
  15. V.Stella
    V.Stella
    Love it!
    11 years and still perfect!
  16. webb1932
    webb1932
    I
    Sorry, but the top I have is for a Rodwell windshield which is not only laid back but has. a curve in it. A stock style windshield will not work.
