Projects 54 Capri Roadster
Discussion in 'Traditional Customs' started by 296moon, Jan 17, 2018.
  1. I kept a conv top frame from a Benz I fixed years ago
    that looks cool
    OahuEli and chryslerfan55 like this.
  2. Ya know Moon, every time I see progress photos of your build I’m truly amazed at the level of craftsmanship.
    bct likes this.
  3. 296moon
    296moon
    from england
    Well I got the roof to nearly fit but it just wasent doing for me in the looks department so I junked it and have gone back to my first thoughts for this, moved the screen back about 6″ and made a new dash frame for it to mount on, rear quarters are now slightly lower too and taper down, It flows alot better now in my eyes……………………. [​IMG] [​IMG] [​IMG]
    Okie Pete, OahuEli, bct and 1 other person like this.
  4. Moon, moon,moon. As I said before, every time I see progress photos of your car I’m amazed at the level of craftsmanship.
    gsnort likes this.
  5. 296moon
    296moon
    from england
    Decided to try my hand at making a screen frame, so heres the start [​IMG]
  6. 296moon
    296moon
    from england
  7. brigrat
    brigrat
    from Wa.St.
    I had to come back to see what a "screen frame" was, I guess it's something you put above and back of the "bonnet" ?
  8. 296moon
    296moon
    from england
    I need to reshape the top edge as its slightly pointed but should suit the rest of it better [​IMG]
    gsnort, Okie Pete and chryslerfan55 like this.
  9. 'Mo
    'Mo
    I'm pretty sure that that means "Windshield" (wind-screen) frame.
  10. beater40
    beater40
    Have u thought about a screen off a 55 Chevy, nice shape and curves around to the start of the door
    Sent from my VFD 710 using The H.A.M.B. mobile app
  11. 296moon
    296moon
    from england
    Not many 55 chevys in available in england for spare parts sadly so we have to make do, happy with the top frame now but the base shape needs more input [​IMG] [​IMG] [​IMG]
  12. Fabber McGee
    Fabber McGee
    What will you do about gl***? Can someone there make custom gl*** at a reasonable price?
  13. 296moon
    296moon
    from england
    Fabbing the frame and former with the intention of having the gl*** made, wether I can afford it or not is another matter, cant get a quote until they see the pattern so plastic it may have to be.
  14. 'Mo
    'Mo
    Repro '55 Chevy windshields are readily available, inexpensively.
    I don't know if this is the solution, but I do believe you would far better work out the gl***, then build the frame.
    IMHO, even a tempered rear window would be better than plastic, which can surely go opaque in the sun.
  15. 296moon
    296moon
    from england
    Mo you my well be right, I have never attemped a frame of this sort before so I am treating the first one as my learning curve then as you suggest I can source the most readly available gl*** and make the frame to suit, I proberbly should have said that the frame bolts on so can be changed if need be and allows me to keep my dream alive of perhaps making a bubble top one day.............................................
    Atwater Mike, OahuEli and brEad like this.
  16. 'Mo
    'Mo
    That being the case, you might want to see what's available in boat windshields.
    (Custom trick since the Thirties.)
  17. 296moon
    296moon
    from england
    Thanks Mo, Been looking for a perhaps suitable boat screen for some time now, but not much available here in the uk and most are plastic, as much as want a gl*** screen if using plastic is the only way I can get the form I see in my head and to be able to afford it then so be it
    chryslerfan55 and 'Mo like this.
  18. 296moon
    296moon
    from england
    First front end mock up to see if goes with new screen shape..............[​IMG] [​IMG] [​IMG] [​IMG]
    gsnort, Okie Pete, OahuEli and 6 others like this.
  19. All I can say is, outstanding.
    kidcampbell71 and 296moon like this.
  20. brEad
    brEad
    Great thread - no fear! Love the idea of a future bubble top! (What about twin/double bubble?)
  21. japchris
    japchris
    from England
    Is that a door window frame as the grille surround? Liking it! Do you have a pair you can shorten to fit?
    296moon likes this.
  22. 40FORDPU
    40FORDPU
    Extensive mods, one off, personalization, unique..well on your way to my definition of a custom.
    Good luck.
    Thanks for sharing your build.
    296moon and chryslerfan55 like this.
  23. Colin HD
    Colin HD
    "keep my dream alive of perhaps making a bubble top one day"
    I've got a spare bubble, if you want to try it for size someday!?!?
  24. Stan Back
    Stan Back
    To me, the greatest thing you've done, is the apparent insetting of the trunk lid – making roadster-size p***enger compartment while maintaining the existing wheelbase. That way it seems to keep the proportions better in tact than adding another 12" of overhang.
  25. rustydusty
    rustydusty
    Add on a cool "continental kit" between those rear fenders, instead of behind them, as they normally are...
    chryslerfan55 and 296moon like this.
  26. Malcolm
    Malcolm
    from Nebraska
  27. 296moon
    296moon
    from england
    Thank you all for your encouragement !, need to sort b/c post shape now so first mock up [​IMG] [​IMG]
  28. goldmountain
    goldmountain
    As I was sleeping last night, I remembered seeing a possible windshield. With Canada having its British Commonwealth connection, the local GM dealerships would sell the odd Vauxhall. Late 50's Vauxhall Crestas had panoramic windshields. I haven't seen one of these for decades!
  29. Nads
    Nads
    from Hypocrisy
    I'm digging this.
