Technical Broken bolt removal
Discussion in 'The Hokey Ass Message Board' started by nickleone, Sep 9, 2018.
  1. nickleone
    nickleone
    Interesting video
    Nick
  2. Casey Riley
    Casey Riley
    from Minnesota
    Use some kind of bushing as a drill guide to drill broken bolt and use the time honored EZ-Out extractor... I didn't see anything out of the ordinary.
  3. saltflats
    saltflats
    from Missouri
    You know they come out easy, the dang parts are settin on the bench. Try that in a very limited space under the hood.
  4. Neat
    Never understood why they are called “ easy outs”
    Should be called “ haha you’re ****ed”
    mikhett, slayer, williebill and 8 others like this.
  5. bobss396
    bobss396
    I had a guy I know that owns a shop ask me to look at a busted bolt on a late model Mopar truck exhaust manifold. Long story made short, the manifold winds up at my house strapped to an angle plate on the mill to be drilled out. Standing on your head with limited access is how most busted bolts are located.
    IMHO only a hack uses an adjustable wrench to work a tap....
    saltflats and Casey Riley like this.
  6. Casey Riley
    Casey Riley
    from Minnesota
    That exact same thought went thru my head.
  7. saltflats
    saltflats
    from Missouri
    Lucky me, I get to fix them on the car. :(
  8. But of course he isn't working a tap.
  9. fiftyv8
    fiftyv8
    from CO & WA
    That video helps to keep the arm chair experts and dreamers happy...
    28dreyer likes this.
  10. noboD
    noboD
    Too bad he doesn't speak English.
    Center of the Galaxie likes this.
  11. G-son
    G-son
    from Sweden
    In swedish they have the nickname "grispitt", and that translates to "pig d*ck".
    VANDENPLAS likes this.
  12. Casey Riley
    Casey Riley
    from Minnesota
    I learned about pigs having a corkscrew ***** from Marty Stauffer on Wild America
  13. ]That exact same thought went thru my head.
    Hey said he left the proper wrench at work.
  14. Fortunateson
    Fortunateson
    Well I think it's an ok video as it is useful to the young ones on the forum who may not have this knowledge or experience.
  15. fiftyv8
    fiftyv8
    from CO & WA
    Yes, you are right, but folks who have been around the block a couple of times will tell you, in real life there is usually a lot more to dealing with what this video shows as simple and easy.
    Generally, when something is broke in a threaded hole it usually means it is stuck and broke for a reason.
    This video makes light work of what is supposed to be a stuck bolt, yet they all come out so easy.
    However, the philosophy is worth noting and keeping in the memory bank for that particular situation.
    zzford likes this.
  16. revkev6
    revkev6
    from ma
    working at a machine shop and knowing the hell it is to remove an easy out, I've never tried one. always found alternative ways. that deep recess looks tough though.
  17. saltflats
    saltflats
    from Missouri
    I have had good luck with these.
    VANDENPLAS and zzford like this.
  18. Fortunateson
    Fortunateson
    Yep, Easy Outs are not my friends and when they break good luck. I like the left hand twist drill bits and of course the welding nuts to the problem area if possible. But I know my limits and sometimes off to the machine shop I go. I'm hesitating removing smog type exhaust manifolds on an ot truck and replacing with non-smog because I know I'll brobably break a bolt!
  19. tb33anda3rd
    tb33anda3rd
    al-you-min-knee-um? or a-loo-men-um?
  20. Well, despite all the negative comments, I like the idea of the bolt with the hole in the center, if for no other reason than to be able to drill out a broken stud without the hole getting off center. I'm gonna make up a set today.
    Bugguts, clem, ClayMart and 2 others like this.
  21. noboD
    noboD
    Me too. When friends would call and say they broke a bolt and wanted me to get it out I would tell them if they already broke an EZ-out to take it somewhere else. If they broke a bolt and brought it straight to me without screwing it up I could help them.
  22. We call them ****youovers at work!
  23. tb33anda3rd
    tb33anda3rd
    "easier to fix the damage created by mother nature, than the damage created by the last mother ' that worked on it"
  24. H380
    H380
    from Louisiana
    Left hand drill bit set. Works most of the time.
    paul philliup likes this.
  25. Fortunateson
    Fortunateson
    Exactly!
  26. Casey Riley
    Casey Riley
    from Minnesota
  27. 56don
    56don
    They are a great idea. I actually came up with that idea myself a few years back and made up a set of every size from 1/4 through 5/8. They need to be made on a lathe though so you can be sure the hole is in the exact center.
  28. Yeah, I made up a few on the lathe today. Now that I have them ready, it's a pretty sure thing I'll never need them.
    56don, clem and G-son like this.
  29. saltflats
    saltflats
    from Missouri
  30. Beanscoot
    Beanscoot
    Easy-out - the world's most ironically named tool.
