Hot Rods Rear end for model a
Discussion in 'The Hokey Ass Message Board' started by oldsman41, Sep 25, 2018.
  1. oldsman41
    oldsman41
    i know lots of threads on here about rears that fit a model a but i need to know what center pinion rear end will work I haven’t found info on that. 57- 58 inches wide is what i would like. Thanks guys
  2. oldsman41
    oldsman41
    Gee i thought I’d have 10 answers for this.
  3. Sorry I can't answer, but what is a "center pinion rear end"?
    Charlie Stephens
  4. Pete Eastwood
    Pete Eastwood
    from california
    '57 to '59 Ford & early Bronco . . . .
  5. flamedabone
    flamedabone
    Most fellas like the rear ends that center the 3rd member housing rather than the pinion purely from a looks perspective. Is there a reason you like the centered pinion? Just curious.
    PS, The Bronco rears Pete mentioned work nice for a coupe (coupes are skinnier than a sedan) if you can find a reasonable priced one.
    -Abone.
  6. oldsman41
    oldsman41
    Yeah building a coupe and the engine and trans are centered in the frame so a centered pinion would work out best. I know some guys run a slight offset pinion even with the trans centered but i think it puts a lot of strain on the u joints,imo. Pet yes i thought 57 59 ford had it didn’t know bronco did though, are you talking about 66-77 broncos.
  7. oldsman41
    oldsman41
    Wow thought there would be more feedback on this.
  8. Limey Kid
    Limey Kid
    If you use the '66-mid '70s bronco you also get the 5 on 5 1/2 bolt pattern so you can run early ford wire or steelies. I run one under my '33 coupe.
    Cheers,
    Stewart.
  9. Why not use a banjo rear?
    Dino 64 likes this.
  10. oldsman41
    oldsman41
    I would consider a banjo if i knew for sure it would hold up under some abuse.
  11. Dino 64
    Dino 64
    from Virginia
    Pete& Jakes sells a 9” that fit right, chunk is close to the middle, I don’t think any of them are exactly in the middle.
  12. Dino 64
    Dino 64
    from Virginia
    2270690A-DD3E-4564-BE3F-C935E358DE5C.jpeg Close to the middle, cheaper than a banjo
  13. 47ragtop
    47ragtop
    I know this is crazy, but I have a 70 thru 80 International Scout rear in my 40 Ford. 58 inches wide with 5 1/2 bolt circle and centered pinion. They are Salisbury design Dana 44's and will take some abuse. They come in ratios from 3.07 to 4.27 and the ring and pinion ,bearings etc for Dodge ,Ford and Chevy trucks will interchange. They sure don't bring the stupid Bronco rear prices either.
    Hnstray likes this.
  14. Marty Strode
    Marty Strode
    IMG_0668.JPG 8" out of 62-65 Fairlane.
    catdad49 and Hnstray like this.
  15. What engine?
    What trans?
    What time period are you trying to achieve?
    What did you have for lunch?
    Dino 64 and Chucky like this.
  16. oldsman41
    oldsman41
    Really this car is being put together with a lot of stuff i have accumulated over the years little Chevy motor auto it will look stock on the outside no chop running boards and fenders and would like to keep it 60s style. Oh I don’t eat lunch. Thanks everyone so far.
    cactus1 likes this.
  17. 31aford
    31aford
    from az
    8" from a maverick 56 1/2" wide
    36-3window likes this.
  18. Jalopy Joker
    Jalopy Joker
    check on roadkillcustoms.com for rear-end widths of classic American cars
