Technical 12 volt conversion
Discussion in 'Traditional Hot Rods' started by sstock...not, Aug 22, 2018.
  1. sstock...not
    sstock...not
    from boston
    Hello all. I have a stock 1935 ford 5w coupe that I want to convert to 12 volts. Where do I start? I tried doing a search but I'm doing something wrong as I can not come up with anything. Any help will be appreciated.
    Butch
  2. Krash
    Krash
    from Cleveland
    sstock...not likes this.
  3. 19Fordy
    19Fordy
    The go over to Fordbarn and do a search.
    czuch and sstock...not like this.
  4. A good place to start is to examine if you are doing the conversion for the right reasons. Why are you changing?
    Charlie Stephens
  5. WiredSpider
    WiredSpider
    55-62 Ford regulator.
    12 volt field winding for the generator
    12 Volt coil
    bulbs,battery etc etc
    I get the regulator from Napa and the field windings from C and G in San Diego
    rfraze and sstock...not like this.
  6. sstock...not
    sstock...not
    from boston
    Thank you for your suggestions.
    I believe I can have brighter headlights, taillights and brake lights if the car had 12 volts . It would also be nice to have a radio for cruising. More options for a radio or music in general. Of course this will all be hidden. Bluetooth perhaps. I also have a 40 coupe that the previous owner converted to 12 volts and the starter definitely spins faster and helps the engine fire up quicker.
  7. I can get behind the brighter lights. When you get to the headlights be sure to get the "Brite" (their spelling) bulbs from Ron Francis Wire works, https://www.ronfrancis.com. With the proper size cables and a good starter you shouldn't have and problem with the 6 volt system. How about some pictures of your car?
    Charlie Stephens
  8. sstock...not
    sstock...not
    from boston
    Thanks again for everyone's suggestions. 20180823_073107.jpeg 20180823_073026.jpeg
    Sent from my SM-G955U using The H.A.M.B. mobile app
  9. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Nice bunch of cars! You are a lucky man. How do you keep a shop so un-cluttered?
    warhorseracing likes this.
  10. wheeldog57
    wheeldog57
  11. warhorseracing
    warhorseracing
    from cameron wv
    Looks like they are all completed roadworthy cars:eek:, unlike mine:D.
  12. sstock...not
    sstock...not
    from boston
    Texas Webb likes this.
  13. sstock...not
    sstock...not
    from boston
    Yup. West Rox
  14. aircap
    aircap
    Thumbs up on this. Randy rules.
  15. dirt t
    dirt t
    I used his book. Recomend it.
  16. Oldschool Rodder 62
    Oldschool Rodder 62
    I use a gm 1 wire alt. 12v coil some runtz resistors for the gauges and changed the head and tail lights on a 40 2dr and a 47 ford vert. this summer. All's well so far.
