Projects Almost Funny - AWB Barracuda Funny Car Build
Discussion in 'The Hokey Ass Message Board' started by squirrel, Nov 27, 2017.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    Awesome, epic! Congrats on the amazing results so far.
    chryslerfan55, Stogy and loudbang like this.
  2. Deuced Up!
    Deuced Up!
    Amazing first drive and she got Christened too! Lol. Awesome work!
    Sent from my SM-G930V using The H.A.M.B. mobile app
  3. squirrel
    thanks guys! It might look like I did this quick, but there was a lot of time spent thinking about how to do things, over the past two years.
    And I still dont know if it'll go more than a few feet :)
    But I did get the windshield wiper working this morning.
    catdad49, OahuEli, raven and 16 others like this.
  4. 1934coupe
    1934coupe
    Good Luck Jim! I wasn't looking and in 14 hrs you started it and moved it, Great Job.
    Pat
  5. OK Jim, When did you really start building it.
    You make the rest of us look like slackers.
  6. GordonC
    GordonC
    I thought Jim had this pristine shop but did anybody notice that pile of stuff when he pulled the Cuda back inside! Must have been in a rush to fire that beast up and hadn't cleaned yet...:D
  7. woodbutcher
    woodbutcher
    :D Hi Jim.Looking good and sounding good.Now the fun begins.Onward and upward.
    Good luck.Have fun.Be safe.
    Leo
  8. AHotRod
    AHotRod
    The car looks spot-on Jim, well done.
  9. Doctorterry
    Doctorterry
    Well said
    brad2v, chryslerfan55 and loudbang like this.
  10. milwscruffy
    milwscruffy
    Going into Drag Week well rested still makes for a very long week. I can't imagine how long your week will feel for you. I'm tired just thinking about it....
    chryslerfan55, squirrel and loudbang like this.
  11. Tim
    Tim
    from KCMO
    Unreal doesn’t even come close to touching it
  12. Nostrebor
    Nostrebor
    The video commentary... "Neat." Hahaha!
    That word sums up your personality. You just soldier through.
    If you quit right now, you've already won. Now keep going!:D
  13. 30tudor
    30tudor
    I think everyone around here is pretty impressed with how this is all going down. I know I am. Thanks for all the dialog and pictures.
  14. Doctorterry
    Doctorterry
    Jims project less than a year apart
    [​IMG][​IMG]
    My project in the same time span [​IMG] [​IMG]
  15. Jim, Can you tell what the converter feels like? Did you check the gears on jackstands, off camera?
  16. wrenchbender
    wrenchbender
    Jake you have made a ton of progress on your car for a guy doin it the first time Jim has a small amount of experience doin this before lol. Jim the car looks and sounds awesome good luck on drag week I will try to follow along and live vicariously through you guys
    chryslerfan55, Doctorterry and enloe like this.
  17. squirrel
    I took it for a short drive, almost a mile, low speeds...not sure yet how it feels, there are some issues with the engine, like, not running right at slightly higher rpm...I haven't really had it spinning fast enough to feel it engage the converter fully.
    also it wasn't charging, so we're wiring up the voltage regulator properly, and I changed out the condenser to see if it runs better (I don't have the right one for the distributor, so I added an external .22 uf)
    also the dipstick for the trans is iffy, and I haven't checked the fluid level properly, I think it's a bit low still.
    catdad49, Thor1, Sancho and 3 others like this.
  18. blowby
    blowby
    from Nicasio Ca
    I'll be curious how dialed in you can get it riding and handling wise. Lots of highway miles to cover I believe, not to mention the strip.
  19. ClayMart
    ClayMart
    Well it's not a "Fish Out Of Water" anymore, is it. All the moldings, nameplates and fender emblems really put this project over the top. :cool:
    Hnstray, chryslerfan55 and enloe like this.
  20. squirrel
    thanks!
    Yes, it's going to be a fun drive...
    been tinkering with the ignition system, it's still not running right. Time to jump in the time machine, and think back to all the things that went wrong in the old days.
    we have so far swapped out coil, condenser, ballast, and played a little with the point gap. The points might be ****py, they are new. It seems to cut out a bit over 2000 rpm, the timing light goes all over the place, tach jumps around, and it runs really rough. It sure sounds like an ignition problem.
    catdad49, Thor1, Sancho and 5 others like this.
  21. Baumi
    Baumi
    It´s great to see that car moving under itsown power.
    What an accomplishment. When I ( ever) grow up, I wanna be like you, hahaha, but that ´ll still take a couple years. You´ve got the skills, the creativity and the motivation it takes to do what you love on a non NASA budget, even if that´s somewhat exhausting. My hat and all my respect is off to you!
  22. saltflats
    saltflats
    from Missouri
    Have you tried running it on one set of points?
    enloe likes this.
  23. blowby
    blowby
    from Nicasio Ca
    You should hang that little tailpipe back on it.
    With a wheelie wheel bolted through it.
  24. squirrel
    I fixed the ignition problem. just defective new parts, they installed the contact strap, but not the spring strap. that was fun.,. I found the old points in the garbage can, filed them, put them in, and it runs great.
  25. Ebbsspeed
    Ebbsspeed
    How do they miss putting the spring strap into a new set of points?
    Stunning execution, and incredible speed at which you built this car! Best of luck during Drag Week!
  26. enloe
    enloe
    from east , tn.
    I am planning on being there on the last day.
    Doctorterry likes this.
  27. The excitement is mounting.
    Stogy likes this.
  28. ClayMart
    ClayMart
    I'm surprised you could even see 2 grand with just the contact strap! :eek:
  29. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Those look like the exact same points that I changed in my little M***ey tractor . Same problem so I filed and put the old ones back. lol I got mine at the NAPA I work at on Sundays. You would not believe how may different applications those fit over the years. And yes they are made over seas. Larry
  30. squirrel
    little video. We're working on the wheelie bars, and the fan shroud, and the hood, right now.
