Technical I may have lost the coolest little tool.
Discussion in 'The Hokey Ass Message Board' started by gimpyshotrods, Aug 25, 2018.
  1. gimpyshotrods
    gimpyshotrods
    I may have lost the coolest tool that my grandfather gave me, and now I am not sure that it is even made anymore.
    It is a socket adapter that goes directly from a 1/4" drive ratchet, to a 1/2" drive socket, in one step.
    I have used it over 100-times to set pinion preload. Now, it is not in its marked space in the drawer, and is nowhere to be found.
    Does anyone know if this tool still exists? I cannot seem to find one. I don't like stacking adapters with this low a torque reading, and not with a rotating measurement. Slop creates errors.
  2. Budget36
    Budget36
    I welded two together to make mine.
    I wonder if HF sells something like that?
    belair likes this.
  3. banjeaux bob
    banjeaux bob
    from alaska
    Could it be in the location you have reserved for your 10mm socket?
  4. H380
    H380
    from Louisiana
    He wants 1/4 to 1/2. Hard to find. 1/4 female to 1/2 male
    3340, Hnstray and banjeaux bob like this.
  5. gimpyshotrods
    gimpyshotrods
    I have 12 of of those in 6-point, and 8 in 12-point.
    weeniewawa likes this.
  6. gimpyshotrods
    gimpyshotrods
    Correct, on both counts.
    I will likely resort to welding two adapters together, but would rather have the real-deal.
  7. Truck64
    Truck64
    from Ioway
    I've been doing some Remote Viewing. Check behind the toolbox cabinet, it fell down and rolled next to the wall. Thank me later.
  8. 1946caddy
    1946caddy
    from washington
    It will be laying in plain site as soon as you get another one. :D
  9. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Go to H F & buy a 1/4" drive torque set. They are under $20.00 & are close enough.
  10. Bleach
    Bleach
    I've got a ****sman 1/4 to 1/2. They should still make them.
    It's easy to miss them when mixed with sockets or left on a socket.
    kidcampbell71 likes this.
  11. porkshop
    porkshop
    from Clovis Ca
    Snap on has them. I can get you a part# monday...
  12. junkyardjeff
    junkyardjeff
    Did not know that adapter was ever made,I do have a few 1/4 to 3/8 and might have to look for one since I could have used one many times.
  13. squirrel
    my torque-o-meter is 3/8 drive so I never needed that cute little adapter....
    VANDENPLAS likes this.
  14. Ebbsspeed
    Ebbsspeed
    Weld a chunk of 1/2 inch square stock in a POS 1/4 inch socket.
    clem and Hnstray like this.
  15. Never2low
    Never2low
    Got a 1/4 male to 1/2 female, but not the other way around.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Porkshop, I don't think Snap-on has that item.
    Gimpy, I can see why that would be good for checking pinion preload. But, the slop you refer to does not affect torque readings as long as you are not introducing a side load into the ***embly.
    I spent 22 years at Snap-on and put on countless torque seminars as both an engineer and Government Sales Rep. Trust me on this one.
    But that being said, I would buy said adapter if I could find one for exactly the purpose you stated. I also set carrier preload that same way.
  17. ClayMart
    ClayMart
    Have a little talk with St. Anthony. He'll help you find it.
    TomT, Okie Pete, Atwater Mike and 3 others like this.
  18. I have never seen a 1/4 to 1/2 adapter, and I wouldn't waste the big bucks it is going to cost to buy an expensive Snap On tool if it is only going to get used once in a blue moon. I would weld a 1/2 square piece onto a POS 1/4 socket that has been ground down enough to keep the adaptor short. For the 1/2 inch piece, I would look to sacrifice a cheep, bent, damaged, 1/2 extension or the nose of a flex tool as the donor.
    From my personal point of view, my inch pound torque wrench is 3/8 ths, and I can't think of a time in 60 years, when I have needed to go from 1/4 to 1/2 directly where I haven't been able to use 2 adapters.
    Bob
  19. gimpyshotrods
    gimpyshotrods
    I average two gear changes a month. More in the summer time.
    I don't care about money. As long as I am not dead, I can just make more.
    It was a Williams adapter, I think, and it was older than me.
    Okie Pete and Hnstray like this.
  20. gimpyshotrods
    gimpyshotrods
    Is that malt liquor?
    Joez, Special Ed and ClayMart like this.
  21. Williams was Snap-on's industrial line (now discontinued I believe), so I'd look in industrial tool suppliers, not automotive. May be unobtainium new these days, sounds like an eBay search is in order....
    Hnstray likes this.
  22. Boss 302 Mustang
    Boss 302 Mustang
    from Duxbury MA
    They used to sell Williams tools at an auto parts store where I grew up.....I didn't know they were connected to Snap-On. I still have some wrenches....very good quality
    brad2v and Hnstray like this.
  23. woodiewagon46
    woodiewagon46
    from New York
    Craftsman PN, 4257, and yes you are right, it comes in handy.
  24. Hnstray
    Hnstray
    from Quincy, IL
    Gimpy, hope you find the ‘misplaced’ adapter......sentimental value is worth a lot, even if you can find a replacement.
    Ray
    brad2v and gimpyshotrods like this.
  25. safetythird
    safetythird
    I googled it and that is 1/4 to 3/8. Gimpy wanted 1/4 to 1/2.
    verde742 likes this.
  26. I'm gonna have to keep an eye out now at the next tool swapmeet, as I didn't know they were made.
  27. Dean Lowe
    Dean Lowe
    The thread ***le fooled me. I thought there had been an accidental amputation! :eek:
    GuyW, Nailhead A-V8, oldsjoe and 5 others like this.
  28. gimpyshotrods
    gimpyshotrods
    I said little.[emoji6]
    oldsjoe, dana barlow, brad2v and 2 others like this.
  29. verde742
    verde742
