Projects My new ride - finally on the road
Discussion in 'Traditional Hot Rods' started by grdra1, Jul 9, 2018.
  1. Brad333
    Brad333
    Glen, heating and bending any steering components wont be accepted in Australia, regardless of engineer involvement. No engineer (that i'm aware of) would approve it either. It weakens the material substantially, especially if its cast. I'd suggest moving the steering box to locate the pitman arm where it needs to be, while still maintaining correct steering geometry to avoid bump steer.
  2. grdra1
    grdra1
    Thanks for reply, my engine mount is in the way and limits where steering box can go ( I probably will have to make new engine mount ). Dimpled grille came out P5010447.JPG ok but not sure about shade of paint - used black hammer tone, may change to a gloss black similar to body color, What do others recommend. Glen P5010440.JPG P5010443.JPG P5010444.JPG
  3. grdra1
    grdra1
    Re mounted grille and changed colour to gloss black, also ordered some dropped steering arms that will give me more options for steering box location. Glen P5110448.JPG P5110450.JPG
  4. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    As Tim said "Man the way those coil overs are mounted on what amounts to a flimsy tab makes me cringe." .I am kind of surprised no one picked up on that sooner. I see you have cut them out and judging from the way this build is going I am doubtful you will put them back in as they were. Nice work. I have friends in Brisbane and I'm aware of the hoops you have to jump through to please the government inspectors
    Outback likes this.
  5. grdra1
    grdra1
    Pulled body off yesterday, not easy by myself but I got there in the end after I made a table / trolley, now the fun begins. Also received my rear disc brake kit a few weeks ago - I might change the bolt on caliper mounts to a weld on unit. A few pics of progress. Glen P6210453.JPG P6210456.JPG P6210457.JPG P5190452.JPG
    Outback, Vic Walter, catdad49 and 4 others like this.
  6. Atwater Mike
    Atwater Mike
    Glen... Very nice coupe, nicer fabrication going. That looks like a 2" x 4" rec. tube 'Custom built' frame...possibly the Model A VIN was restamped on the bottom.
    You mentioned 'Gl***', (windshield/windows) What is the difference between Canada standards and O-Z?
    Reason for asking: California has different standards than Europe, (bumpers, etc.) as experienced by 'gray market buyers' of Euro Mercedes, BMW in years past.
    A friend bought a Range Rover from O-Z, and on receiving it at the Port Authority, we had to remove ALL gl***, wheels/tyres, and even the 'bonnet', for Dep't of Transportation, as they were deemed 'Ca. Sub standard'...
    What is the 'gl***' designation down unda?
    Thanks...Mike
    Outback and loudbang like this.
  7. grdra1
    grdra1
    Mike the regs state that all gl*** needs to be automotive standard safety gl***, my car came with all new gl*** that previous owner had made to suit. Unsure of exact specs as the street rod guidelines im using dont give that detail, they refer to some appendix in some other fancy section of the automotive guidelines. You must have some extremely tough rules - wheels / tyres /bonnet, thats outrages. And yes there is a number stamped under the frame on left side. I will note it down and see if I can find out if it is original. I have been working on car today, made trolley more stable with more bracing and cleaned garage ready to remove engine / trans to measure ch***is to see what im dealing with, will post pics tonight. Thanks also for the kind words, Glen
    catdad49 and loudbang like this.
  8. grdra1
    grdra1
    Cleaned shed yesterday, removed engine from ch***is, ran a tape measure over ch***is - all ok so far. Found number on ch***is, left side on bottom. A4 106478 anyone no if this is a original number, I no its not in original spot on ch***is. Glen P6210461.JPG P6220462.JPG P6220464.JPG P6220465.JPG P6220466.JPG P6220467.JPG
  9. grdra1
    grdra1
    Started on ch***is ch***is today, will do one section at a time before moving to next. Started on rear ch***is ( will have fish plates and gussets ) and plan is to complete rear end mounting to determne where centre X member will locate - current centre cross member will be in way of upper 4 link mounts and is not the currect size tube, it needs to be 4 x 2 tube with diag****s to form a K member. A few pics. Glen P6230468.JPG P6230469.JPG P6230472.JPG P6230473.JPG
  10. catdad49
    catdad49
    Man, that should handle some horsepressure! Will be watching.
  11. grdra1
    grdra1
    Left side of ch***is was out 6 mm / 1/4 inch, had to modify, see pics. Welded ch***is after repair today , all within 1 mm, happy with result despite no jig ( you guys need to go metric, much easier than imperial ). Glen P6260474.JPG P7020482.JPG P7020484.JPG
    Ron Funkhouser and Shadow Creek like this.
