Projects Aarons 29 AV8 coupe build
Discussion in 'Traditional Hot Rods' started by Aaron D., Jul 27, 2016.
  1. brEad
    brEad
    Car looks good! Crazy days/nights moving... I went through that recently. Sounds like a good thing for you though. Good luck!
    Aaron D. likes this.
  2. Aaron D.
    Aaron D.
    Thanks bread
    She's ready to head West!
    Corsa, Jeff34, brEad and 1 other person like this.
  3. Aaron D.
    Aaron D.
    Just a quick video to let you guys know what's going on. More videos coming soon.
    Corsa, brEad, 51box and 4 others like this.
  4. baspinall
    baspinall
    from SE PA
    Glad to here the move went well Aaron.
  5. greaser
    greaser
    Great to hear from you, Aaron. Glad all went well with the move, and congrats on your retirement!
    Looking forward to your updates.
  6. Tim
    Tim
    from KCMO
    Man I’m way behind, looks like your still making progress though!
  7. 48fordnut
    48fordnut
    Hi Aaron, Could you give me some details on the fan set up/ I have a 8ba eng that I am using early water pumps and heads on, with a 3 carb intake. I need a set up similar to yours. Great work.Glad you're setteled.
    jim
  8. Aaron D.
    Aaron D.
    Hi Jim, I cut the original fan mount and used the part that holds the fan shaft. I then welded a plate to the part. I set the fan as low as possible, then drilled the mounting hole. I will probably add a couple gussets for strength before I paint it.
    [​IMG][​IMG]
  9. Aaron D.
    Aaron D.
    A little steering wheel restoration action. Some older footage, some new footage.
    Corsa, deluxester, brEad and 3 others like this.
  10. IowaMercMan
    IowaMercMan
  11. Blues4U
    Blues4U
    from So Cal
    How did you protect the trim rings? Did you mask them off?
  12. Aaron D.
    Aaron D.
    Yep, 3M blue fine line tape.
    brEad and Blues4U like this.
  13. Glad to hear the move went smoothly. I'm amazed that you are up and running so quickly after a such a major life event. Congratulations on the retirement!!
    Brian B
  14. Aaron D.
    Aaron D.
    Thanks Walt and Brian.
    Here is how I put my steering components together. Hope it sheds some light on some of the components.
    Corsa, brEad, 48fordnut and 4 others like this.
  15. 51box
    51box
    from MA
    Nice work man, it’s cool watching you tackle all the aspects of the build
  16. Aaron D.
    Aaron D.
  17. brEad
    brEad
    Still really liking the video updates! Not knocking the rest of the build threads but the videos just provide so much detail. Thanks for taking the time to make and edit them!
  18. Aaron D.
    Aaron D.
    Thanks brEad
    Installing taillights and working on the windshield frame.
    Corsa, Blues4U, brEad and 5 others like this.
  19. 48fordnut
    48fordnut
    Awesome as always with the work Aaron.
  20. DaveyJonez
    DaveyJonez
    from Houston
    Hi Aaron: nice job! Quick question- What was the issue with the cam bearings?? Wrong bearings or issue w/ the block??
    Keep up the great work
  21. brEad
    brEad
    Like your taillights. I used the same ones on a vintage style teardrop trailer I built for my brother. You might want to paint the inside of the housing white as they aren’t real bright in the daylight sometimes. (Supposedly white is brighter than silver which is what I used.) I’m jealous of the old lens, too.
  22. Aaron D.
    Aaron D.
    Hi Davey, the machinist told me he found a burr on the rear bearing. He said he burnished the burr out. The cam turned freely when I got it back from him.
  23. Aaron D.
    Aaron D.
    Hmmm, maybe i'll do that, thanks brEad.
  24. Aaron D.
    Aaron D.
    Alright guys, getting some of the smaller but necessary things done. Next will be the engine reinstalled.
    louisb, Corsa, Mikel50 and 3 others like this.
  25. brEad
    brEad
    Another excellent update!
  26. barrnone50
    barrnone50
    from texas
    Looking good !! Tank and connections came out super clean.. Thanks for the videos great learning experience..
  27. Making progress!! Thanks for another informative video!!
    Brian B
  28. Aaron D.
    Aaron D.
    Thanks guys. Today I put the motor back in and worked on fabricating an adjustable clutch pedal return stop. Little steps forward!
    Aaron
  29. Aaron D.
    Aaron D.
    Lengthened and bent to fit the 1939 torque rods and finished up the clutch pedal return stop.[​IMG]
    brEad, Corsa and greaser like this.
  30. Aaron D.
    Aaron D.
    Got some more work done on the Coupe. Getting closer everyday!
    Blues4U, Corsa, brEad and 3 others like this.
