1952-59 Ford gas tank
Discussion in 'Off Topic Hot Rods & Customs' started by 54shoebox, Aug 21, 2018.
  1. 54shoebox
    54shoebox
    was told a 55 gas tank will work in my 54 mainline. how do i go about making the filler neck work?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. 54shoebox
    54shoebox
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. 54shoebox
    54shoebox
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Look under the car towards the front there are bolts that go into the straps longer bolts will probably work for you. The fuel lines are 5/16" the old ones can get gunked up from sitting so should be replaced.
  7. 54vicky
    54vicky
    if replacing the gas line you will need to do so in two pieces as factory was run before body was set on frame.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    I used two metal brake lines from Autozone 5/16" X 6' you will need a union and some adapter fittings too.
    54vicky likes this.
  9. 54shoebox
    54shoebox
    so i will cut into that 6' and union it somewhere along the frame?
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    You need an adapter fitting from the tank to the 6' new line then a union to the second 6' line from there it's on to the fuel pump which will require some adapter fittings. The new 6' lines have flared fittings on both ends. Autozone's part number is PAX-572
  11. 56longroof
    56longroof
    If you cut the lines flare the ends and use the union to connect. Compression fittings are ok but not a ideal fix.
