Technical Can a cracked piston be welded?
Discussion in 'The Hokey Ass Message Board' started by Dirty30Dodge, Sep 2, 2018.
  1. Dirty30Dodge
    Dirty30Dodge
    These are old Chevy 302 Pistons pre DZ. I pulled them from a small journal 327 that had a steel 283 crank. It was in my 57 Chevy that I found in garage parked in there since the late 70's. I wanted to sell the Pistons then noticed this crack. Can it be welded? I am not certain if they are forged. They have a weighted steel plate one each side were the pin goes through? Which is behind the crack in the 1st picture.
    [​IMG][​IMG][​IMG]
    kidcampbell71 likes this.
  2. goldmountain
    goldmountain
    It wouldn't be worth trying. Would you feel comfortable with an engine that could possibly grenade on you?
    dana barlow likes this.
  3. i'm sure they are cast
    Max Gearhead and squirrel like this.
  4. Unkl Ian
    Unkl Ian
    Nobody want to buy a welded piston.
    GuyW likes this.
  5. Unkl Ian
    Unkl Ian
    Yes, I have heard of people welding pistons.
    Generally, holes in domes.
    Distorting ring lands is a potential problem.
  6. BadgeZ28
    BadgeZ28
    from Oregon
    Don't chance it. You are lucky you have a motor that has literally dozens of piston manufactures offering a white array of options. I image stock cl*** racing requires pistons similar to what was stock.
  7. KenC
    KenC
    Cast piston. Most common small block crack ever. I've seen all 8 cracked on early 265/283s 'back when'. The steel strut inside is for expansion control and is one of the many reasons welding is a bad idea.
    Hnstray and Unkl Ian like this.
  8. sbtslick
    sbtslick
    from Washington
    The cause of the notorious “Piston Slap” unlike the more common “Rod Knock” (bad bearing) [emoji41]
  9. Jethro
    Jethro
    Looks like it had a little"kiss" too
  10. Deuces
    Deuces
    That piston is nothing more than a .125" over 283 piston...
    Egge probably sell those....
  11. Dirty30Dodge
    Dirty30Dodge
    Ok Thanks - I was under impression it was a specific piston for the 302 stroker only. They are pretty expensive. If it's just a 283 piston then it's just another piston.
  12. Sure, bring it over I'll weld it up. I'll also strongly advise that you do Not try to use it again in a motor. In the over all cost of building Cars the cost of pistons is relatively Cheep.
    The Wizzard
    Just Gary likes this.
  13. dreracecar
    dreracecar
    from so-cal
    The cast material being of this age and being run has sooooo much contamination inbeded into the material that the weld becomes garbage and pitted, welding the crack will expand the alu and then when it cools will shrink it more then when it was expanded
    clem, Black Panther and Pist-n-Broke like this.
  14. DDDenny
    That is even pre "MO" 302!
    Deuces likes this.
  15. Jimbo17
    Jimbo17
    This is a bad idea to even consider doing.
    You have to know when to say forget it!!!
    Jimbo
  16. RMONTY
    RMONTY
    Burt Munro would weld it up....and go over 200 mph with it!
    Atwater Mike, clem, Torana68 and 4 others like this.
  17. jimmy six
    jimmy six
    In my day a .125 over 283 was a 301...;)
  18. Dirty30Dodge
    Dirty30Dodge
    Thanks! Glad I had noticed the crack before I tried to sell them. Paper weights, trophy art 4 sale lol like you guys don't have a few of these laying around lol thanks
  19. Same bore/stroke as the 302 Z motors. Chevy didn't want it to look like the hot rodders came up with it years before they did, so they upped the 301.? to 302. LOL
  20. NO! And even if you did the skirts look like they're trashed anyways.
  21. DDDenny
    Yeh, at 8000 rpm what possibly could go wrong!
  22. R Pope
    R Pope
    New SBC cast slugs don't last long enough!
    Atwater Mike and Deuces like this.
  23. Deuces
    Deuces
    Same thing!.....;)
  24. Mr48chev
    Well you can do like a buddy of mine did with hundreds of them in his shop. pull the rigs off smash them from the side, take out the steel piece and sell the broken pieces for s**** by the five gallon bucket load. He did it because it paid a few cents more a piston when he hauled a load of s****. With the skirts scuffed up like that the decorative item thing might be the other way to get a buck or two.
    Genuine .125 over 301 Piston from the late 50's for use as a paperweight.
    In the early 70's you could buy a 302 Chevy block from Chevrolet for around 300 bucks that was a new 302 block with Z28 pistons fitted to the bores I helped a friend in Texas put one together and it ran like a bandit. He used a 283 crank and rods along with a pair of 202 camel hump heads. He had less than 500 1973 dollars in that engine when it was done, new cam lifters and all.
  25. Ya, but only once!
    The Wizzard
    RMONTY likes this.
  26. oldolds
    oldolds
    Some of Burts pistons. From World's Fastest Indian
    Unkl Ian and Deuces like this.
  27. woodiewagon46
    woodiewagon46
    from New York
    Anything can be welded, but why would you even think of building an engine with a repaired piston. I wouldn't trust it. If it lets go think, of the consequences.
    Deuces likes this.
  28. saltflats
    saltflats
    from Missouri
    That must of been a tough piston, most that I have seen, the skirts are laying in the pan.
    Take it to your local fair and have that guy that welds up those soda cans do it for you. :D
    Deuces and X-cpe like this.
  29. I would like to have a set of .020 or .030 oversize 302 pistons. so I could bore a small journal 327 block and use a 283 crank. A famous engine builder once stated if you can turn a 1000 RPM more than everyone else. All other things being equal you will beat them. I suppose I will just use the 327 pistons I already have. 327 pistons 001.JPG 327 pistons 002.JPG
    Deuces likes this.
  30. 56sedandelivery
    56sedandelivery
    301= pi as 3.14.
    302= pi as 3.141590265359 (although it can be taken out to 1 million digits).
    take your pick, it's only math. They both had a 4 inch bore block.
    Really old cast pistons, and the first design small journal rods also.
    I am Butch/56sedandelivery
