Projects buying an ole can a beans:my 29 ford
Discussion in 'Traditional Hot Rods' started by Austin kays, Jan 13, 2018.
  1. Tim
    Tim
    from KCMO
    @Dennis Lacy though you make have some ideas as well.
    Trans was acting fine- non driving car as of yet- previously. Is it possible that monkeying with the clutch linkage arm on the side of the trans could move things enough to do this?
  2. There are two things to check, fist of all if the clutch is disengaged and after that it will be a matter of pulling the inspection plate/top if ****** and checking for stick engagement and shift fork issues.
    Sounds worse than it is. It is actually simple ****** 101
    loudbang and Tim like this.
  3. Tim
    Tim
    from KCMO
    @porkn****** that’s kinda what I figured. Just hard to help or check when I can’t make it over there to look in person. So I figured I’d see if anyone in internet land had any ideas before it got dug into
  4. Tell me about it. I am going to try and break off a piece of time this week, uh don't tell the kid. :D
  5. Austin kays
    Austin kays
    Well that would be appreciated. Im at a loss. When its in neutral the tires spin pretty freely. But when put in a gear the spin like theres a load on them. And not as long. Just to throw another question mark in there as well.
    Sent from my LGMP260 using The H.A.M.B. mobile app
  6. For it to turn “in gear” wouldn’t the engine be turning too?
  7. Austin kays
    Austin kays
    Yeah but the motor wont turn because the starter is jammed up. Thats where my confusion lays
    cactus1 likes this.
  8. Austin kays
    Austin kays
    They arent hard to turn when put in gear but they dont spin as long as opposed to when its in neutral
  9. Tim
    Tim
    from KCMO
    Sounding more and more like your clutchnis disengaged
    Atwater Mike and cactus1 like this.
  10. That's my point. something is broken or disengaged.
    Tim likes this.
  11. slowmotion
    slowmotion
    Or the clutch is just 'barely' engaged. Enough to put a slight drag and still be able to turn the wheels. Full engagement and them wheels ain't turnin'. Course I never tore into one of those in particular, so YMMV. Hopefully it's a matter of adjustment...
  12. Tim
    Tim
    from KCMO
    That seems likely. It all seemed to work just fine until he was messing around with mocking up some clutch linkage. Seems reasonable that he got the arm twisted back hit enough that it’s letting it slip.
  13. Tim
    Tim
    from KCMO
    I’m leaning toward disengaged. It would hold in gear just fine before and the car hasn’t moved since then.
    Good thoughts and suggestions guys
  14. Austin kays
    Austin kays
  15. saltflats
    saltflats
    from Missouri
    If it is a open diff the wheels will turn in gear. one wheel one direction and the other wheel the other direction.
    Tim likes this.
  16. Austin kays
    Austin kays
  17. Tim
    Tim
    from KCMO
    Lol so your possibly totally fine
    brEad likes this.
  18. Austin kays
    Austin kays
    Well got the car back in gear and the starter off and the teeth are pretty chewed up on starter Im think on my first fire up the engine took off running with the starter engaged. Soooo I'm guessing I hurt the old starter
  19. Austin kays
    Austin kays
    kiwijeff, Texas36, loudbang and 3 others like this.
  20. Austin kays
    Austin kays
    Well after losing a wheel because of stripped-out wheel studs. We decided that it's probably not a good idea to flat tow the old a bone.[emoji23] [emoji23] [emoji23] but man it's always interesting around here 20180826_181024.jpeg 20180826_181059.jpeg
    ct1932ford, kiwijeff, Texas36 and 3 others like this.
  21. Tim
    Tim
    from KCMO
    That was incredibly entertaining lol. Hotrods. Gotta love em 538BC6BE-0A3E-44C3-87DA-B80FD00F4F22.jpeg D592577E-B6BF-4945-B864-09D2402C8C9C.jpeg
    kiwijeff, Sancho, brEad and 1 other person like this.
  22. Austin kays
    Austin kays
    Getting it outside gave me a chance to do a crude photochop on it. Ones real radical other little more conservative. received_683057242051809.jpeg received_1977432295650481.jpeg
    ct1932ford, kiwijeff, Texas36 and 2 others like this.
  23. Texas36
    Texas36
    Hardchop all the way!! Looking cool > comfort lol
    kiwijeff likes this.
  24. Austin kays
    Austin kays
    Haha I love the hard chop
  25. Austin kays
    Austin kays
    But zero room after I already channel the car almost 3in LOL we're going to be running out of room real quick
  26. 2" and let 'em wonder. Hell you could even make up a good **** n bull story about it being a limited run in a pre Vicky model. LOL
    osage orange and Austin kays like this.
  27. Austin kays
    Austin kays
    Hahaha now that could be fun [emoji23] [emoji23]
  28. That's what its really about isn't it. ;)
  29. Austin kays
    Austin kays
    That it is haha
  30. Corn Fed
    Corn Fed
    Or go the other way....add 1" and really make them scratch their heads.
    osage orange likes this.
