Technical Distance from ground to I-beam
Discussion in 'The Hokey Ass Message Board' started by Fairlane3x43, Sep 6, 2018.
  1. Fairlane3x43
    Fairlane3x43
    from Michigan
    If using a 26" tall tire and have a 3 1/2 inch drop front beam would my ground clearance be 9 1/2 inches from ground to the I-beam? Don't have the parts yet so that's why I ask. Trying to decide on tires.
  2. oldolds
    oldolds
    Depends on the axle. Some drop lower in the center, some are straight across.
    lothiandon1940 likes this.
  3. Happydaze
    Happydaze
    My understanding is that the stated drop is the additional drop from the original.
    With the numbers suggested I expect the under axle clearance to be a good bit less than 9.5" !!
    Chris
  4. oj
    oj
    The math would be to the center of the spindle/axle; the 3 1/2 is total drop so it'd be 9 1/2 to the center, not the bottom of the axle. But math and hot rods don't always agree.
    lothiandon1940 and sidevalve8ba like this.
  5. continentaljohn
    continentaljohn
    I have 7 1/2 on mine but with a old original drop axle so it looks like a 3 or 4 inch drop
  6. wbrw32
    wbrw32
    Mr Fairlane......Please complete your profile page then Read the rules of the HAMB,,,,,
    lothiandon1940 and hrm2k like this.
  7. LAROKE
    LAROKE
    I have a 4" dropped axle on my '55 1st Series Chevy pickup. If my 6.50x16 front tires go flat, I'll be plowin' asphalt.
  8. continentaljohn
    continentaljohn
    What are you building matters on tire size for the Look:D
  9. town sedan
    town sedan
    Not a bad idea thinking about tires early on, but I'd suggest waiting till you need them before buying them.
    Knowing the size(s) will allow you to mockup the suspension, but your tires will be fresh when you start driving on them. Besides you may change your mind. This is just something told to me by folks who have done much more of this than I have.
    -Dave
  10. sunbeam
    sunbeam
    Most States don't like cars that s****e the ground if a tire goes flat. I personaly would not drive one.
  11. lothiandon1940
    lothiandon1940
    Unkl Ian, upspirate and Jibs like this.
  12. Fairlane3x43
    Fairlane3x43
    from Michigan
    This is for a 32 Ford 5 window coupe. Not sure if I should get the 15" rims or the 14" rims for the car. Two inch difference in tire diameter. I have nothing but the motor as of now. Frame is ordered with a Pete and Jakes I-beam and axle set-up.
  13. nochop
    nochop
    from norcal
    I build mine so if all 4 tires are flat nothing would touch pavement, aka scrub line
    pitman likes this.
  14. 19Fordy
    19Fordy
    Your question confuses me. Are you currently using a dropped axle? If so, how much is it "dropped".
    Then add tie size and type of front spring.
    What kind of car and what is your goal regarding stance?
    Don't use 14 inch tires. 15's are ok.
  15. pitman
    pitman
    15 inch dia. May save from a slide, into the woods!
  16. Dreamweaver
    Dreamweaver
    I'd call and talk to either who you ordered your frame from or P&J. They should have an excellent feel for tires sizes and clearances in a completed car.
    14" rim may not clear your brake calipers if using front discs and much more choices in 15" rims.
  17. nobux
    nobux
    With a Socal 4" drop axle and 26" tires, I can't get my floor jack under the axle without running the front tires up un 2x6s. So, 9 1/2" is being grossly optimistic.
  18. adam401
    adam401
    14" wheels look super modern and lame on an early hot rod. 15's certainly have their place but 16s my friend look right at home. I always feel like a 6.00 16" tire looks mint due to it being the factory size if the 40 Ford. Throw a 7.00 or 7.50 16" on outback and its nailed in my book. For reference
    1536258230460156273311.jpg 15362582977421455861447.jpg 1536258366578805156151.jpg
  19. Fairlane3x43
    Fairlane3x43
    from Michigan
    Thanks. I will call the frame shop and P&J to ask what they have been using.
  20. BJR
    BJR
    Some of you need to look up scrub line. If your car does not comply with it, what you are driving is very dangerous.
    nochop likes this.
  21. Happydaze
    Happydaze
    I think you mean scrub line, but hey, I know what I think you meant!
    Chris
    BJR likes this.
  22. BJR
    BJR
    Yes I did thank you, and I fixed the original post.
  23. 19Fordy
    19Fordy
  24. LAROKE
    LAROKE
    Thanx Mom.
  25. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Mock it up with bare roller rims, or rollers with approximate size tires, then eyeball and go from there.
  26. LM14
    LM14
    from Iowa
    With 26” tall tires on my Pete and Jakes front with a 4” dropped Alum-I-beam axle I have right at 5” from the ground to the bottom of the axle. The loaded sidewall height of the 165/80R15 tires is 4”.
    SPark
    DC2594F8-B0B9-4EA9-8367-91F402A56B33.jpeg FDB9B557-62FB-4E17-BF46-57F103D2F65F.jpeg
    akoutlaw and lothiandon1940 like this.
  27. BJR
    BJR
    My point exactly.:p
  28. Unkl Ian
    Unkl Ian
    14" tires are getting harder to buy.
    Maybe go with 15" and 16" ?
  29. 51 mercules
    51 mercules
    On my Model A I have a six inch super bell dropped axle and running Firestone 16x5 inch dirt track tires that are about 26 inches tall and have 5 inches from ground to the bottom center on my axle. Only have about 3/4 of inch for the scrub line.[​IMG]
  30. LAROKE
    LAROKE
    It's in mock up. Still plenty of time to iron out the bugs. Maybe weld castor wheels on the bottom of the axle :D
