Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. swade41
    swade41
    from Buffalo,NY
    No photos but I cut the Henry J outer column down to 23 inches, using the upper bearings. I took the upper bearings off the J upper shaft and installed them onto the chevelle shaft, collapsed the shaft to length and pinned it with a roll pin. Then took the lower bearing, retainers and small piece of the inner tube off the chevelle column and welded it to J column. Put it all together and on the interior side it looks totally like it did before, happy guy.
    I moved the column and drop about an inch to the left to clear the engine. This thing was tricky splitting the gap between a sparkplug socket and header bolt socket without interfering with exhaust port. The things you have to think ahead about or you screw yourself down the road. Last piece of the puzzle was welding a plate to column to attach to firewall for support. 20170305_173129.jpg 20170305_173205.jpg 20170305_174005.jpg 20170305_174248.jpg
    Baron, Chucky and loudbang like this.
  2. loudbang
    Remember spring is only a couple months away. :rolleyes: Looking good.
  3. Dooley
    Dooley
    from Buffalo NY
    Looking good Phil....
  4. swade41
    swade41
    from Buffalo,NY
    The truck is up and running good so it was a parts chaser for the J today, my friend in his J caught me in the act and took a couple photos.
    I finished up shortening the drag link and set the tow in at an 1/8, everything is parallel and should be good. The only thing is I'll pull the steering arm and have the spacer welded to it for a little piece of mind, just feel better doing that.
    Next step is to pull the motor/Trans and finish up the firewall and Trans hump transition. 20170426_164330.jpg 20170426_164408.jpg 20170426_164934.jpg FB_IMG_1493253086091.jpg FB_IMG_1493241940748.jpg
    loudbang, LOST ANGEL and Dooley like this.
  5. swade41
    swade41
    from Buffalo,NY
    20170503_104051.jpg Nice weld my buddy did for me
    Chucky, loudbang and Baron like this.
  6. loudbang
    Weather is getting good time for some RUNS LOL :rolleyes:
  7. swade41
    swade41
    from Buffalo,NY
    That'll be a while yet...lol
    Between the truck, t-bucket and Harley that are all ready to go it's hard to get time crunch motivated to get this one done.
  8. swade41
    swade41
    from Buffalo,NY
    Not much progress but I did recently test fit some borrowed headers, almost like I had these headers while setting the engine in place. I've got minor interference at the pinch weld on both sides but hot damn if I can't buy some off the shelf headers for this thing, a big plus. henryjheaders.jpg henryjheaders1.jpg henryjheaders2.jpg henryjheaders3.jpg
  9. Mike Colemire
    Mike Colemire
    Nice, the truck is bad a$$.
    loudbang and swade41 like this.
  10. az426hemi
    az426hemi
    I have these same headers for mine. $204 at Speedway for painted ones.
    Mike
  11. swade41
    swade41
    from Buffalo,NY
    Thanks, it's a handful with the blown 540 but it sure is fun !
    Yes that's them, my photos are all screwed up with photobucket's third party posting BS, but I had tried Patriots back when I was mocking up the big block while in the stock ch***is and they did not fit. I would have liked at least a 2 1/8 tube but for off the shelf availability, I'll take them.
  12. tfeverfred
    tfeverfred
    Looks good and it's going to be a lot of fun.
  13. loudbang
    It will be Howling at the moon again soon. :cool:
    swade41 and enloe like this.
  14. swade41
    swade41
    from Buffalo,NY
    Last year I was caught welding by my pacemaker reading and was given the sturn lecture by the cardiologist to stop and desist. So I just haven't had any motivation to work on this thing, why fab a part if you can't finish the install.
    Getting the 57 p/u at the first of Dec. and me telling myself that I won't start on that one until the Henry J is back up and going put a bug in my *** to get something done.
    ***essing the trans tunnel to firewall situation I decided to remove the old bellhousing area to give more room for the flywheel shield and blanket.
    Standard posterboard mockup followed by just throwing that in the trash..lol 20180128_171419.jpg 20180225_133606.jpg 20180225_181041.jpg 20180225_151046.jpg 20180227_163519.jpg 20180227_141058.jpg
    loudbang, Baron and Chucky like this.
  15. swade41
    swade41
    from Buffalo,NY
    Trimmed to fit and went against the doctor's orders and started tacking it in place, got over zealous and warped the firewall. The whole welding thing screws me up, so I am as far away from the machine and surface as I can get and it shows.
