Projects My "You didn't build that" 27 T Roadster build thread
Discussion in 'The Hokey Ass Message Board' started by daddio211, Sep 13, 2012.
  1. daddio211
    daddio211
    Hit send before I was ready, LOL. That would be amazing if you guys brought the T! Looking forward to seeing you two again.
    Sent from my SM-G955U1 using The H.A.M.B. mobile app
    loudbang and 26 T Ford RPU like this.
  2. Dick Stevens
    Dick Stevens
    Sleep is overrated! :D:rolleyes::D
    daddio211 and loudbang like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Will be great to see Victoria's Roadster at the LARS next summer complete with interior. We will be bringing the T over in 2-3 years, just need to tie up some loose ends here first and all going to plan we are looking forward to catching up with you guys too next June. :cool::cool::D JW
  4. atch
    atch
  5. 26 T Ford RPU
    26 T Ford RPU
    I spoke with Eric just over a month ago and there is nothing to report on as he is very busy and with work and family, so hopefully soon as I hope for a ride in the roadster next June.:cool::cool::) JW
    daddio211, loudbang and Outback like this.
  6. daddio211
    daddio211
    Hey fellas, I apologize for not checking in. Work and family, plus another venture have kept me ridiculously busy. I hadn't touched the car in MONTHS but finally got time and motivation to start cranking on it again.
    I've been getting something done on nearly a daily basis now and my checklist is very short. Fingers crossed, itll be at the Hot Rod Hill Climb in Colorado in a few weeks.
    Sent from my SM-N960U using The H.A.M.B. mobile app
    kidcampbell71, OFT, JOYFLEA and 4 others like this.
  7. Blue One
    Blue One
    from Alberta
    And as usual we will require photo evidence of this activity ;) :D
    SR100 and Kroombit like this.
  8. daddio211
    daddio211
    Ha! Well, the car was so far along with just details left to do that it really doesn't look much different.
    And because my 19 year old son is a **** and just bought a truck he thought he'd be cool...
    Things checked off of the list in the past two weeks:
    Finish wiring harness (mount fuse box, install voltage regulator)
    Mount battery box
    Terminate power cables
    Rewire generator (did it wrong the first time)
    Tie up all loose grounds (tie into grounding bus)
    Radiator overflow tube
    Fuel tank vent
    Wire speedometer to transmission
    Finish tach wiring
    Seat belts
    Fusible link
    Oil in
    Trans fluid in
    Things left to do:
    Connect throttle linkage
    Connect trans kickdown
    Fill radiator
    Fill rear end (not feel)
    Locate TDC, set distributor, wire cap
    Connect cooling fan override switch worh relay
    New ignition switch (ordered from So Cal, lost the key somewhere)
    New headlight switch (ordered from So Cal, lost the shaft and knob somewhere)
    Add brake fluid, bleed, adjust brakes
    Install torque converter override (ordered, should arrive tomorrow)
    Test electrical
    Connect horn ****on (ordered from So Cal)
    Put on Corvette valve covers.
    Nut and bolt ch***is
    Fuel
    Fire and test drive(s)
    Sure wish you guys lived near me, I'd love to have a hand getting these last items knocked out!
  9. 26 T Ford RPU
    26 T Ford RPU
    Very, very cool to see things moving along again and I would love to pop up and give a hand but I must the further most away, keep up the momentum. :cool::cool: :D JW
    AndersF and daddio211 like this.
  10. daddio211
    daddio211
    Another item off the list, filled the rear end tonight. I'd forgotten how long it takes to pour 80/90 in a funnel, down a tube, and into a rear diff.
    And this is why I used to buy quart squeeze bottles!
    AndersF and 26 T Ford RPU like this.
  11. AndersF
    AndersF
    Nice to see some progress again.
    I hold my thoumbs that you find the time get it on road now.
    daddio211 and 26 T Ford RPU like this.
  12. JOYFLEA
    JOYFLEA
    Great to have you back . The sun really sets off the paint .
    daddio211 and Outback like this.
  13. daddio211
    daddio211
    Been fighting a flu bug all week and I must concede, there's no way I'm making the Hot Rod Hill Climb. Funny though, I actually thought I had another week!
