Customs 235 cranks but won’t fire
Discussion in 'The Hokey Ass Message Board' started by Sharpb, Aug 12, 2018.
  1. RMONTY
    RMONTY
    I bought the Carter Weber dual carb setup from Tom Langdon but haven't put them on yet. I got the dual carb Offenhauser intake....its supposed to be a good setup.
  2. RMONTY
    RMONTY
    A couple of pics of my project engine. It's got an S10 T5 transmission bolted to it. It will all happen when I stop being lazy and bolt them on. :rolleyes: 20180816_185428.jpg 20180816_185503.jpg
    302GMC likes this.
  3. Sharpb
    Sharpb
    That’s a pretty sweet setup you got there. I’ll look into the carter or Holley carbs. I found a fuel pump at oreilly for about 45. Rock auto has them for around 20, but I’ve learned the hard way, you usually get what you pay for
  4. Sharpb
    Sharpb
    I didn’t see it on your motor, but what is the thing between the distributor and fuel pump that comes out of the block and turns under the truck?
  5. RMONTY
    RMONTY
    You will likely get a lot of different opinions on what the best carb is. It's like "what's the best oil" question lol!
  6. RMONTY
    RMONTY
    It's called a road draft tube. It's for crankcase ventilation. It was used before PCV valves came about. (Positive Crankcase Ventilation)
  7. Sharpb
    Sharpb
  8. RMONTY
    RMONTY
    Any progress? What are the immediate plans? Just checking in with you.
  9. woodbutcher
    woodbutcher
    :D Ah yes.Ignition problems CAN drive one up the wall rather quickly.On an easy way to fill the float bowl.I have an old metal funnel from a Coleman refill kit.Just put a short piece of fuel hose on it,and stick that on the bowl vent.No fuss.No muss.Easy fill.No spill.
    Good luck.Have fun.Be safe.
    Leo
    belair likes this.
  10. Sharpb
    Sharpb
    I guess no one around me carries the fuel pump in stock, so I had to order it online. After I see that the engine is going to work ok, I’m gonna start on body work and getting rid of surface rust. I’m really in no hurry, so it will just be a little here and there (that’s what I keep telling myself anyways)
  11. 52HardTop
    52HardTop
    I'd get it running and driving first. The other work can always be attended to after. You need to have it on the road so there is no chance that the project stalls.
  12. Nailhead A-V8
    Nailhead A-V8
    replace your condenser (the little round thingy by the points) or ground check the little ground wire inside the distributor and your engine to body ground...put some extra ground wires here and there it can't hurt....you don't need a fuel pump to get it running. I use a gatorade bottle hung from the hood take the top off the "sports lid" attach your fuel hose to the ****** and to your carb....oh and if gas starts pouring down the carb your float is stuck
  13. Sharpb
    Sharpb
    I’m sure the carb is all gunked up. I foresee a carb overhaul coming soon
  14. RMONTY
    RMONTY
  15. Sharpb
    Sharpb
    Thanks. I’ve watched a couple of videos and read most of what I can find online
  16. Sharpb
    Sharpb
    Would it be a bad idea to soak it before I completely dis***emble it, to try and loosen things up?
  17. RMONTY
    RMONTY
    I have always dis***embled them, cleaned the parts with a gasoline rinse, and then soaked the parts. Keeps the Chemdip a bit cleaner if that makes sense.
  18. ClayMart
    ClayMart
    Did you have your fuel can sitting on the floor? Keep in mind that mechanical fuel pumps aren't very well designed to draw air through them. They like to have an ample supply of liquid fuel on the inlet (suction) side of the pump. Air, instead of liquid, in the inlet hose is essentially what happens under a vapor lock condition.
    Your old pump may in fact be shot. But even a good pump may act a bit flakey trying to draw air up the fuel line from a fuel can sitting on the floor. If possible, try to prime the inlet hose and pump with liquid fuel and set the can somewhere close to level with the fuel pump. Just make sure it can't be easily tipped or knocked over.
  19. Sharpb
    Sharpb
    I had the gas can sitting beside the fuel pump. I’ve already ordered a new pump, but I’ll try priming the line and if it works, then I’ll have a backup. Thanks for the tip
  20. 1 Raggedy Ride
    1 Raggedy Ride
    Some years ago, I drove my '71 Torino to work; Tried to go home, wouldn't start... Car sat there for a few days, until I figured if out.... The condenser was bad..... A few years ago, something in my MSD distributor, went bad also..... Just trying to help you, make the best choice....
  21. rfraze
    rfraze
    Say Hello to Mike Campbell in St. Jo.
  22. Sharpb
    Sharpb
    I don’t think I know a mike Campbell. Has he lived here long?
  23. rfraze
    rfraze
    Long time. Out towards Bulcher off 2382. The firewood guy/inventor.
  24. Sharpb
    Sharpb
    Hell, I might know who he is, just can’t put a face to the name. I’ve lived here for the past 28 years
  25. Sharpb
    Sharpb
    I got the new fuel pump on today and started working inside the cab ( pulled everything out and started freshening everything up). It will definitely need a carb rebuild. It sprays gas out of it[
    RMONTY and Truck64 like this.
  26. RMONTY
    RMONTY
    Good deal! Glad it's running. I'm not sure what that bracket is but it looks like an a.c. bracket maybe? I've never seen one like that.
  27. belair
    belair
    Congrats on getting it running. I think that's an AC bracket too, maybe for one of those old Yorks.
    RMONTY likes this.
  28. GuyW
    GuyW
    Is that trans a straight bolt-in?
  29. Sharpb
    Sharpb
    Yeah, I’m not sure what that bracket is either. I thought ac would be on the other side
  30. RMONTY
    RMONTY
    No it requires an adapter plate. There are several around on the market.