    After that it was time to cut out a distributor recess and fit an old tackle box in the hole about a quarter inch from the back of the dash. Got that welded in with the same process and first coat of duragl*** on. 20180326_134902.jpg 20180328_171758.jpg 20180328_181515.jpg 20180328_181323.jpg 20180329_171014.jpg 20180329_163921.jpg 20180331_150439.jpg
  16. Baron
    Baron
    Looks good Phil. Evidently your staying far enough away to have your pacemaker send any signals to the Dr. Finish up the firewall and get it painted and you'll be ready to put the motor back in for the final time. Be nice to see this out on the track again. Keep up the good work pal.
  17. blue 49
    blue 49
    from Iowa
    Just wondering to myself, would the lead vest they use for dental x-rays do anything to prevent the effects of welding with a pacemaker?
    Gary
  18. Clik
    Clik
    I don't suppose you want to gas weld and will continue to cheat. I've had atrial fib for years and have been advised that I may need a pacemaker or defibrilator at some point, so I pay attention to posts like yours. I've read where it helps to wrap your welding cables around each other. I've also read where pulsing ain't good and that's just what we do with sheet metal.
  19. Dooley
    Dooley
    from Buffalo NY
    so how do you go fishing now??
    I cant weld either....no pacemaker just cant weld.
    Looks good
    should be pulling the front wheels up soon
  20. philo426
    philo426
    I can see how arc welding may effect your heart but not oxycetelene.
    loudbang, Baron and swade41 like this.
  21. 0nedon
    0nedon
    Looks great congrats.
  22. swade41
    swade41
    from Buffalo,NY
    Thanks everyone and Clik I was just on the operating table a couple weeks ago for a new defib model. They had seen a couple anomalies in my pacemaker reading and setup surgery the following week, very sudden like. If you guys remember, I do not have a heartbeat outside what's induced by the pacer and adding the defibrillator model would have surely put ill effects on my automotive pleasures. Any outside interference that may make the heartbeat irregular would be followed up by a defib shock, but thankfully after 3 hrs laying on the table and getting the heart stimulated for such period, they could not get it to replicate the anomalies. So no change to the defib model
  23. Dooley
    Dooley
    from Buffalo NY
    Phil
    You are the definition of Hot Rodder
    swade41, loudbang and Baron like this.
  24. Dreamweaver
    Dreamweaver
    Awesome build!
    Question for you regarding a Henry J and a BBC. How much further forward could you bring the motor(to maximize interior room)?
  25. swade41
    swade41
    from Buffalo,NY
    A big block is roughly 2 inches longer than a sbc but it's all forward of the motor mounts, from mounts back they are the same.
    It also depends on how low you set your engine into the ch***is, the lower it is the less transmission hump you'll have in the floor. I set mine up high, right at the 24 inch crank centerline to ground maximum as per NHRA rules.
    Here's how forward the sbc was in the ch***is when I bought it and the radiator was in the stock location.
  26. swade41
    swade41
    from Buffalo,NY
    Since the thread was bumped up, not much going on with the car, I don't last more than a couple hours out in the garage so it's been very slow going.
    Was doing bodywork on the firewall earlier in the year, then got sidetracked working on the carbs on the 41 truck, didn't want to get bondo dust in the carbs or engine while waiting on correct parts so work stopped.
    The most recent I decided to do a mirrored stainless insert in the firewall recess, always liked them but never had one. So I figure I can cut my bodywork down a bit on the warp I put into the firewall by covering it up, little tough to breathe through a mask so that's good by me. Ha ha ha
    Making the posterboard pattern
    Laying it out on the 22 ga. stainless
    Cut out the sides with a jigsaw and took it to my buddy's shop to use his break to bend it, test fit looked great.
    So went ahead and cut the rest out with same jigsaw, couple boo boos when I cut into my table that I was working on top of but I can live with it.
    Might try that chrome door edge guard around the whole bottom cut, I hear you can heat it and it'll take a pretty good bend. Or just blend in my boo boos a bit with a sander and let it ride, might not even see them with the engine back in.
    Stogy and papajohn like this.
  27. swade41
    swade41
    from Buffalo,NY
    Bad Moon is getting BADDER
    20190428_170255.jpg 20190430_181456.jpg 20190430_181418.jpg 20190501_155100.jpg 20190501_185156.jpg 20190501_185342.jpg 20190501_185318.jpg
    loudbang, enloe, lumpy 63 and 4 others like this.
  28. Dooley
    Dooley
    from Buffalo NY
    Good thing you have a new frame and axles
  29. Baron
    Baron
    Nice to see you back on this Phil. Going to be a totally different car than you took apart. All good !
    loudbang, enloe and swade41 like this.
  30. 1971BB427
    1971BB427
    from Oregon
    Love me some big block Chevy Phil! Nice addition!
