Projects Stainless Firewall edges
Discussion in 'The Hokey Ass Message Board' started by swade41, Aug 22, 2018.
  1. swade41
    swade41
    from Buffalo,NY
    I have cut my 22ga stainless out using a jigsaw, what's good for cleaning up the edges ? The edge cuts sandpaper like a razor blade so I've been using a hand file but there must be something better out there that's readily available. Hell I'm ready to try a sharpening stone for my knife, this is some hard stuff.
    20180817_145858.jpg 20180813_172316.jpg 20180814_181944.jpg 20180817_175405.jpg
    AHotRod and kidcampbell71 like this.
  2. swade41
    swade41
    from Buffalo,NY
  3. manyolcars
    manyolcars
  4. swade41
    swade41
    from Buffalo,NY
    I have some for the 4 1/2 inch grinder, I thought it might leave a wavy edge.
  5. It is hard to do but a nice file will do the best job .
  6. If you don't want to be at it for hours, do what I do...
    Clamp a piece angle iron along the straight edges, with just what you want to remove protruding. Hit it with a 4.5" 400 grit sanding disc (NOT a flapper wheel) until you just hit the angle, using the angle as your 'guide'. Grind 'into' the angle, not 'away' from it. I'll touch it with a file for any high spots or burrs before unclamping the angle. You'll have to free-hand any curved parts, I use a 2" roloc 360 grit sanding disc in a angle die grinder.
    One piece of angle should be enough to do your firewall. Eventually it gets curves/low spots no matter how careful you are...
    millersgarage likes this.
  7. Bob Labla
    Bob Labla
    from mitten
  8. oldolds
    oldolds
    Roll the edge with a beading machine.
    Rich S. likes this.
  9. alchemy
    alchemy
    I'd use a fine file on that and be done in 15 minutes. Maybe some sandpaper on the edge to soften it a bit after filing.
  10. ol-nobull
    ol-nobull
    Hi. there is a cut edge cleaning tool avalible from most tool outlets that has a screw driver handle and the shaft spins free. At end of shave there is a V that is hardened cutting steel. Just put it on the cut edge and make 3 or 4 p***es by hand and the sharp edge is gone. Used them for years as an industrial electrician when we fabricated panels.
    It is out in my tool box from work from back when I retired & if you need a photo I will go dig it out and post.
    Jimmie
    Bandit Billy likes this.
  11. swade41
    swade41
    from Buffalo,NY
    You better get over here and get busy then..hahaha
  12. Atwater Mike
    Atwater Mike
    I have a friend with that tool, first time I ever saw one. Amazing, the job it does...
  13. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Buy one and you'll never be without one.
  14. bobss396
    bobss396
    I would sandwich it between a couple of pieces of sacrificial steel bar stock with just enough sticking out and hit it with a DA sander. 22 AWG... should make friends with a cat that has a nice shear.
  15. I’d use my electric finger sander with the sheet material clamped down well
  16. sunbeam
    sunbeam
  17. Fordors
    Fordors
    EEFB7318-6110-4706-BD76-2618C8B1A86D.jpeg FF6A60B5-8AFF-4B63-9CB7-DAE83494F105.jpeg 8ECA4630-07F0-435A-B7C4-0DBF115ACD59.jpeg
    Like this? It works good for the edge where the top surface meets the side but I think the OP is concerned with the side of the 22ga. thickness, not just the edge.
    saltflats, Stogy and Wrench666 like this.
  18. AHotRod
    AHotRod
    What jig saw blades did you use?
    How many did you go through to get the job done?
    I have some polished stainless to cut and have been pondering on what to use to do it with since it is all curves.
  19. Wrench666
    Wrench666
  20. 1940Willys
    1940Willys
    The deburring tool posted does work well on certain materials, Philip. There are various tip configurations available for differant applications. Do be careful, I have seen several experienced machinists lacerated
  21. swade41
    swade41
    from Buffalo,NY
    Honestly just one blade to cut the perimeter, but the teeth seemed to catch every once in a while yanking the metal edge up. Now of course that made me nervous of bending that shiny finish.
    I also had duct taped the bottom of the jig saw to prevent it from marking the finish but make sure you dont get a metal shaving hung up under it.
    When I cut out the center I bought some cheap harbor freight carbide grit blades, it didn't hang up like the regular blade but it did cut a little wider, again using only one blade.
    AHotRod likes this.
  22. bobss396
    bobss396
    The tips have a little ball at the top. I have ground them off for special cases and you have to be ultra careful with it.
  23. swade41
    swade41
    from Buffalo,NY
    I ended up using a worn down disc freehand and it worked perfectly, didn't remove to much to fast. 20180922_172303.jpg
    AHotRod likes this.
  24. TagMan
    TagMan
    Another good reason to never throw anything away, Phil :D
    Glad you found a good way to get it done.
  25. verde742
    verde742
    the de-burring tool is great for de-burring conduit after the cut off,
    so you don't skin the wire when pulling it thru.
