Technical 47-53 chevy truck differences
Discussion in 'The Hokey Ass Message Board' started by LarsL, Sep 16, 2018.
  1. LarsL
    LarsL
    from Norway
    Hey Guys.
    Im wondering if theres any other differences in the front parts than wheel openings on small trucks vs big trucks? Are the fenders the same? What about the sheet metal between the hood and the radiator support?
    Is there any big truck front parts that fit the 3100 trucks?
    Thanks for all the help.
  2. 302GMC
    302GMC
    from Idaho
    Everything from the cowl forward is larger than the 1/2 ton.
  3. LarsL
    LarsL
    from Norway
    On every truck bigger than 1/2 ton? Even the sheet metal between the hood and radiator support? Wider?
  4. not that one guy
    not that one guy
    from So NV
    3100,3600,3800 sheet metal same, side badging diffrent
    If you go 1 1/2 ton or larger your need the complete front clip
    Hnstray likes this.
  5. The hoods and headlight buckets are the same.
  6. LarsL
    LarsL
    from Norway
    So 3100,3600 and 3800 have the same wheel openings also?
  7. jetnow1
    jetnow1
    from CT
    Yes, all under 1.5 ton used the same sheet metal, in fact my 3600 came with factory 15 inch wheels.
  8. henry29
    henry29
    Yes
  9. LarsL
    LarsL
    from Norway
    Thanks guys!!
  10. rusty1
    rusty1
    one & a half tonners (or larger)had lower hoods and the grilles had more space between
    each bar,...
