History When did flip front ends start becoming popular?
Discussion in 'The Hokey Ass Message Board' started by II FUNNY, Sep 4, 2018.
  1. II FUNNY
    II FUNNY
    I’ve been looking through vintage drag race pictures on George Kl*** remembers and here, and I’m not seeing as many flip front ends on full bodied drag cars as I figured there would be. When did they start showing up? Removable hoods seem pretty popular, but flip front ends not so much...
  2. I don't rightly know the answer. A flip front makes engine bay access much better. However a steel flip front weighs about as much as a stock one. some racers acid dipped the sheet metal to make it thinner & lighter. The fibergl*** made a considerable weight saving. and that weight could them be shifted rearward where it helped traction.
    chryslerfan55 and seb fontana like this.
  3. IIRC, flip-fronts were fairly rare until the mid-late '60s when fibergl*** parts became more readily available. Even then, it was the '70s before they became 'common'.
    The Shift Wizard likes this.
  4. Elcohaulic
    Elcohaulic
    I remember them more in the late seventies and eighty's..
  5. willys36
    willys36
    I recall them becoming popular on Willy g***ers. n the late 50s thru the mid 60s, Willy g***ers were the fastest, most popular door slammers on the strip. AI Fibergl***, Cal Automotive Fibergl*** and a few others started making fibergl*** front ends for them and they became the standard. It took off from there I think. The racers at the time went the lift-off route, it is only us modern g***er wannabes who do the tilt-up versions.
    Prock & Howell kinda took it to the limit!!
    Boned Dubach & Pisano -66-Nats2Medium.jpg boss hydro 2.jpg Coonrod2.jpg hamberis & Mitchell 3.jpg Littlemans fury1.JPG Merkel tune.jpg ohio george 1.jpg
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    I bought one for about $100 for my 57 Chev in 68 so they had. Have been real com!on by then. ( This is central il !!!)
  7. fitznstartz
    fitznstartz
    from mesa az
    It's not a drag car but I built a tilt front end for my F4. DSC_0014.JPG DSC_0011.JPG
  8. II FUNNY
    II FUNNY
    Thanks for the replies...it seems like a completely removable front was way more common in the early to mid sixties.
    squirrel and chryslerfan55 like this.
  9. 1946caddy
    1946caddy
    from washington
    Back in the late sixties, the was a guy in town that raced a 57 ford who built his own tilt front end. He would get the car running great in the pits and then close the hood and head for the strip only to have it die and not start up again. Up goes the tilt front end and he and his crew start checking everything out. They can't find anything wrong and it starts right up. The hood goes back down and again, it only runs for a few seconds and dies. This happens several more tines and finally they give up and are ready to pack up and head home. This young kid about 14-15 years old walks up and starts looking at the car and makes the comment. When you close the hood, doesn't it pinch the gas line off.
  10. Blue One
    Blue One
    from Alberta
    For me personally the answer would be never. :D
  11. They never became "popular" until the late 60's when a few fibergl*** companies began to sell them ready to go and they were no longer a custom made item. (Naturally, there were always a few custom ones around that the big fibergl*** stores didn't stock.) I knew a few hobby racers who bolted stock metal hoods and fenders together to emulate the look of the fibergl*** just because they had the parts and didn't have to buy them. In many cases, they didn't even have to paint them. Yes, the "metal" guys got the convenience to repair and tune at the track, even pull engines, but I'm going to say that was secondary to getting the look.
  12. II FUNNY
    II FUNNY
    I’m not a big fan of how they look, but the ease of working on the car in the pits is definitely a bonus. I’m going for a built to run in 1963 look, so I wanted to make sure before I proceeded to go this route.
  13. badvolvo
    badvolvo
    C5,6,7 fused together, 3 bulging discs, 1 cist in my lower back. I love my flip front end! It's the only way I can work on a fat fendered car.
    swade41 likes this.
  14. II FUNNY
    II FUNNY
    Something along these lines...
    chryslerfan55 and 41 coupe like this.
  15. slayer
    slayer
    Kip, All these pictures are from 1965 to 1967. I cant find any pictures from earlier then that with tilt front ends. Do you have a project to start on now, or are you making plans first? FredHurstA-GasOct1967.jpg Quicksand Harder bros.jpg shake rattle & run @ the beech.jpg Studabaker.JPEG
  16. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    My uncle had one on his 55 in 1967. A book I have on the g***er wars Shows a lot of cars having them by 63 to 64. Larry
  17. II FUNNY
    II FUNNY
    I went to the dark side Eric...I picked up a real solid 48 Plymouth coupe...
    chryslerfan55 and slayer like this.
