rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. Runnin shine
    Runnin shine
    I was wondering if it could make exhibition p***es like last year with no water with a fresh head gasket and o-rings. Then remembered this is a very expensive new engine so maybe not.
  2. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    That ****s, but it was great watching it come alive. Have a safe trip home, and try not to get caught up in this hurricane thing.
    Sent from my SM-G920V using The H.A.M.B. mobile app
    racer-x likes this.
  3. Brand Apart
    Brand Apart
    from Roswell GA
    Wayne Gretzky said you miss 100% of the shots you don't take.
    Great meeting you in Atl and I'm sure you will be able to make this work next time. Seems like the draining the water idea should work.
    racer-x and chryslerfan55 like this.
  4. olscrounger
    olscrounger
    wishing you the best!! You and Squirrel are HAMB heroes!!
  5. hog mtn dave
    hog mtn dave
    Good you got back to GA. Glad you had some help. There's always next year.
  6. Its 2am I'm a hr outside Chicago. I have had several hrs to think about the next moves with the car before the snow flies. The season around here is potentially over soon. The car will go back together this weekend minus the water. It will go to the fall out drags with some fuel changes.
    I'm leaning out the engine every p*** with little effect. The pump is that big. The next move will be to pinch the port nozzles all by five. I will also lower the main jet from 135 back to 100 and add a fuel loop with a 80 jet in that set at 40lbs. The blower over drive will go from 19 over to 25 over.
    Things will happen with those changes. That's starting to give a nitro engine what it wants. There should be flames with that tune up.
    Nostrebor, scott27, raven and 9 others like this.
  7. Stogy
    Stogy
    It's really interesting this complete Hotrod Racer is a machine that envelopes you but you are wired with your mind to every square inch of its function with the heart in front of the firewall the most complex part of it and with every run down the track registering performance mostly from the gut and mind synchronizing to make alterations...and here we are again seeing that expertise in making adjustments to finish off with the fire still burning...that's great...
    Does this mean you can still do street duty between ventures?...just add water...:D
    I guess it's safe to say the tracking down the strip has improved greatly...so despite some negatives there are big positives.
  8. blowby
    blowby
    from Nicasio Ca
    Was the damage to the head done on the last run or on the road miles after?
    Stogy likes this.
  9. Stogy
    Stogy
    I think it was involving the nitro heated engine and hot antifreeze/water at the track caused by a blown head gasket3. Pretty incredible the surface literally melted away. He did say molten metal landed perhaps on the gl*** at the track during a run just this recent run.
    It also seemed there was excessive waiting during track switching as well that may have contributed to this.
  10. Motor_Psycho
    Motor_Psycho
    Shame about the damage cutting drag week short, all good information for another hit next year though.
    racer-x likes this.
  11. It happened at the end of the p*** at Darlington. I can't street drive it. After I get the new gaskets on I will do a leak down on it. If the gasket seals it's off to the fall out in two weeks. It might take more time to clean the car up than to fix it. It's a mess right now.
    chryslerfan55, raven, Stogy and 2 others like this.
  12. saltflats
    saltflats
    from Missouri
    Sorry for you misfortune Brian.
    We will see you at the Fall Out.
    racer-x, dirty old man and Stogy like this.
  13. Yes. I drove last night to just outside Chicago. Grabbed a few hrs of sleep. Came home got the car unloaded and torn back apart. The new tune up is in. It should scream at the fall out.
  14. Woogeroo
    Woogeroo
    from USA
    Us old truck guys have a saying when it all goes bad : old trucks are fun!
    I guess you can change it up to : nitro cars are fun!
    :p
    -Woog
    chryslerfan55 and enloe like this.
  15. Kind of walking around the shop in a fog after a few hours of sleep. Not meeting goals I set for myself can be a big motivator to do better. So I installed the second byp*** to deal with the big pump. The upper pulley was changed to drive the blower at 25 over. To do this I need a 5 inch idler pulley so one was ordered along with the smaller nozzles. The head might work as is. I just don't like putting it on if it's not 100 percent. If things should go bad they will do it in a big way. That being said I'm off to Roger's in Iowa in the morning. I hate it when the cars not right. It will be right for the fall out. 20180913_174829.jpg 20180913_180028.jpg
    mgtstumpy, Woogeroo, wingnutz and 7 others like this.
  16. David Gersic
    David Gersic
    from DeKalb, IL
    Woogeroo and Stogy like this.
