Technical God help me im sooo lost
Discussion in 'The Hokey Ass Message Board' started by Trace jarvis, Aug 22, 2018.
  1. 41rodderz
    41rodderz
    from Oregon
    I was wondering if he has longer plugs in it? Maybe needs short ones.
  2. Guess that depends on his heads and how hard it is to turn with the plugs in depends on compression.
  3. sunbeam
    sunbeam
    Don't hook up the plug wires and see how it cranks with the plugs in.
    porknbeaner likes this.
  4. sliceddeuce
    sliceddeuce
    Indeed......I use it daily to feel better about myself.:)
  5. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    I wonder if there is a balancer/timing mark mismatch? That could throw the timing off quite a few degrees as chevy used at least 3 different timing mark indicators over the years.
  6. Fordors
    Fordors
    Too much initial could cause it to turn over slowly, or even kick back and break the starter but OP mentioned it takes 126 ft./lbs. to turn crank manually with plugs installed.
    Sounds like cam may be installed way advanced.
    chryslerfan55 and seb fontana like this.
  7. Ain't that the truth!
    Ben
  8. 1-SHOT
    1-SHOT
    from Denton
    Yellow spark will not fire today's gas,you need a white or blue spark and check the amp draw on the starter, and is it big enough starter.
    I bought a real clean 65 C10 that some one put a BBC in and it would not start when hot. No. Cause asmall starter was used and not enough Amp.hrs. In the battery. Changed both and it would always hot start after that.
  9. Malcolm
    Malcolm
    from Nebraska
    The original poster @Trace jarvis hasn't been back on since Wednesday afternoon.
    Will he be back to follow up with all of the advice given? Who knows....
  10. 41rodderz
    41rodderz
    from Oregon
    I hope so. This is interesting and I would like to know. I feel for his aggravation but I like to learn or be reminded of potential causes.
  11. 54vicky
    54vicky
    if he has done 50 he should check the simple things first as suggested if he really has done 50 the battery as suggested should be load tested first off.again if he has done 50 I would think he covered all other things timing etc.should be second nature if truly built 50.before flaming think about how many have built 50 and have not gone through everything suggested.in the sixties I built my first engine same type problem.my girlfriend now wife kept telling us it was battery we knew better ha ha after 2 days we put in new battery low and behold it cranked and fired.she reminded me for years:):)between race car engines and street I have probably buttoned up 30-40 small blocks not an expert but
    chryslerfan55 and Tim like this.
  12. Ebbsspeed
    Ebbsspeed
    @54vicky I was thinking along those same lines after reading some of the O/P's posts. Anyone that has "done over 50 of these in the past" should be able to zero in on the issue pretty quickly.
    chryslerfan55, Truck64 and 54vicky like this.
  13. 1946caddy
    1946caddy
    from washington
    Just checked his profile page and car listed is (99 blazer with sbc350 gen 1) :confused:
  14. dan31
    dan31
    A
    Comes on here in a panic then posts this cry baby b.s. and then doesn't post a follow up .WTF.
    chryslerfan55, WTF really and 54vicky like this.
  15. 54vicky
    54vicky
    if like he said he has done fifty:D.then load test battery simple for nearest auto parts store after doing 50 then engine work should be out of the equation besides the no cost factor.with test
  16. 41rodderz
    41rodderz
    from Oregon
    Snookered again , maybe :confused:o_O:eek:
  17. 52HardTop
    52HardTop
    It's what I felt when he first posted. There was just something about his post that didn't feel right.He did 50 yet he was working on this one for 2 & 1/2 months. Suggestions were made on what to test and he comes back shortly after saying he tried everything and He still needed help. I hate to be so skeptical, but, there have been a lot of posts where guys have been getting scammed here and this just seemed strange. His writing and spelling was a lot like some Nigerian fellow trying to scam for a cut from his million dollar lottery winnings...
    chryslerfan55 and 54vicky like this.
  18. I say let's don't rush to judgment. While it does seem strange that he hasn't responded further, we have no way of knowing what is taking place. Maybe he fell ill. Maybe he had a vacation sked for this time. Maybe he had a family emergency. Perhaps he found someone in his area to give him a hand. It cud be anything. Did anyone attempt to call him? He provided a phone number. He has a valid address where he sez he lives and the area code he gave with his phone number is correct for that area. The HAMB has done what it does best, i.e., come to the aid of someone having an automotive dilemma with sound advice and that's not easy to do from a distance. All of you shud pat yourselves on the back for your willingness to help a perfect stranger and feel good that you gave it your best shot.
  19. Tickety Boo
    Tickety Boo
    from Wisconsin
    I am not that far away, Manitowoc WI, tried to call and left a message and got no response.
    Funny thing is the guy recording the message didn't answer it with the name Trace. o_O
    Try it out and see if you can hear the name, I could not make it out.:oops:
  20. Man, I'll tell you how "it used to be". It used to be people didn't think they were owed something and were grateful for the help they got. You've got a shitload of guys here trying to help you, some have sent you private messages and others have tried to call you. You haven't shown the courtesy of even returning to this thread with an update. You've built 50 of these, my ass.
    Hell, maybe I'm being too hard on you but I don't like whining, especially when you have so many of these good folks trying to help you.
  21. Maybe he just got a hernia from turning the engine over with a 6 foot crowbar.
    Tim_with_a_T and 54vicky like this.
  22. We apologize if the free service provided has not been up to your standards on this occasion. Please come again.
    slack, chryslerfan55, Wraith and 5 others like this.
  23. 1934coupe
    1934coupe
    52HardTop and 54vicky like this.
  24. 54vicky
    54vicky
    I am thinking he reread his claim of 50 and realized it should have read .05 they took his outside contact privileges now taking up math classes
  25. upspirate
    upspirate
    Oh well, threads like these give us something to do while waiting on updates from Squirrel's Barracuda and Hotrodmnm's Edsel threads ( as well as all the other interesting threads) ;)
    slv63, 54vicky, David Gersic and 2 others like this.
  26. Well maybe, just maybe Mr. Trace went back to Nigeria after creating all of this De Ja Vu all over again.:eek:
    54vicky and 52HardTop like this.
  27. Come on guys, you know some people are not tethered to the hamb all day long. A new guy probably won't be interacting with every post on here. Besides, there are other posts to read if he doesn't come back.
    osage orange likes this.
  28. Nobey
    Nobey
    I think he just wanted someone to work on his car for FREE. Same thing happened in the Ford Club,
    A new member would come along..... First thing was, can someone come over this week-end, and help
    me put on new brakes. Then they'ed call another member to help build a early transmission, and so on.
    Didn't take us long to figure out what was happening, all new members were put on probation after that.
    Another reason they would join, was to get into everyones part stashes.....
  29. Read the title of the thread.................the dude's lost.
  30. corndog
    corndog
    from Indiana
    I think we need more info on the rotating assembly, especially the pistons. He never said but I am wondering if this a re-ring instead of a fresh bore with new pistons. I have a hunch that this is a re-ring job and that the old pistons never had the carbon removed from the rings grooves. If that is the case the pistons will be free at the top where there is taper-wear in the block, but will be extremely tight in the lower portion of the cylinder where there is minimal wear. If this is the problem, pulling all the pistons, cleaning the carbon from the ring grooves, installing rings and re-assembling will fix the problem. Again just a hunch!