    I knew when I set the goal it was a tough deadline, but I had to set a goal of some sort. Regardless, I got a huge jump on the small things to get the car closer to completion.
    Speedway and So Cal parts arrived this morning but I haven't felt good enough to venture out to the garage. Hopefully I'll feel better tomorrow and get stuff done.
    Outback and 26 T Ford RPU like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    That's a bugga !! wish I could lend a hand to get ya going:cool::cool::D JW
    Here's a wee teaser, myself chasing Mandy in the Mustang.......
    OFT, daddio211 and AndersF like this.
  15. daddio211
    daddio211
    I know you would Jeremy, and thank you! So glad that Mustang worked out well for you two.
    Feeling a bit better this morning. Walked out to a large puddle of 80/90 on the garage floor... ugh. Guess the list is getting longer instead of shorter.
    26 T Ford RPU likes this.
  16. daddio211
    daddio211
  17. KJSR
    KJSR
    from Utah
    daddio211 likes this.
  18. daddio211
    daddio211
    It's the pinion seal. Can't get one today so I'll move on to other things.
    26 T Ford RPU and OFT like this.
  19. Dammit! I was hoping to see it at the Hill Climb! Feel better!
    Outback and daddio211 like this.
  20. 26 T Ford RPU
    26 T Ford RPU
    Glad you are feeling better but dang that's a bad leak, would need to be missing or the wrong one to leak that bad. Hope its an easy fix. Even if its the seal, I cant see how that much oil came out. JW
    brad2v and daddio211 like this.
  21. daddio211
    daddio211
    Thanks brother, take lots of pics for us!
    26 T Ford RPU and cactus1 like this.
  22. daddio211
    daddio211
    Yeah, it HAS to be the wrong seal for sure.
  23. daddio211
    daddio211
    My dilemma this past week...
    Just couldn't scab it together at this point.
    pennafxu, Outback, brEad and 3 others like this.
  24. 26 T Ford RPU
    26 T Ford RPU
    Thats the best way I have seen that described. :cool: Do you have a new deadline or just as soon as it happens? JW
  25. daddio211
    daddio211
    I kind of burned out again yesterday. I have to go to Las Vegas on Friday so I'll see if I can pick up the correct light switch from So Cal Speed Shop.
    I'll to chip away at it each night this week though, but no definite plans just yet.
  26. 26 T Ford RPU
    26 T Ford RPU
    I have had so many hopeful deadlines for shows etc p*** by with the RPU over the years and I know how it feels.
    Are you going to have hood lacing on the cowl and radiator surround? This is how mine turned out, just an idea, I bonded it on with Urethane.
    Hope you are back to a 100% soon, Eric. JW
  27. daddio211
    daddio211
    I sure am. Even if I don't build a hood for it the lacing looks right.
    Plus, the cowl turned out too smooth, kind of street roddy. It needs something to break it up a bit.
    IG: roundsixeric
    FB: daddio211
    brEad and 26 T Ford RPU like this.
  28. daddio211
    daddio211
    Been in the driveway the majority of the day. I shot a quick video but the HAMB won't let me upload it.
    Mostly working today and troubleshooting things I did more than a year ago. Chasing wires, trying to remember where I left off and why I didn't finish certain items.
    Hooked everything up and hit my electrical disconnect, fire extinguisher in hand. No smoke, but no voltage. Whoops, fusible link not connected at the starter.
    Try again... still no smoke, still no voltage. Tracing wires I realized I never connected the link back into the fuse panel. I think I did it with the intent of connecting it last.
    Try #3, no smoke and now we have voltage. Ignition switch works, horn works, headlights work, blinkers work, stereo works. Wired up the electric fan override, now it works. Only thing not working is the rear taillights. I'll sort that out next. List is getting super short. Still have to figure out the pinion seal.
    Time to take a break and get ready to work again tomorrow. I've been working 14-16 hour days recently and it's been kicking my ****. Nice to get some time with the roadster and my family!
    IG: roundsixeric
    FB: daddio211
    pennafxu, patmanta, JOYFLEA and 6 others like this.
  29. daddio211
    daddio211
    JOYFLEA likes this.
  30. loudbang
    Can't watch, must be signed in