  17. Stogy
    Stogy
    @racer-x as naive as I am about this I will ask...You are running no water and installing a new head gasket on head with an incidental void. I suspect you will use a filler in that void area ie. silicone. Yes the steam creating water will be gone but there is still compression, boost and fuel. Will the absence of water and the new installation preparation prevent the water cool areas filling with gases and heat causing further potential problems?
    Just thinking out loud and of concern. I cannot phathom how much is going on in your mind right now...and you've been down this road many a times.
    Tough decision...have a good nights rest and thanks for sharing all the adventure without a sugar coating...
  18. Runnin shine
    Runnin shine
    While your down there put the second set of plug holes in there. I know I guy with really cool mag valve covers that are collecting dust, and it’s easier than leaning the jets out[emoji6]
    racer-x, Stogy and chryslerfan55 like this.
  19. saltflats
    saltflats
    from Missouri
    This sounds like another sanding session with the intake after getting the head fixed.
    Wish I was closer so you could tag me in. :)
    racer-x, chryslerfan55 and mad mikey like this.
  20. milwscruffy
    milwscruffy
    Good call, for what you have invested, why chance it.
  21. 57 Fargo
    57 Fargo
    I can’t wait to see what this thing runs with the big tune up in it! Hats off to you Brian for sticking with it, impressive as always.
  22. blowby
    blowby
    from Nicasio Ca
    In the last photo it shows some additional damage not directly connected to the water port. Was this still a result of the water port leak?
  23. Yes. When the gasket let loose it exposed a large area. Almost at Roger's shop it will be like new soon.
  24. DDDenny
    The head is easily fixed. The o ring wire is removed first. The low spots welded. The head is decked a few thousandths. Last new receiver grooves cut.
    A lot of times there are still witness marks after a repair, even with the best TIG weld.
    Do you "pick up" the groove with the original size cutter or bump it up in diameter?
  25. dirty old man
    dirty old man
    Hope it all works out Brian, so that you can make it to the Fall Out event a little later. If you have time, come back and let us know how the repairs go.
    Was a real honor to meet you at Atlanta, and I will be following your exploits from here on out. You and Jim Forbes are true hard core hot rodders and deserve the highest accolades from us all.
    blowby, Stogy, racer-x and 4 others like this.
  26. 20180914_134542.jpg 20180914_143120.jpg 20180914_165241.jpg 20180914_181119.jpg 20180914_181129.jpg 20180914_185945.jpg 20180914_185952.jpg 20180914_190952.jpg Any one that regularly follows this thread knows I don't waste time fixing problems. I was up early to make the five hr drive to cedar falls Iowa. It was determined the best way to fix it would be to weld the low spots. One of the crew members from the orange crate dragster has a shop in cedar Rapids. Scott is a incredible welder and was willing to stop his work to do his thing. It only took about 15 minutes. While it cooled we caught up on our lives.
    Up next was the resurfacing. It took .005 to clean it up.
    Then it went in the mill to cut the receiver grooves. This critical step is very delicate. The tool has to be perfectly centered. If it isn't the groove will be too big and the wire will fall out.
    New wire is gently tapped in. This is another delicate process.
    A light touch with a tootsie roll on the combustion chamber edge and its done.
    Work like this goes on regularly for a team running a fuel car. In fact this repair was very easy. It's a different story when the ends of valve are sticking out of the combustion chamber like frisbees or torched chambers or piston to head damage.
    While this job was straight forward it was too much to do on drag week. There just wasn't enough time. View attachment 4033102 View attachment 4033103 View attachment 4033104 View attachment 4033105
    Motor_Psycho, Saxxon, Wraith and 14 others like this.
  27. AmishMike
    AmishMike
    Wow, quite a few spots got some weld fill. Nice work following closely. Love the car & your story
    racer-x, mad mikey and Stogy like this.
  28. squirrel
    That cooling system sealer is good stuff. Got a lot of it on my windshield, had to s****e it off with a razor blade. [emoji12]
    Sent from my Trimline
  29. Stogy
    Stogy
    Machinists are amazing in their craft as well. The Rockets wounds have been mended...
    I guess in my naivety I thought you were going to run without surface repair...that is obviously not what was part of the plan. That is comforting.
    Will this allow coolant filled racing or will removal of it prior to race be now standard procedure?
  30. DDDenny
    Neat, and look at the guys fingers, he's done this before!
    Stogy likes this.
