Projects Cheap altered build - Topolino.
Discussion in 'The Hokey Ass Message Board' started by gasserx, Sep 14, 2018.
  1. gasserx
    gasserx
    from norway
    Just agreed to buy this project. Its an 50s Topolino with a 30s front. A "half" frame, Anglia front end, etc....I will build a cheap racer out of it to run in the local nostalgia cl***es. Not a Hemi powered monster on nitro :rolleyes:
    However, what route should i go for ch***is? Its not much, i know, but its a start...
    The little thats left of the cage will of course be thrown out. How about the rest of the frame? Keep it, or build a new square frame? Rear axle? Wheel and tire size for the rear?
    Just need some good ideas. Thx in advance.
  2. oj
    oj
    Nice project, btw there is no such thing as a 'cheap altered'. I'd be contacting SFI Foundation, and purchase the proper set of plans/specs for building an Altered. Get the set good for 7.50 and slower (unless you plan for AA, then 6 seconds). Follow them and get it certified, then you'll have the real deal and protect your investment.
    Hnstray likes this.
  3. oldolds
    oldolds
    Put a 4 cylinder in it. Something like a Chevy II or Mercruiser. Keep it in the 10's or slower. You can cut the cage out of it. Minimal safety stuff at that et. If you try to go faster you need a roll bar or cage up to those specs. A not approved cage will mean you can't run no mater what the et. If you have never raced before 10.00 will seem fast. No NHRA license required either.
    Those engines are kind of cheap to build. They use mostly available internals and only 4 holes to buy parts for.
    Leave it on springs, not solid mount rear, with that engine it will not break much. You can race every week.
    rodrat51, Hnstray and kidcampbell71 like this.
  4. finch6013
    finch6013
    from Oregon
    I helped a friend run a 32 Bantam with a very modestly built 396 at it easily ran into the 9's. We had to throttle stop it to keep it 10.0 or slower due to not wanting to get a license. It doesn't take a lot of engine to make a light weight altered scoot. You might even be able to keep it street able and still run low 10's if you wanted.
  5. patmanta
    patmanta
    from Woburn, MA
    What are the drag strip rules line in Norway as far as build specs and times?
    Hnstray likes this.
  6. Jalopy Joker
    Jalopy Joker
    yep, need to build according to rules/requirements of your local Nostagia Drag Racing ***ociation - great body style to start with - I think that most of us start a build with "cheap & easy"
    Hnstray and Deuces like this.
  7. AHotRod
    AHotRod
    What you choose for the engine will determine what your going to need for the rear end, gearbox and ch***is.
    Give us more to go on to help.
    As "Finch6013" said, a good old stock-ish V8 will make it plenty quick.
    How fast do you want to go?
    mad mikey likes this.
  8. gasserx
    gasserx
    from norway
    :eek:
    I cant afford the real deal. It will be more like a bracket car with a sbc or something else cheap that comes my way. A 10-11sec car, just to play.
    I've gone 9.0@1/4 in a slingshot, but i guess its unfair to compare it with a short wheelbase car.
  9. Never shortcut a ch***is and cage. There are some race ready ch***is on racejunk.com that you can alter to fit the body. As long as your platform is safe and strong you can run junkyard fours to supercharged eights and never worry.
    Put your money into the ch***is and save your money on the drivetrain and body.
    kidcampbell71 likes this.
  10. gasserx
    gasserx
    from norway
    Im not going to shortcut, but i dont justify the need for a 6.0 ch***is to run above 10's..
    wingnutz likes this.
  11. old sparks
    old sparks
    I`m running one like you want to build right now . its a bantam coupe body is pretty much the only difference. I bought 2 sticks of 1 1/2 by 3 square tube 1/8 wall and a bunch of 1 1/2 by .139 wall tubing for under 500 bucks. borrowed a bender and away I went. I run a 3.50 gear with 29 in. tire a homebuilt powerglide and a 350 chevy old model a front end. my advice is stay with a small block so the m***ive torque of a big block wont be a problem. i`ve got less than 5000 in the car and I had to add 100 lbs. to keep it out of the 9s. a lot of fun. the motor is a 12 to1 flat tappet two swap meet afbs with less than 2000 invested. have fun and good luck car weighs 1730 lbs
  12. gasserx
    gasserx
    from norway
    Old sparks.. , sounds like the route im going.
