Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. Pinstriper40
    Pinstriper40
    I welded the rear fenders. Onto this '47 Ford coupe. I will weld a strip over the top to minimize filler on the front 3/4 of the seam. Its starting to look like a custom! I'll do a build thread on this car soon.
  2. b-bob
    b-bob
    My budget doesn't allow for a pro paint job on my 51 Chevy p.u., so i thought i would just do it myself with flat tinted primer. That way people wouldn't look too close at the prep job. Went down to my local paint store to get some flatner for some paint i already have. Was shocked when i was told the flatner was $95 a a quart, and i needed a quart of flatner for every quart of paint! So that is $400 for a gallon of paint! Can't do that, so went down to a painter i know who paints cars on the side at at home. I would rather spend the money on labour , and have a pro do it instead. I know he will treat me right.
  3. 392
    392
    23CA7A88-0A1A-4113-B986-33A068AEE714.jpeg D9410000-802E-43E6-B48A-D14220BC301C.jpeg Modified key with 2 dog rabbies tags and panel bond. The keys today with off the shelf ignition switch have no character.
    The37Kid and Tomincanada like this.
  4. squirrel
    I took a nap. Twice. Still tired, after all that..
    Latigo, chop job, j-jock and 8 others like this.
  5. 56don
    56don
    Today I found out that if you use ARP head bolts on a BBC engine then the cast iron exhaust manifolds will have to have clearances ground into them because the ARP bolt heads stick up higher than the oem head bolts. So I spent the entire day grinding and fitting and grinding and fitting exhaust manifolds. This was on the Corvette exhaust manifolds, I don't know about other models.
    swade41 likes this.
  6. Hnstray
    Hnstray
    from Quincy, IL
    Didn’t do all this in one day, but moved my lift to another location in the shop. Wanted to move it intact, thinking not dis***embling would be less work. Well, it probably was more man hours doing it this way, but it was satisfying to do it nonetheless. :)
    (Sequence of pics is off. The first (top left) pic should be the fourth
    Ray
    E4BB6780-80B3-4212-8377-1FF42335F5A1.jpeg 2E8EE06F-D7AD-4B2F-8118-2F4ECE3542BD.jpeg E61B18C4-5F12-441A-A31E-73AF79F745B4.jpeg
    7E6564DE-3647-4193-8152-3ADD7C7AC1CC.jpeg 65AAFC30-6D55-441A-8C76-BCCAAC2DD57A.jpeg DED87112-BEB7-49C0-B7B8-F4633169DC59.jpeg
    LAROKE likes this.
  7. milwscruffy
    milwscruffy
    FYI, they make a thin head version. Ran into the same problem with headers. No I don't have a part # and had to call and talk to them to find out a cure.
  8. 56don
    56don
    I wish they would have made this common knowledge. I would have used oem bolts if I had known this.
  9. bobss396
    bobss396
    Yesterday I had to tighten one of the exhaust flanges on my Ford to quiet it down, did it cold and worked from under the hood... off to the gym... seems like I'm most likely to get FUBARed going to the gym...
    Anyway, heading out and wanted to get gas on the way, car has a dead miss. Knocked a plug wire off it seems, pull over, scorch my hand on the manifold, close the hood and put it away, fixed it later when it was cool. After dinner... go for a ride, it was a nice night. Get home, one of my low beams is out, the bright doesn't work on that side, hope its just the bulb, will swap them side for side or put a tester on the socket. Fix one thing, break 2 others...
    UNSHINED 2 and Hnstray like this.
  10. 31Dodger
    31Dodger
    FINALLY got enough cash to order my new wheel cylinders for my 1931 Dodge Brothers coupe. Should get them soon and be on the road again.
    UNSHINED 2 likes this.
  11. Pinstriper40
    Pinstriper40
    I moulded in the rear pan and filled the fuel filler hole on the fender of this '47 Ford coupe. Fun stuff!
