Projects Rusty chrome bumper, is there anything I can do? update
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 24, 2018.
  1. HOTRODPRIMER
    HOTRODPRIMER
    To clean them up and make them look a little more presentable short of having them re-chromed?
    The front bumper & turn signal housings on the coupe are showing their age and looking pretty bad and replating is out of the question for now.
    Anyone have suggestions on how to clean the chrome or at least remove some of the rust and improve the looks? HRP
    3W JOHN and chryslerfan55 like this.
  2. Kerry
    Kerry
    Oxalic acid. spray it on, scrub wash off thouroghly. Years ago I worked for a detailer and it would take bumpers with rust showing all over and make them look way better. It's not going to take out pits and the like but the red will be gone.
    grapeboy, jazz1, wvenfield and 3 others like this.
  3. Chavezk21
    Chavezk21
    I have had good luck with White scotch brite and clr, then wax the snot outa it.
    jazz1, 3W JOHN and HOTRODPRIMER like this.
  4. 0000 steel wool with water and Ajax worked for me
    Then some atf and steel wool
    And then it looks like cotton batton soaked in something but it’s called NEVER DULL works great
  5. 56don
    56don
    X2 I have used the 0000 steel wool on lots of chrome and if you don't actually scrub it, but gently polish with it, it works well. Some people hear the word steel wool and scream that it will scratch the finish but the 0000 is not the course stuff, I have even used it on cleaning plastics.
    Please....don't paint the bumpers! Looks awful.
  6. dana barlow
    dana barlow
    from Miami Fla.
    In case those don't work,,Also there is now some stratchy chrome tape that if put on right,a smooth clean bumper,looks like new chrome,last about 2 years if kept out of sun at lest some of the time. Sign shops have it. Rechroming the bumper maybe good if ya find a place that's low enough $
  7. traffic61
    traffic61
    from Owasso, OK
  8. ffr1222k
    ffr1222k
  9. I take Ospho and pour a little in a dish, cut out some aluminum foil about a 3" x 3" square and wad it up in ball. Dip the foil in the ospho and scrub the offending chrome. The foil knocks the rust down and the Ospho converts it. Then seal it with wax.
  10. low budget
    low budget
    from Central Ky
    I always use soap SOS pads and water but Ive heard people say oh that will scratch the chrome but Ive never really noticed any significant scratches on the bumpers, wheels, bezels etc Ive cleaned,They have always looked a lot better but then most of the stuff Ive cleaned wasnt bordering perfection either.
    Actually thats the first thing I wanted to mention when I saw this car in another thread, SOS pads and water would knock that junk off there quick
    scotty t, 3W JOHN and HOTRODPRIMER like this.
  11. 51504bat
    51504bat
    As kids we used Coke and aluminum foil
  12. L. Eckart
    L. Eckart
    Do they make a Chrome Wrap like wrap they use on cars?
  13. stanlow69
    stanlow69
    Citric Acid, food grade mixed with water. 15 minutes in the tank. Scan0488.jpg Scan0491.jpg
  14. upspirate
    upspirate
    I was going to say if the other methods don't satisfy you , maybe those wrap places will have something that will be better until you decide to get it re-chromed
  15. jimmy six
    jimmy six
    Yep.. Have it chrome wrapped I you want it to look better. Chrome vinyl numbers on race cars look good. But I'd really have it smooth as it will show ripples but not pits. I bought a small roll and did some wind wings. After a couple of years the need to be done again. Still look great but don't have the "mirror" look anymore.
  16. clem
    clem
    HRP,
    Let’s see the end results please.
    Thanks
  17. KustomKreeps
    KustomKreeps
    My normal goto for rust these days is electrolysis bath but not sure how that would go with chrome plating and the fact the bumper is so large it would rule it out anyways.
    Have used store brought chrome scrubs but I find Aluminum foil and coke works just as well. soak the smaller parts over night in a coke bath(contains acid) then scrub with foil.
  18. cretin
    cretin
    My old man read about using window cleaner and aluminum foil. He used it on a chrome sbc water pump we had lying around and he was pretty impressed with the result.
    I must admit, it worked well. Well enough to get bolted onto the engine in the '54.
  19. bobss396
    bobss396
    My Ford bumpers were not as bad as yours, I used Noxon polish and steel wool and it got all the rust off. I need to go over them again and wax them after. The bumpers are decent driver quality.
  20. FrankenRodz
    FrankenRodz
  21. Fold up some aluminum foil about 8 plies thick. As you are rubbing the bumper, pour on a can of Coke at the same time. Used this a lot. Wax after words. Would last about 2-3 weeks.
  22. BamaMav
    BamaMav
    from Berry, AL
    Is Dallas Plating in Dallas GA still in business? Not really that far from you, and they may have an exchange bumper.
  23. moparjimd60
    moparjimd60
    Might give hart plating in Carrollton ga they do great work and are very reasonable.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Having them plated is just not in the budget at this time, I just want to improve the looks and anything I can do myself I can use that toward the metal work. HRP
    chryslerfan55 and 3W JOHN like this.
  25. ct1932ford
    ct1932ford
    Nevr-Dull is my go to!
  26. HOTRODPRIMER
    HOTRODPRIMER
    I've got a can of that around here somewhere now all I have to do is find it, we used it on a antique br*** bed and it sure turned out nice.
    It never occurred to me to try it on chrome. HRP
    chryslerfan55, 3W JOHN and bowie like this.
  27. Rusty O'Toole
    Rusty O'Toole
    I use copper scrubbing pads and Pledge. Steel wool scratches, you can see the fine scratches if you look close. This may be a minor point if the chrome is already scratched to hell. But, I still use the scrubbing pads. 3 for a $1 buck at the dollar store.
    3W JOHN, HOTRODPRIMER and VANDENPLAS like this.
  28. johnold1938
    johnold1938
    from indiana
    try white vinegar, works good and is user friendly!
  29. bowie
    bowie
    I have had good luck with Vandenplas’s suggestion. However, I usually go with WD40 instead of atf. I have found the current version of Never Dull seems to be missing something; so that old can of it you have ; is probably still the good stuff.
