Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    Welded on the switch pod...
    Cut holes / welded bolts for gauges... 20180907_161434.jpeg 20180907_161811.jpeg 20180907_204434.jpeg 20180908_102426.jpeg
    Sent from my SM-G930T using The H.A.M.B. mobile app
    brEad, OahuEli, patmanta and 3 others like this.
  2. Stogy
    Stogy
  3. 340HilbornDuster
    340HilbornDuster
    brEad, kidcampbell71, Stogy and 3 others like this.
  4. 340HilbornDuster
    340HilbornDuster
    No noise..yet!
    Rear axle plug stuck / rounded.
    Welded a nut to it...
    Cause o stance...had lift up the front to get 2 quarts in there 20180912_181055.jpeg 20180912_203437.jpeg 20180912_213325.jpeg 20180912_213810.jpeg
    Sent from my SM-G930V using The H.A.M.B. mobile app
    kidcampbell71, AndersF and Stogy like this.
  5. Stogy
    Stogy
    340 there's a thread for that cool shot...;)
  6. Stogy
    Stogy
  7. 340HilbornDuster
    340HilbornDuster
    Organized / labeled relays
    Shoulduv dunn this before i put the back dash in...!
    brEad, kidcampbell71, Russ B and 2 others like this.
  8. 340HilbornDuster
    340HilbornDuster
    Starting to make sense again...
    Back board ~ year ago...
    Drawings 20 + changes later...
  9. Stogy
    Stogy
    Ugh...:rolleyes:...I'll take drilling holes and installing rivets...but if that's your forte...good on you...;)
  10. 340HilbornDuster
    340HilbornDuster
    It's past 2am...There's the f****** problem.
    E-bay site listed the colors wrong...!!
  11. 340HilbornDuster
    340HilbornDuster
    Should have taken that ****er out long time ago... relay Fu fixed - back to finish wiring.
    Pic Behind that mess.... 20180915_105508.jpeg 20180915_105440.jpeg 20180914_224414.jpeg
  12. 340HilbornDuster
    340HilbornDuster
    Thought I had it...then this...two batches...none them standard...
    ....F#&#^^ C#&$%
    If i'd just checked from the begining!!!
    brEad and Dannerr like this.
  13. 340HilbornDuster
    340HilbornDuster
    Every time you do something ...
    brEad, OahuEli, Dannerr and 1 other person like this.
  14. Dean Lowe
    Dean Lowe
    That's why I don't do wiring. Life's too short.
    brEad, kidcampbell71 and Stogy like this.
  15. 340HilbornDuster
    340HilbornDuster
    Smart Man You!
    No car show today either....and here comes the rain...
    Maybe a short shake down tomorrow...never know?
    F...ing Relays finally works!
    Everythings got power except the Starter...!?....tired! 20180915_185953.jpeg 20180915_184619.jpeg 20180915_184651.jpeg
    brEad, LAROKE, tomkelly88 and 4 others like this.
  16. Stogy
    Stogy
  17. 340HilbornDuster
    340HilbornDuster
    Stogy likes this.
  18. 340HilbornDuster
    340HilbornDuster
    Everything works!
    Now i just have to find my "Old-School" DB9 to DB9 cable!
    brEad, LAROKE, AndersF and 2 others like this.
  19. Stogy
    Stogy
    Having an evening drive I see how fast are you going...:rolleyes:...glad to see your getting through the ups and downs.
  20. 340HilbornDuster
    340HilbornDuster
    Always said I'll report both when I'm doing good and when I Mess things Up!
    I'm Learning!....Sometimes the Hard way!..but it's still FUN!
    Stogy, AndersF and Dannerr like this.
  21. 340HilbornDuster
    340HilbornDuster
    Hilborn injector hoses to bench bleed the Master Cylinder....looks like the rear circuit is bad!!!...swap meet find...guy said it was re - built... 20180922_135430.jpeg
    Stogy likes this.
  22. Stogy
    Stogy
    :(...I can think of several responses to this outcome...none are very pleasant to hear but I'm sure you have vented your frustration already...hopefully you can repair it...is that feasible?
  23. 340HilbornDuster
    340HilbornDuster
    E-Bay.....
    Stogy likes this.
  24. Stogy
    Stogy
    My Missus does a fair bit of E thing. She Paypals it and many times has issues and generally comes out protected...I am sure this may be time related and I know we tend to get stuff and it could be a while before we set it up...so this may complicate the situation albeit it is all legit you just want a functioning item. Did you send the seller a message as they have a rating to protect...
    and defective product with no recourse doesn't help them as bad reviews add up.
  25. 340HilbornDuster
    340HilbornDuster
    I've had a 99% success rate with E-bay / PayPal!!...the 1% bad i always got my $$ Back...
  26. 340HilbornDuster
    340HilbornDuster
    Foldable O2 sensor bracket...doesn't match the dash look.... 20180923_201943.jpeg 20180923_202403.jpeg 20180923_202410.jpeg 20180923_202452.jpeg 20180923_202458.jpeg
    brEad, Tim_with_a_T, AndersF and 2 others like this.
  27. 340HilbornDuster
    340HilbornDuster
    AndersF, brEad, Stogy and 1 other person like this.
  28. 340HilbornDuster
    340HilbornDuster
    Mopar plugs...not much more $ than Oh' Realy's.
    Slightly longer than Bosch & not that annoying screw on top...solid...
    Clean up wires a bit... 20180925_203227.jpeg 20180925_210452.jpeg 20180925_205710.jpeg 20180925_211929.jpeg
  29. brEad
    brEad
    Been a while since I checked in here. Car looks great - you’re almost there! Looking forward to updates.
  30. 340HilbornDuster
    340HilbornDuster
    Troubleshooting...
    Unilite's good!... tested in the Duster.
    Same model number different height? 20180929_154539.jpeg 20180929_154638.jpeg
    patmanta, Stogy and Dannerr like this.
