Hot Rods SBC squeaking motor question? help please
Discussion in 'The Hokey Ass Message Board' started by ozzies 57, Aug 24, 2018.
  1. ozzies 57
    ozzies 57
    SBC 350 motor. went on one of those super slow miserable cruises at hot august nights in Reno, 1 MPH for 1.5 hours. no overheating made it great. then when I got back home I could hear what sounded like a water pump squeak... however I wasn't leaking any fluid and if I hit the accelerator enough it disappears.
    I took both belts off and started the car. still has the squeak. now I am a little more worried. it can't be the alt. or A/C, it isn't the belts, and it can't be the water pump. so who has EXPERIENCE in something like this??? what is the most likely culprit?
  2. X38
    X38
    It is a mouse engine.
    Happydaze, pat59, moparjimd60 and 2 others like this.
  3. blowby
    blowby
    from Nicasio Ca
    Look in the valve covers and see if it's wet.
    302GMC likes this.
  4. ozzies 57
    ozzies 57
    and if it is not, is it a oil pump issue?
  5. DDDenny
    Does it have roller lifters?
    Johnny Gee and lumpy 63 like this.
  6. 24riverview
    24riverview
    Balancer moving around on the rubber?
  7. oldtom69
    oldtom69
    from grandin nd
    Not good news-had the same "squeak'-blown head gasket between middle two cylinders!mine actually torched a trough in the block,never blew water out or got into the water jacket
  8. tinkirk
    tinkirk
    Does it go away when bringing the rpm's up?
  9. Dago 88
    Dago 88
    Check oil Pressure & check valve clearance.
  10. shivasdad
    shivasdad
    from Texas
    I rebuilt a 292 Chevy inline that developed a strange squeak. I tracked it down to where I could make it go away by loosening the front rocker arm. More pressure equaled more high pitched squeaking. The guy I was helping decided to leave the front rocker arm at less than optimal adjustment so I never got to the actual problem. Strangest squeak I ever found.
  11.
    slowmotion, pat59 and Moriarity like this.
  12. riv63
    riv63
    from Texas
    Cam bearing?
  13. boltupal
    boltupal
    from western ny
    If you don't have one already. Buy or borrow a stethoscope find out Exactly were the squeak is coming from.
    blowby likes this.
  14. ClayMart
    ClayMart
    Worn rocker arm and pivot ball will set up a squeak sometimes, usually if they've been oil-starved. Suppose a push-rod end could do the same thing at the rocker arm socket too.
    Maybe loosen or remove the fuel pump, start it for a few seconds, and see if that changes anything. Also check the engine mounts and give 'em a spray with some silicone lube and see if it quiets down. If it's an automatic check that the convertor bolts are tight, though if they're loose they usually make a tick or knock noise.
  15. ozzies 57
    ozzies 57
    O.k thinking ill go valve covers off first and look for something in there. It's a 56 chevy so it only has an oil dummy light. So I will run a cheaper gauge to the block and see about oil pressure. I'm going to ***ume the head gasket or block isnt blown. Runs great and I wouldn't say it is overly loud. Just obnoxious to me. Then I'll check back in.
    firstinsteele likes this.
  16. Budget36
    Budget36
    Maybe a vacuum leak?
  17. bigdog
    bigdog
    I had a bad cam bearing squeal, but it didn't go away at higher rpm. First thing I'd do is check under the valve covers.
  18. KJSR
    KJSR
    from Utah
    Try disconnecting the PCV and see if it goes away.
  19. flathead4d
    flathead4d
    Had a squeak on a 70's Chevy. Turned out to be a a push rod not getting any oil at the rocker.
  20. DDDenny
    Back in the mid 70's I built a 355 small block and a brand new Chevy blue stripe pushrod had one end ball that didn't get drilled all the way through, burned it up along with a rocker arm.
  21. ozzies 57
    ozzies 57
    so wait for it. I tried a couple things today and got frustrated, and I hit the headers with the palm of my hand while using a few choice words as I pushed myself up out of that stooped over stance we all know so well. an there it was the squeak! so I hit them again, the squeak, went to the other side and hit the valve covers and....wait for it, the squeak. so that means it isn't mechanical and I have narrowed it down to 90% sure it must be motor mounts, the engine has a nice little lopping movement to it when idling, not much but its there, obviously it smooths out on acceleration and 2 hour cruise of almost always idling must have either cracked the rubber on one, or else the main bolt is loose, either way I am feeling pretty confident this might be a fairly inexpensive fix. (fingers crossed).
    thanks all for all the info.
    swade41 likes this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I bet that kept you up nights wondering what was wrong all this time. Myself, I always sleep well after the bed springs go silent. :)