    Picked up an Volvo 240 rear axle today for free, should hold quite a lot of hp, and parts are cheap over here.
    wingnutz and kidcampbell71 like this.
  13. Max Gearhead
    Max Gearhead
    from Wisconsin
  14. AHotRod
    AHotRod
    How about posting a few pictures ??? Would love to see it !
  15. old sparks
    old sparks
    got an anra event in famoso middle of oct so when I pull it out of the trailer to do an oil change and try to figure out what to change to help my dismal reaction times ill take some pictures then get one of my grandkids to show me how to do it, I will. by the way last p*** was 10.28 @ 126. remember you have to stay under 135 mph or you need a license and a parachute. one more thing rpm is not your friend. I shift at 5500 and go thru the lites at 6000. can you say hydraulic cam?
  16. Neat little project. What happened to the side ventilation flaps in the firewall that are so specific for a Topolino ? Guess this was allready a hotrod or race body.
  17. gasserx
    gasserx
    from norway
    Yes, it has been customized before, i dont know the story though...
    Worked on the rear axle last night, stripping of stock brackets, brakes etc. Now i need to find a good combination of wheels and tires. A little bit tricky, since Volvo has a 5x108. Not a lot of good looking wheels to choose from with that boltpattern :|
  18. old sparks
    old sparks
    don't know what your skill level is at the moment but Volvo centers with 7 to 10 inch hoops welded on is the way id go. bolt centers on the axle with brakes removed and use the axle like a lathe welding the hoop 1 inch at a time using angle iron clamped parallel to the axle for a story pole. that's the way we used to do it b4 my grey hair showed up. solid mount the axle double shear 5 3/8 bolts per side 1/4 inch plate
    saltflats likes this.
  19. gasserx
    gasserx
    from norway
    I've planned to solid mount, but i dont think i understand exactly what you are decribing (my bad english)
    Picked up some used slicks today for mockup. 31x10.5, seem to be enough for this little thing.
    Anyone know how wide a typically 60s altered was on the rear wheels?
  20. old sparks
    old sparks
    wheels were typically 7 in wide cause that's what was available. some guys used well casing tho now a days well casing is plastic. double shear is 1 plate sandwiched between 2 plates bolt is supported on both sides of load bearing member
    gasserx likes this.
  21. gasserx
    gasserx
    from norway
    Trying to figure out what would be the best width of the rear. I like the rear to be narrow, but still a little bit limited due to the axle. Dont want to spend money narrowing it :(
  22. gasserx
    gasserx
    from norway
    Found a nice set of 15x8" Minilite wheels :) With these, and the Volvo axle, the max width of the rear wheels should be around 60" - not that bad. I will use the bigger tires though..
    Btw, these wheels was used on a Ford ****** with 1030hp (turbo Cosworth engine), with the same Volvo axle as im using. So i guess it should hold up quite good.
    AHotRod and wingnutz like this.
  23. gasserx
    gasserx
    from norway
    :D
  24. loudbang
    They look good.
    gasserx likes this.
  25. gasserx
    gasserx
    from norway
    IMG_20181006_151744.jpg Testing..
  26. loudbang
    Click on FULL IMAGE when posting makes it easier for us to see.
  27. pnevells
    pnevells
    Neat project, Here is a couple pics of our homebuilt altered, we bought a project started by another HAMBer, and finished it oursleves, Ch***is is NHRA Certified to 7.50, We run mid 9 second times at 135MPH . It was a 3 year father and son project
  28. gasserx
    gasserx
    from norway
    Good looking car pnevells!
    Got any pictures of your front suspension setup? Thats the next thing i need to decide on.
  29. gasserx
    gasserx
    from norway
    Next week im putting the frame rails on the jig. Meanwhile im trying to figure out what direction to take with this (Anglia axle) .
  30. AHotRod
    AHotRod
    What are you unsure of with the Anglia axle?