    20180919_221956.jpg 20180919_172735.jpg 20180919_173524.jpg 20180919_182432.jpg 20180919_185142.jpg
  12. bobss396
    bobss396
    2nd degree burn on my left hand has finally blistered, doesn't hurt much considering the size. Replaced the low beam on my '59 Ford, went to local chain store... $16.99.. oooffff.. but there was something rattling around in the box. Got home, opened it and found a nice toggle switch inside of it. AND the light worked.
  13. lumpy 63
    lumpy 63
    Gathered up 10 of my buds to do a car show at the old folks home where my Mother in law lives. The Residents really enjoyed it and it was fun listening to the stories of the cars they had owned. Packed up around 1:00 and went to the shop to work on the OT drag week L* engine . Fired on first crank. :D Good day in my book.
  14. Hnstray
    Hnstray
    from Quincy, IL
    Moving my frame bench to a better location in the shop
    UNSHINED 2 and RICH B like this.
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    Hnstray likes this.
  16. bymanr
    bymanr
    IMG_9165.JPG Finished up mods to HF bead roller, Eastwood power unit, return springs and old window crank for adjusting. One man operation now!
    39WILLZ, swade41, UNSHINED 2 and 4 others like this.
  17. 392
    392
    94FFF5A1-EB20-4C4B-A24B-D8FB4F23E512.jpeg Went to the nhra drags in St. Louis.
  18. bobss396
    bobss396
    Covered my front seat with a Mexican type blanket, the seat was getting worse. I have to take a picture or 2. Crawled under and tightened my exhaust on 1 side, may have to replace a plug wire.. have to stagger out in a bit. Supposed to go to a car show off the ocean, but VERY overcast here so far.
  19. 39WILLZ
    39WILLZ
  20. Fitted the seats and harnesses to my Modified. Harnesses are from an armoured personnel carrier. IMG_20180923_161638255.jpeg IMG_20180923_161705319.jpeg IMG_20180923_161659762.jpeg
    Sent from my moto g(6) play using The H.A.M.B. mobile app
    Hnstray, UNSHINED 2 and 39WILLZ like this.
  21. RICH B
    RICH B
    My crusty coupe got to hang around by the fabulous Astorian at my kid's annual party.
  22. mopacltd
    mopacltd
    Attended a celebration of life for a very close friend.
    lumpy 63 likes this.
  23. WTF really
    WTF really
    Went and picked this up yesterday 20180923_151208.jpg 20180923_163627.jpg 20180923_163645.jpg
  24. Jkmar73
    Jkmar73
    from Tulare, CA
    Got the rain gutters in the trunk of my model a installed and welded. Now to fit the trunk and hinges in.
  25. PHIL COOPY
    PHIL COOPY
    Rod building interference.....
  26. swade41
    swade41
    from Buffalo,NY
    I s****ed flaky chrome on these 15x4's in preparation for sandblasting and powdercoating. 20180927_155619.jpg
    UNSHINED 2 and Max Gearhead like this.
  27. junkyardjeff
    junkyardjeff
    Fixed what I thought was a pressure plate issue on my 37 Chevy but was a loose jamb nut on the adjuster.
  28. RoddyB34
    RoddyB34
    17A80563-1463-4757-9DFA-467CBAFBD1BB.jpeg 5FA26A4B-C3EF-454B-B012-9E75BFB9D92B.jpeg Fired up our mercruiser converted A coupe ,,used a “temporary “radiator ,we ran the regrouned cam in ,runs nice ,,was interesting to see how the thermostat worked allowing small amounts of water through until it reached its temperature,,
    UNSHINED 2, Hnstray and RICH B like this.
  29. charleyw
    charleyw
    Checked out the pictures of my F-1 going through the paint process, should be ready next weekend (800 mile round trip). It's been an on again off again project since 1991. IMG_0350.JPG
    CudaChick1968 likes this.
  30. lumpy 63
    lumpy 63
    Got up at 0dark thirty and drove up to Don Longs shop in Gardena to buy his big *** 17" LeBlond lathe. While we were there got to check out the last dragster ch***is to be built in his shop:cool: Good day in my book...
    CudaChick1968 and jnaki like this.