  12. Fast Eddie 27
    Fast Eddie 27
  13. grdra1
    grdra1
    A few pics of today's progress, removed old cross member and installed a new K member. Put front end and engine back in to determine pinion angle and check wheel base, will probably need to make some new brackets to mount the rear as the ones supplied with the 4 link kit may not be suitable. Glen P7020486.JPG P7020487.JPG P7020490.JPG P7030493.JPG P7030494.JPG
  14. grdra1
    grdra1
    A few pics of today's progress, set up pinion angle and wheel base then tack welded housing in place to make it easier to fab mounts / mount 4 link. Glen P7040495.JPG P7040496.JPG P7040497.JPG P7040498.JPG
  15. grdra1
    grdra1
    A few pics from today, made some 4 link mounts for bottom bar to ch***is and mocked up the rear. Nice and easy with rear tacked in place, able to work at a nice height. Glen P7060500.JPG P7060501.JPG P7060502.JPG
    loudbang, EVL401 and Shadow Creek like this.
  16. grdra1
    grdra1
    A few pics of latest progress, all working out ok so far. Glen P7070506.JPG P7100509.JPG P7110512.JPG P7110514.JPG P7110515.JPG P7110516.JPG P7110518.JPG P7110519.JPG
    Shadow Creek and loudbang like this.
  17. grdra1
    grdra1
    Finished mounting shocks today, now need to finish weld everything. Happy with result, all working ok - no binding and all square. Rear end is currently set at the height of old unit, I can move up or down by one inch. Glen P7120522.JPG P7120521.JPG
    Outback, Ron Funkhouser and loudbang like this.
  18. grdra1
    grdra1
    Finish welded the rear housing and K member etc, also machined up some plates to make my gearbox cross member removable. Glen P7160525.JPG P7170529.JPG P7170533.JPG P7170535.JPG P7170536.JPG P7170532.JPG P7160523.JPG P7170531.JPG P7170534.JPG
  19. zz29
    zz29
    Wow, they’re killing all the fun!! I thought Australia was all like no rules, just run wild. In the state I’m in here in the USA, the mechanic was like “cool car. Here’s your sticker. “
  20. 3banjos
    3banjos
    from NZ
    You've sure been busy. Looking good and strong. Just hoping for your sake, you have enough triangulation to avoid needing a panhard.
  21. grdra1
    grdra1
    I will be adding a panhard to front suspension and will add to the rear if required - easy to do at present, better now than later. I have been looking on google for minimum and maximum angles for top bar bar placement for triangled four link suspension without success. I feel what I have will be ok, but am willing to add panhard if others have had issues - please let me know. I always appreciate advice from those that have experience - and been there before. Thanks again, here are a few pics of today's progress, I managed to complete gearbox mount and start on installing new front cross member - will lower front approx 1/2 inch and with removal of he first small leaf spring total amount lowered with be approx 3/4 of an inch. Glen P7190541.JPG P7190542.JPG P7190543.JPG P7190544.JPG
  22. CharlieBob
    CharlieBob
  23. Moparts
    Moparts
    Great build! Looks awesome!
  24. grdra1
    grdra1
    Thanks for info, looks like my upper bars are approx 20 degrees when the minimum is about 30 degrees, will need to add a panhard bar now. A few pics of todays progress, got front cross member where it needs to be and started making boxing plates for underneath, here are a few pics. Glen P7200545.JPG P7200547.JPG P7200548.JPG
  25. grdra1
    grdra1
    Finished mounting front cross member today, now need to make new shock mounts. A few pics Glen P7210551.JPG P7210554.JPG P7210558.JPG P7220563.JPG
  26. grdra1
    grdra1
    Made some shock mounts, happy with result so far. Also needed to make a new spring mount as radiator was hitting the U bolts due to new cross member. I Also brought some used panhard bars from local wreckers to make front and rear units. A few pics, Glen P7220564.JPG P7220565.JPG P7240569.JPG P7240571.JPG P7240572.JPG P7240573.JPG P7230567.JPG
    Vic Walter, loudbang and catdad49 like this.
  27. grdra1
    grdra1
    Machined and threaded some bungs today and made two adjustable panhard bars, will make mounts soon on my next days off. I will then cut them to length and tig weld bungs in, a few pics Glen P7280574.JPG P7280575.JPG P7280576.JPG P7280577.JPG
  28. low budget
    low budget
    from Central Ky
    Awesome work but have to humbly ask, Do you think the up and down travel of the rear diff will ever be a concern where the drive shaft p***es under that rear crossmember?
  29. 392
    392
    Nice ride and great work. Where did you get that heater. I’ve never seen anything of the sort.
  30. grdra1
    grdra1
    Unsure about tailshaft to crossmember clearance as yet, nil issues with old crossmember but will determine when I put engine, trans and body back on, may need small scallop - will wait and see. Heater was $30.00 ebay item, not sure what it came out off, just cleaned and painted it. A few pics of todays progress - mock up of panhard bar. Glen P7310578.JPG P7310579.JPG P7310580.JPG P7310581.JPG P7310582.JPG
