Technical ***September 2018 Banger Meet - 4 Cylinder Equinox***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 31, 2018.
  1. winduptoy
    winduptoy
  2. winduptoy
    winduptoy
  3. winduptoy
    winduptoy
  4. Jet96
    Jet96
    from WY
  5. Jet96
    Jet96
    from WY
  6. Binger
    Binger
    from wyoming
    Here are some banger pics!
  7. winduptoy
    winduptoy
  8. winduptoy
    winduptoy
  9. winduptoy
    winduptoy
  10. Dustyp489
    Dustyp489
    What jets are you running? Stock are 35 and Jim B book said use 41 or 42, I'm not sure what is best
    Skip
  11. winduptoy
    winduptoy
    I don't have my notes with me. I know I did both a power valve and jet change....it's going to be mid October before we get home....I'll check then
    Sent from my XT1254 using The H.A.M.B. mobile app
  12. winduptoy
    winduptoy
  13. winduptoy
    winduptoy
    At a mining museum kind of surprised nobody stole in the carburetor IMG_20180916_102122572_HDR.jpg IMG_20180916_102128654_HDR.jpg
  14. blgitn
    blgitn
    It says something on that manifold; "for ****x use only". Can anyone read it?
  15. G Baese
    G Baese
    Gasoline Only?
    Jet96 likes this.
  16. Jet96
    Jet96
    from WY
    Well it's a wrap-Back home after a solid weekend of fun with all you Hambers who were there! The banger was a little rich, but started and ran fine all weekend. Got just shy of 20mpg on the reliability run so couldn't complain. Congrats to Binger for editors pick!
  17. Jet96
    Jet96
    from WY
  18. Jet96
    Jet96
    from WY
    And a Huge shout out to Mike and Amy and everyone else involved for another wonderfully run event!
  19. Binger
    Binger
    from wyoming
    Thanks Grady. It was good to see you. I am excited a banger won the editors pick. It was a surprise to me that my plain little car caught his eye.
  20. Well, I wasn't disappointed! What a great event, congrats to all of those that made it possible. See ya next year!
    winduptoy and Dannerr like this.
  21. brjnelson
    brjnelson
  22. Jet96
    Jet96
    from WY
    ^^^those two T's were really cool! ^^^
    winduptoy and 1stGrumpy like this.
  23. winduptoy
    winduptoy
    Good to meet you in person. Thanks for hunting me down.
    Larry
  24. Glad to have met you as well, Larry. You still owe me a ride though!
    Jim
    winduptoy likes this.
  25. winduptoy
    winduptoy
    Yes I do
  26. Jet96
    Jet96
    from WY
    Here's a little head scratcher for you guys- my car ran perfectly (dual 94's)for the hour or so that I drove it on the way to HRHc and during the reliability run. I built these carbs a couple years ago for my flattie and they are really good. Sat. morning it seemed a little rich but started fine and ran okay. . I chalked it up to the 8k +ft. elevation. As the day went on however it ran progressively worse each run (popping out the pipe, really g***y etc.) When I got home I rolled it off the trailer and oil level was up and smelled of gas. Figuring I had blown a PV, I popped the carb body off and sure enough the little PV well was wet. Replaced PV, changed oil and started it-ran exactly the same! Checked and well was wet again? These are good PV's from **** York and seal very well I've never had a prob with them. Anyway, went over everything with a fine tooth comb, dried everything out, filled float bowl and let it set last night. Checked this morning and bottom of carb is damp. Looked close-carb body itself is seeping! I took a picture with the PV out but it had kind of dried out by then. I had an autolite body do that 25 years ago but not since then. Just a little oddity, now I need to go dig through my 94 bodies.....
  27. Jet96
    Jet96
    from WY
    7EDFBF5F-5B5E-4EE3-B9BF-1B604C093826.jpeg I couldn't get the light right, it was pretty wet up in that cavity.
  28. winduptoy
    winduptoy
    The new Power Valves have a radius where the gasket seals against the bottom of the bowl. It won't allow the gasket to seal as it interferes with tightening the power valve against the gasket. The radius needs to be turned flat, removed basically so the gasket will seal.
    I think I have some power valves with me and I'll try to take photos tomorrow as I don't know if my description made sense.
    Larry
  29. Jet96
    Jet96
    from WY
    Winduptoy- yes I'm aware of the gasket sealing issues with some of the pv's-these fit/seal perfectly. These carbs have been run quite a bit on my v8. It's actually seeping thru the casting above the pv. I filled the cavity around the pv with carb cleaner tonight,upside down. It seeps out around the column that the br*** dealy sits in for the acc pump. I wish I could get a decent picture. Very curious but not hard to rectify if I can find a good body.
  30. winduptoy
    winduptoy
    Ok, I understand that you understand....took photos anyway. I always question mechanical fittings and joints before going anywhere else.... IMG_20180920_081021127_HDR.jpg
    Jet96 likes this.
