331 Hemi question
Discussion in 'The Hokey Ass Message Board' started by Fox Valley Hot Rods, Mar 8, 2007.
  1. I did a couple of searches and found some good info, but not what I needed. I have a 4x2 intake off a 331 Hemi, can anyone tell me what other engines this will fit? :rolleyes:
    Matt
  2. Soviet
    Soviet
    331 354 392 Chrysler
  3. scootermcrad
    scootermcrad
    Not always...
    It shouldn't fit the 392 because of the higher deck height.
    Will bolt up to a 331 or 354 but is there provisions for a water neck and thermostat on the manifold? 331's had no water crossover so there were provisions for water flow thru the manifold. 354's had a water crossover up front that enable the thermstat and return neck to be positioned there.
    Pictures of the manifold?
  4. junkmonger
    junkmonger
    Even though the 392 has a taller deck height, it has more meat on the intake side if the heads to make up for this. This means the 331/354 intake may work for a 392 as well. Hot Heads makes a pair of shims so you can use the better-flowing 331/354 heads on a 392 without changing intakes.
    I think the only difference in Chrysler hemi intakes is the water crossover for '55 as scootermcrad already said. Tex Smith's 'Complete Chrysler Hemi Engine Manual' has a lot of good info on all the mopar hemis.
  5. Kerry
    Kerry
    Junk****er is right on. The intakes all swap in the chrysler hemis. The 392 heads do have more on the intake side. 354 heads can be run on a 392 with the spacers. Putting 392 heads on a 331/354 would mean milling the intake side of the heads to fit.
  6. Soviet
    Soviet
    As mentioned, stock they will all interchange. The 392 heads have more meat on them to compensate. The high deck issue came into play when racers started using the 354 heads on 392 blocks, but the intakes could still be used with a spacer. Stock Chrysler intakes swap across the board, the only exception being the wet intakes.
    http://www.jalopyjournal.com/forum/showthread.php?t=118712&highlight=hemi+tech
  7. George
    George
    On the 354 & '55 331 the water pump bolted to the front of the heads, the 392 has the crossover.
  8. Kerry
    Kerry
    Only in certain cases. I've got a pair of 354's with pumps that bolt to the block and the separate water crossover.
  9. scootermcrad
    scootermcrad
    Ah yes! I stand corrected!! :eek: I've been so fixated on head swaps lately that I forgot that there are stock motors out there! DOH! Sorry about that! Correct-a mundo! Just water flow differences.
    :eek:
  10. George
    George
    All the Chr intakes will bolt on any Chr. Hemi. You can put most dry intakes on the engines w/o the front openings by drilling the intakes for fittings where the water holes are in the intake flange on the head. Some have a different crossover under the carb, most are square, some tall & narrow. the 51-3s have small runners. In the "Idle minds Dept."....You could put a '54 wet intake on an engine with the 392 crossover & run two upper radiator hoses to a custom radiator...
  11. strombergs97
    strombergs97
    Hello...If the intake is a cast aluminum, not log type, won't fit the 392..If it is a log type (2 pieces) it will fit..Make up the difference with the rubber cross over tubes..Flange pattern is the same on all three engines..
    Duane..
  12. Soviet
    Soviet
    Why not?
  13. Kerry
    Kerry
    That's true only if you have 392 heads on a 354/331.
  14. George
    George
    Exactly!!:D
  15. slayer
    slayer
    If this intake is for a '51 to '54 331 it will have some means to get coolent out of the heads, and possably a thermostat housing. The '51 to '54 did not have a external water crossover like the '55 to '58 had, it was cast into the intake.
  16. junkmonger
    junkmonger
    This has already been covered. See post #10 in this thread.:rolleyes:
  17. Gkafer
    Gkafer
    from Vancouver
    Here's another 331 manifold question. I've shown this manifold to a few people and they havent seen it before. Is it just a stock 331 mani or something else. The water crossover looks different?
    It's on a early 331 exyended bell #1323329-2
    The manifold # 1637625-2
    Valley # c53-8-12583
    Just curious if anyone knows something about it.
  18. Here's a picture of the intake I have. :)
    Matt
  19. snap too
    snap too
    from lost wages
    That old Horne is a nice piece , it even has the hose spuds for the upper hoses,used on 51-54 . Cragar made one pretty close to it but the spuds weren't drilled . In looking at the picture of that long bell 331 with a strange water neck , I believe it's a later 4 bbl. intake with hoses adapted , not a '54 model because the water p***age was cast in the intake and it was the first year for a 4bbl.
  20. strombergs97
    strombergs97
    OOPS..I forgot about that swap..Your right..
    Duane
  21. englishtim
    englishtim
    hi is this for sale ??
  22. George
    George
    You do realize that was posted in '07?
  23. Kerry
    Kerry
  24. foolthrottle
    foolthrottle
    Should fit Chrysler 331/354 poly head engines as well, whether its 2007 or 2018
  25. tubman
    tubman
    Hell, I'd ask after 20 years if there was even a sniff of a chance to pick up a Horne four-in-a-row for an early hemi!
    John Milner and Hnstray like this.