  18. II FUNNY
    II FUNNY
    I’m hoping to end up with something along the lines of this one...but this one is powered by a 327 Chevy, and I went dark side completely...mines gonna be RB powered.
  19. II FUNNY
    II FUNNY
    I’m trying my best to not have any parts that weren’t designed before 1963...I’m not going so far as to get date matched parts. I don’t have the time patience or money for that. I am trying to reuse as much of the car and other old parts I’ve gathered. like the rear diff. It’s a Dana 60. They came out in 55 in Ford trucks, but mine is newer...the motor is a 440 from a motorhome, but done correctly most people can’t tell a 440 from a 413. It will have steel wheels all around, and stiff wall rear slicks with bias ply Firestone’s up front. The ladder bars are long...way long like the GB performance 40 Chevy and the Colson and Wood Studebaker. It will also have a quarter elliptical rear suspension like those two cars had. It still has the stock master cylinder (new of course)and I’m running chevy drum brakes up front and stock rear drums too. I flipped the pitman arm to the back and moved the steering box ahead, and it seems like it will work perfectly, so I won’t need to go corvair or something else. It’s not going to be too radical to drive on the street though. I don’t have the money for two cars, so my hot rod will have to do both street and strip.
  20. slayer
    slayer
    AH HA! Under cover MOPAR fan exposed!
    All kidding aside that's an awesome start! You have a great eye for what looks period correct and your attention to detail is second to none. I totally understand the street/strip dual purpose car. Both the Valiant and the coupe are street cars first. Keep up the good work and post some progress when you get a chance.
    Dad and I stumbled across this 50 Plymouth on the south side of Chicago a year after picking up the Dodge coupe or it would have been our next project. It was an old drag car that supposedly ran an early Hemi at some point. 1950 plymouth gasser.jpg
    chryslerfan55 and II FUNNY like this.
  21. II FUNNY
    II FUNNY
    I’ve always respected Chrysler’s drag race program through the 60’s and 70’s , so I guess I’m a closet mopar fan.lol
  22. slayer
    slayer
    What plans do you have for induction? Any factory cross ram short or long would look the part, but no doubt be pricey. An in line dual quad intake could get the job done cheaper and still have the vibe your looking for. Are you going with a Torqueflite or manual? A push ****on shifter would be killer in there.
  23. II FUNNY
    II FUNNY
    I have an edelbrock in-line dual quad and a 727...eventually a manual trans would be nice, but I have the auto already...
  24. II FUNNY
    II FUNNY
    Going for this look...
    Ned Ludd and chryslerfan55 like this.
  25. seb fontana
    seb fontana
    from ct
    I made the fibergl*** nose for my shoebox in 1976 because I didn't want to cut the steel fenders for it to tilt.. Made a mold off the original nose and had a boat manufacturer lay up the mold. I did all the finish work; inner frame structure, etc. It is 45 years old this year ..To me a necessity when you set the engine back the allowable 10%.
  26. II FUNNY
    II FUNNY
    I already made the parts to make mine tilt, and they’re installed. I figure on leaving it, and bolting the fenders on. That way if I need to do serious work a few bolts and I can get to everything easy. My engine is back 7%. That is a far as I could go and keep the stock pedal ***embly and also abide by the maximum seat relocation of 4” as per the gas rules.
    Almostdone and chryslerfan55 like this.
  27. II FUNNY
    II FUNNY
    Here’s the ladder bars. They’re non adjustable and 84” long. They are way wrong by today’s standards, but they are shorter than the ones on the Colson and Wood Studebaker that was built in 62.
  28. swade41
    swade41
    from Buffalo,NY
    Exactly why I have 2 cars with tilts and one roadster with nothing but a radiator shell up front.
  29. 1924776_985759121505594_2715609998719288206_n.jpg 1924776_985759121505594_2715609998719288206_n.jpg 1924776_985759121505594_2715609998719288206_n.jpg pic from '80's - a buddy had it for a minute - 327/4 speed - was supposed to be built in '70's in Winchester, Va. - A guy in Hoppers Car Club had it , it was gray with a Confederate soldier on deck lid - was sold & painted resale red - my buddy got it & sold it - where is it? I want it!
  30. finn
    finn
    They became popular beginning in the very early sixties and were ubiquitous by the mid to late sixties.
    Quality of most was pretty sketchy, though. Flimsy is probably a generous way to describe most of what was available.
