Technical ***September 2018 Banger Meet - 4 Cylinder Equinox***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 31, 2018.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    September 9th, El Mirage
    September 14-16, Hot Rod Hill Climb
    Central City, Colorado
    September 28-30 ECTR-LSR THE ARKANSAS 1-MILE CHALLENGE
    The event is held at the Arkansas Aeroplex (The Blytheville-Gosnell Regional Airport) at 4701 Memorial Drive in Blytheville, Arkansas.
    October 2nd -5th, SCTA/BNI Bonneville Race World Finals
    October 21st, El Mirage
    November 10th - 11th, El Mirage
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $31.00 for color, $24.00 for B/W (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. denis4x4
    denis4x4
    from Colorado
    Waiting for my original ‘39-‘42 Ford logo brake shoes to be relined as the aftermarket stuff is WRONG!,,,
  3. RussTee
    RussTee
    Here also thanks.
  4. ROCKER77
    ROCKER77
    Checking in from the "armpit" of the south....
  5. Binger
    Binger
    from wyoming
    Checking in too! I have a little more than 300 miles on the new motor. It is running awesome. I am happy with the performance I am getting out of it. Thanks Bert’s. Hot Rod Hill Climb is just a few days away! I will see some of you up there.
    Jet96, brjnelson, winduptoy and 4 others like this.
  6. noboD
    noboD
    John, we need pictures at the hillclimb.
  7. V4F
    V4F
    from middle ca.
    pix would be nice
  8. I'm looking forward to the "Hill Climb", we'll be heading that way as well! Unfortunately not as a participant, spectator only!
  9. Binger
    Binger
    from wyoming
    I will post pics as I get them! We are leaving Thursday the 13th in the morning and driving down there. I am excited to be driving my banger there. I will chronicle the journey. Anybody coming through Cheyenne who wants to drive along? There are a couple of guys in town who are planning on driving with us.
  10. Been busy with work and planning for future but here are a couple pics from BVille this year.
    Busted a ring in the coupe on first pass, maybe gone a little too far.
  11. from the push truck heading off on 174+ run.
    Quite the Motley crew, none of this would be possible without them.
    Many Thanks to ALL, John
    cactus1, Jet96, Shutter Speed and 8 others like this.
  12. Following along from 10-UH-C. Hopefully will live to be 110 so I can work on mine.
  13. Check'n in! Turned in some good lap times at Laguna Seca the week before last; putting me in the second row on the Pole (3rd place). Thought I might be able to get by the "Pole Setter" as I had put that particular car "away" at Buttonwillow Raceway last May. However, on the fifth turn of the first lap, the engine began to crackle and occasionally backfire. I was passed by one car immediately; but held off others. Half way through the race, I got myself "sandwiched" between a couple of wandering "Back Markers". Without sufficient power, two more cars got by me. I finished sixth out of 32 finishers (I think forty had started). I and seven others had completed the full ten lap race.
    The culprit was a crack in the intake manifold (that I DIDN'T see) that had propagated to the point where number two carburetor and flange were barely hanging on! But we had fun!
    cactus1, Jet96, Shutter Speed and 4 others like this.
  14. callcoy
    callcoy
    Hard Day ?
    Not really, Friday found me in the city (SF) at Greg Martinez shop with him showing me his new tool, a line boring machine, an exceptionally well designed marriage of an old Kwik Way line boring machine with a (?) brand cylinder boring tool mounted horizontally. It is long but it is slick, came with at least 75 lbs. of tooling.
    We went thru the shop to select a block, pistons , rods and etc. to duplicate the record engine retired due to deck cracks. Had lunch and found everything we needed so I was able to hang the rods, boy those cur-clips are a bi#ch, cleanup to go to dinner.
    Greg dropped me off on the Embarcadero near the ball park had dinner with Pat Coyle Nor-Cal banger hill climber and our Cam Grinder. Walked over to the ball park to catch the Giants over power the Mets, not your average day around here, but beats doing yard work.
    winduptoy and Jiminy like this.
  15. TBone69
    TBone69
    from NJ
    Hey folks putting my first Banger together, do the head studs need sealer? Thanks
  16. It depends, I do not use sealer or silicone, I use some anti-seize to prevent damage.
    This will depend on the block, chances are if the holes have not been inserted or damaged the well on the bottom of the stud is sealed. If it has been "repaired" it may go into the water jacket, then sealant is necessary.
    YMMV, J
  17. The37Kid
    The37Kid
    Old Dawg, We saw your car in the pits again, some year we will meet. Thought I heard you slide and get sideways out of one turn. Bob DSCF0519.JPG
  18. Checking in - just got back to work after another spectacular Rømø Motor Festival... need to get the other G28T running, so car (or chassis, at least) has run this year!
  19. The37Kid
    The37Kid
    DSCF1140.JPG Got to get Dad's Roadster engine unstuck and running, another project on hold. Bob
    chriseakin, Dannerr and winduptoy like this.
  20. V4F
    V4F
    from middle ca.
    looks like it could be a nice looking motor
  21. winduptoy
    winduptoy
    Getting ready for the hill climb too...
    See you there John looking forward to it....
    brjnelson and Binger like this.
  22. winduptoy
    winduptoy
    I'll toss a lot out there for you
    Larry
    Hamtown Al, Dannerr and Binger like this.
  23. Yeah Bob! Sorry I missed you! I believe though that's me to the right of the photo, facing my wife (the tall lady in the turquoise top. I'm wearing a Fedora; and we're talking to Pam Shatraw, formerly with "Victory Lane" magazine and now Marketing Director for the Sportscar Vintage Racing Association (SVRA). Yes, you DID see me get sideways on Turn TWO (Turn One is a kink just after the track goes past the Start/Finish, under the Overpass). I "over-cooked" it trying to keep momentum due to the loss of torque because of the aforementioned manifold breakage. Note the light gray in the exhaust due to the lean mixture. On the "tear-down" there seems to be no damage. We've already repaired the intake manifold.
    Dannerr likes this.
  24. studebakerjoe
    studebakerjoe
    Old Dawg, saw a pic of your car in Automobile magazine article about Monterey. I think page 76 if I'm not mistaken.
  25. studebakerjoe
    studebakerjoe
    Oops forgot to say its the September/October issue
  26. The37Kid
    The37Kid
    That girl in the sun glasses is my daughter who treated me to the trip. Same girl in 1982 in my Riley 4Port. Working on my '39 pickup today so the trip was motivational. ;)Bob
    Tim, Shutter Speed, Jet96 and 2 others like this.
  27. Thanks, I'll check it out!
  28. I was going to say! I DO remember her. And, you MAY have had a nod from me, as I remember someone (YOU) with her! Dang me! Ain't life funny?
    Our youngest daughter (having just moved from Wash. D.C. to Pasadena CA) was with us. She's gotten bitten by the"racing bug"! So "Old Dad" here is going to take her to The Univ. of VARA in February (where I'm a volunteer instructor) to see if she's really serious about it......Just keep "wrench'n", Bob....I think that's what might be keep'n us old guys young!
  29. Here's a video of what Bob and his daughter saw at Monterey, Other than mine, there were three other Ford "Bangers" in the race. There were a number of other old "Bangers" too!
    Enjoy,
    Jet96 likes this.
