antique tools
Discussion in 'The Antiquated' started by bct, May 14, 2018.
  1. Barn Hunter
    Barn Hunter
    1947knuck and Okie Pete like this.
  2. Barn Hunter
    Barn Hunter
  3. 1932tub
    1932tub
    First item is at tool for recutting threads which have been damaged. Numbers stamped on it denote the number of threads per inch.
    catdad49 likes this.
  4. 18n57
    18n57
  5. 18n57
    18n57
    egads likes this.
  6. Got a few pieces yesterday at the flea market for 50 cents apiece. A pair of JMC Co. blasting cap pliers;a couple of vintage Stanley utility knives(look the same but have subtle differences in the logos);a nice Snap-On screwdriver;a flexible shaft screwdriver(likely for adjusting idle mixture screws)and an X-Acto hand drill which I could have used the day before.
  7. Adriatic Machine
    Adriatic Machine
    One of the few tools I own but do not know exactly how it was used. Twin blades that spread apart on a machined way and can be set at specific spacing. The other end looks like it could have had a handle, like a wood lathe chisel. I'm guessing it is for making a specific profile on a wood lathe.
  8. It is great you still have that Tony. I have a few of my grandfather's tools.
    However it seems a little at odds sitting on a Toshiba lap and in front of a Samsung screen.
    1947knuck, Tony Martino and egads like this.
  9. spurgeonforge
    spurgeonforge
    A706A4C5-4F9C-4E18-A229-60E8EDB7D1AE.jpeg 490525CE-8554-403D-B729-3A76CB85A89B.jpeg My Little Giant power hammer and forge set up.
    BigRRR, 1947knuck, Okie Pete and 2 others like this.
  10. NoSurf
    NoSurf
    Here is a 1942, 1953 sheet metal pattern book I got from a retiring engineer here at work. He started out in the Merchant Marine and became a HVAC PE for buildings.
  11. I recently bought a Black and Decker NWA valve grinder like this, but mine is missing the valve stem grinding support on the right side. Would it be possible for you to get some detail pictures and a few measurements? If you could do so, and send them to me as a private message, I would greatly appreciate it. Would like to try to reproduce that part.
  12. oldpl8s
    oldpl8s
    I was looking at a pile of tools at a swap meet. Any tool on the blanket was $1. A guy picked up a strange looking tool and the seller said it was for cleaning the grooves for piston rings. When the guy p***ed on it I picked it up for a buck. HAMB-piston-ring-tool.jpg
  13. oldpl8s
    oldpl8s
  14. oldpl8s
    oldpl8s
  15. chevy57dude
    chevy57dude
    Snap On speeder from Opa, I rubbed some chalk in the letters to show the old font. 1534762803877340990385.jpg
    1947knuck, lothiandon1940 and NoSurf like this.
  16. NoSurf
    NoSurf
    "Hey, I was cleaning out my garage and I found some old tools. I was going to just toss them but I thought maybe you'd want them..."
    1947knuck likes this.
  17. 24riverview
    24riverview
    I can't resist these Ford wrenches when I can get them cheap, usually $3 or less. Have a dozen or more, about 6 or so different variations.
    1947knuck and Speedys Garage like this.
  18. KJSR
    KJSR
    from Utah
    Some cool stuff here guys. Thanks for posting.
  19. nosnhojguy
    nosnhojguy
    I just cleaned out an old garage and there were two bell shapped tools on attachment 9. What were they used for? Also in the bunch was the oldest set of finger pick up I have ever seen. Will try and post picture.
  20. TagMan
    TagMan
    Here's a couple of more oldies I found while cleaning out my barn. Top one is a 7/8" & 1" engineer's wrench and the bottom one is an articulated grease gun spout for the real early twist-on grease fittings.
    [​IMG]DCP_6114 by TagMan, on Flickr
  21. Ed Angel
    Ed Angel
  22. neatoldclassics
    neatoldclassics
    from Montana
  23. Here's a few handy ones that are still in use.
  24. chevy57dude
    chevy57dude
    How about Yankee screwdrivers?
    Lots of work!
    BigRRR, 1947knuck and lothiandon1940 like this.
  25. chevy57dude
    chevy57dude
    The name sold me on this one. 1535583973145-399085422.jpg 1535584048687-834002040.jpg
