Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. 1947knuck
    1947knuck
  2. Deuces
    Deuces
    No vacuum secondary pod for the front carb.....:confused:o_O
    mad mikey and saltflats like this.
  3. gimpyshotrods
    gimpyshotrods
    Don't need one.
    One can control both.
    chryslerfan55 and mad mikey like this.
  4. rails32
    rails32
    According to the late mister Barris the original had 10 carbs ,this car is a clone . MSD ignition did not exist when the original car was built in 1966. Know one thought of fake carbs back then
  5. Brand Apart
    Brand Apart
    from Roswell GA
    "1947knuck, In post: 12730775, is that keyboard traditional???
    Haha just playing I love the Offy set up. Thanks a bunch for many great pics you put up.
    chryslerfan55, Deuces and 1947knuck like this.
  6. Deuces
    Deuces
    I'd love to see how that works.....
  7. gimpyshotrods
    gimpyshotrods
    Simple linkage, made from a bent piece of metal, joining the secondary throttle shafts together, between the carbs.
  8. lumpy 63
    lumpy 63
    Do you have any pics of that set up ?With a standard size vac secondary diaphram and housing?
  9. gimpyshotrods
    gimpyshotrods
    I have seen it done, but never though it was novel enough to photograph.
    The carburetor with the diaphragm had its primary to secondary linkage removed, and a metal bracket attached to it, with a small bolt and nut in the slot where the linkage was. That bracket, was u-shaped and went to the secondary bellcrank picked up the pin that the diaphram rod normally attaches to, and was fastened down by bolt, replacing the screw that normally holds that bellcrank on.
    Connect thos:
    To this:
    And you have one diaphragm controlling four secondary barrels. The secondary linkage on the other carburetor then does double-duty.
  10. lumpy 63
    lumpy 63
    Why did Holley use a larger Diaphram on 3 barrel carbs? If Holley felt they needed a bigger diaphram to control the larger ****erfly of the 3 barrel Don't you think you would need one to properly actuate 4 ****erflys? I know you will debate stuff to the bitter end .. but its not adding up for me.**** just realized this is a fun threado_O
    chryslerfan55 and enloe like this.
  11. gimpyshotrods
    gimpyshotrods
    I didn't bring my calipers to measure the diaphragms. Frankly, I don't normally think to carry them everywhere.
    No worries if this is not something that you have seen, or don't understand. It has been done, repeatedly, and on both US coasts, and on some very compe***ive cars.
    I never thought anything of it. I makes perfect sense to me. As for pictures, you may as well have asked me to take a picture of something as pedestrian as a particular lug nut.
  12. lumpy 63
    lumpy 63
  13. 402BOSSMAN
    402BOSSMAN
  14. 402BOSSMAN
    402BOSSMAN
  15. 402BOSSMAN
    402BOSSMAN
  16. swade41
    swade41
    from Buffalo,NY
    This must have the Offy offset carb spacers to be able to clear the throttle shaft linkage, I'd like to see it with a distributor dropped in the hole because that was another interference point.
    chryslerfan55, mad mikey and enloe like this.
  17. 1947knuck
    1947knuck
  18. 1947knuck
    1947knuck
  19. 1947knuck
    1947knuck
  20. 1947knuck
    1947knuck
  21. mad mikey
    mad mikey
    A nice shot of Brian, racer x, induction. This was taken earlier today, he is doing DRAG WEEK. It was posted on the Drag Week 2018 thread. Street Fuel Coupe. 20180910_162118.jpg
    TBirdGirl26, loner2, Stebo27 and 13 others like this.
  22. Jet96
    Jet96
    from WY
  23. Flatred53
    Flatred53
    from Sweden
  24. DDDenny
  25. saltflats
    saltflats
    from Missouri
    DaDaDaDenny ............:eek: :D
  26. DDDenny
    Not my photo but I did see this at an area car show Saturday.
    600 inch Ford Boss based engine
    TBirdGirl26, loner2, Stebo27 and 7 others like this.
  27. Flatred53
    Flatred53
    from Sweden
  28. enloe
    enloe
    from east , tn.
  29. Flatred53
    Flatred53
    from Sweden
    TBirdGirl26, loner2, Stebo27 and 12 others like this.
  30. 1947knuck
    1947knuck
