Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. UNSHINED 2
    UNSHINED 2
    Gotta pay attention to detail....;)
    CudaChick1968 and Max Gearhead like this.
  2. Made some hood straps for the hood I made recently. Then I made some hood sides using offcuts from the hood and louvre panels from a DIY store that cost about $3 US
    bob b., CudaChick1968, Jet96 and 5 others like this.
  3. 62rebel
    62rebel
    Not bad, not bad
  4. CudaChick1968
    CudaChick1968
    This old beastie is cleaning up better than I hoped. I had a few pinholes -- of course in the top -- that needed some filler so it's setting up now. I was hoping to get it into powder today but the filler needs to set up and I'll outgas it again first. Both my customer and I have high expectations for it! << prayin' to the Powder Gods >> :D
    Before ... wow, that's full up isn't it?
    LAROKE, j-jock, David Gersic and 2 others like this.
  5. bobss396
    bobss396
    I have to dive into why my electric fan is not working, a nice Spal kit with the works I put in last year. I was waiting to get into a cruise (place was jammed...) and the fan never went on, should come on at 195 and it worked last week. Fuse (30 amp) at the battery looked intact.
    I mean, what the hell. Build a car with the best parts, my skills are good, I cut no corners and its one thing after another..
    CudaChick1968 likes this.
  6. junkyardjeff
    junkyardjeff
    Removed the front of a 351-W to replace a sloppy timing chain and took a hammer to the stuck distributor to get it out.
  7. David Gersic
    David Gersic
    from DeKalb, IL
    Last weekend I finished replacing the leaking water pump. That took longer than I expected for a simple SBC water pump, because I had to discover that it’s a 74 block with a 68-70 Corvette “short” pump on it. With less than 1/4” clearance, nothing else will fit.
    Moved the car afterward, and found an oil drip by the left rear wheel. So today I guess I’m going to start replacing the axle seals.
  8. 56don
    56don
    Took a drive around my yard in my 48 Ford coupe I bought a couple of months ago. Finally got it to run and yard drive. Now to tune it up. It sat for years and has taken me 2 months to replace brakes fuel system and ignition. Did you guys realize you can't buy anything for old cars local anymore? Have to order everything and wait and wait.
  9. David Gersic
    David Gersic
    from DeKalb, IL
    Yep. Had to order brake shoes this morning. NAPA. Coming from Tennessee, should be here Tuesday or Wednesday. Had to order the water pump two weeks ago. Even v belts are getting hard to get, almost had to order those too.
    Took three tries to find somebody that could turn drums.
    Atwater Mike and CudaChick1968 like this.
  10. 56don
    56don
    I don't know about your area, but here O'Reilly Autoparts now turns drums.
  11. David Gersic
    David Gersic
    from DeKalb, IL
    Good to know, but we don’t have one of those here.
    NAPA used to, but got out of it and sold their lathe to Jesus Auto in what locals refer to as “little Mexico”. Tried him, but he decided it wasn’t making enough money to justify the space, so sold it to a friend in Chicago. But, three doors down, Pedro has a lathe, and 30 minutes and $20 later, they’re turned and good to go.
    My other local chain stores are Advance and AutoZone.
  12. Jet96
    Jet96
    from WY
    Local show on a beauty day! A0CCDA29-A1A4-4DC7-BD47-B5CD3ABD04E5.jpeg 3D319992-72CE-4D82-9F76-3A58FFF52198.jpeg 935418B8-E121-4C40-8B82-A4D88288D30C.jpeg 32F9428E-D84D-43D1-8FA6-4A0311A10F48.jpeg BED99EE9-EA14-4BD2-9124-976171D52A81.jpeg
  13. 2bubbas
    2bubbas
    Meet up with Old 27 Tour in Cheboygan MI this evening-[/ATTACH]
  14. Jet96
    Jet96
    from WY
  15. bobss396
    bobss396
    This was the culprit in my electric fan saga... I had a shrink sleeve splice in it and one side had let loose. Replaced it with a crimp connector and sleeved it.
    swade41, CudaChick1968 and UNSHINED 2 like this.
  16. lumpy 63
    lumpy 63
    Worked all day on a 6.0 LS engine being built for drag week with a procharger, Yep I know its off topic but gotta pay for my old **** one way or another...:rolleyes: If it makes anybody feel better its going in an off topic 65 mustang:D
  17. I patched a hole in my steel '29 AA right front fender. A friend and mentor told me it wasn't worth the time and effort, and he is right, but I needed the practice. I'm learning. Afterward, I treated myself to a trip to our nearest big town for Cruise Night.
  18. saltflats
    saltflats
    from Missouri
    Took on a project.
    Should be easy enough.......right?
    Making the world a better place, one W engine at a time.:D
    Chavezk21, 2bubbas, lumpy 63 and 5 others like this.
  19. Tell me about it... Replacement parts that don’t fit or solve the problem, mystery faults... Makes you wonder why we don’t all buy new cars.
  20. David Gersic
    David Gersic
    from DeKalb, IL
    ‘Cause the new ones have the same problem, but it’s harder to fix? My father in law has a fancy Caddy with all electronic dash that randomly goes blank. Turn the car off, back on, it starts working again. It’s going to take a lot more than a test light to figure that out.
  21. swade41
    swade41
    from Buffalo,NY
    Sped my blower up an additional 4%, fixin to fire it up now and check the belt. 20180825_194557.jpg
  22. junkyardjeff
    junkyardjeff
    Got the engine back togather in the F100 and gave it a bath and first real drive.
  23. 56don
    56don
    Where did you get those neat br*** battery clamps?
  24. David Gersic
    David Gersic
    from DeKalb, IL
    56don likes this.
  25. David Gersic, Drove 550 miles home from the Frog Follies, stopped for ice cream at the Culvers at the Dekalb- Rochelle exit. Long hot drive with no AC!
  26. Boneyard51
    Boneyard51
    1B7B3172-184D-4777-B569-6F60497D7B4C.jpeg Went to an auction near me, missed a lot of good deals, but bought this American made blast cabinet for $30, with foot valve and dryer.
    Saw a 1940 Chevy two door coupe,project, with a perfect six and totally rebuilt drive train, suspension and body fixed only needed put together, a pile of new parts and an addition twenty foot trailer packed full of Old Chevy parts go for $1900.
    Bones
  27. David Gersic
    David Gersic
    from DeKalb, IL
    Nice. I should do Frog Follies again.
  28. UNSHINED 2
    UNSHINED 2
    Have been away getting a H. S. Grad/Boot Camp Going away party ready for the boy.
    Able to get back to it today....engine and transmission are set in place to check for last fits of headers, clutch linkages, etc. Ready to bolt it in for good tomorrow!!! 20180828_122357.jpg 20180828_122338.jpg 20180828_122312.jpg
  29. What are you doing for the rear ****** mounts? Is it a stick and you are using the bell housing with the mounts, or did you make something? The reason I ask, is that my son and I are putting a 400 sb with a 700r4 in a 47 International, and although I have the mid engine mounts cut and ready to weld and the rear crossmember built, it isn't too late to change the setup to get more room on the left side.
    Bob
    UNSHINED 2 likes this.
  30. UNSHINED 2
    UNSHINED 2
    Stock Y-block and stock 3 speed trans with a old style Spark-O-Matik floor shifter.
    Bolt-in affair for me.....
