Hot Rods Making Gaskets?
Discussion in 'The Hokey Ass Message Board' started by HuskerNation, Sep 28, 2018.
  1. HuskerNation
    HuskerNation
    Does anyone make their own gaskets? Without an original gasket on hand how best can one determine type of gasket “material”, the “thickness” and the proper hole size one needs for the gasket?
    My last attemp at buying gaskets didn’t go very well, so I’d like to make a few gaskets myself instead. Ive already made all the gaskets needed for the valve covers on my 37 Hudson and it went well. Now I need a Water Jacket gasket with 18 bolt holes & this gets a bit more involved.
    Along these lines how does one pick the size of punch to use for the holes? If there is a 5/16” bolt going thru the gasket should the hole punch be 5/16” as well or something else in diameter? On water jacket which carries coolant to the engine block after cooled, I was thinking of using the Cork-Rubber matterial by Fel Pro in 1/16” thickness.
  2. KenC
    KenC
    I've always use a tiny hammer on the gasket material placed directly over the part itself. Like a timing cover, fuel pump etc. Tap directly on the hole and it will imprint, if not cut completely through. When the first hole is done, put a bolt or punch in it to hold the alignment. Repeat with the second hole, as far from the first as possible. The just tap away 'til they're all done.
    this only works with thinner paper gaskets of course. With cork, you're on your own!
    Ned Ludd, clem, loudbang and 4 others like this.
  3. My Dad and I make our own gaskets all the time. I even make some for weird **** at work. We use the same size punch for the bolts we are using, 5/16 bolts, 5/16 punch. I have been a truck mechanic for 25 years and we try to match the thickness of the gasket material to other like items that I have seen at work, ie, a stamped tin cover that has oil inside would get cork rubber material around 1/8” thick, like a pre made oil pan gasket. On your water jacket, I would use a Fel Pro product call Karopack, it’s a brown gasket paper, in different thicknesses. I would go with 1/16”.
    brad2v and Atwater Mike like this.
  4. F&J
    F&J
    The holes are normally just very slightly larger that bolt size....but do whatever works for you.
    another thing is that the jacket, if it is stamped sheetmetal, could have been overtightened too many times during 80 years, so 1/16" might be too thin, ( if you can't get the jacket to lay flat without a gasket, to see if you have gaps between the bolts. )
    also, some cars used very soft copper washers on those bolts.
    Hnstray likes this.
  5. lake_harley
    lake_harley
    I do like KenC....tiny hammer, lots of patience. As far as material, more often than not it's a Cheerios box.
    Lynn
  6. woodiewagon46
    woodiewagon46
    from New York
    McMaster-Carr has a wide variety of gasket materials and punches. You can also make gasket punches from tubing or pipe with a sharpened edge.
  7. Atwater Mike
    Atwater Mike
    My wife makes most gaskets for me, I still have a large collection of gasket paper I bought 30 years ago from MOTOR SUPPLY in Los Gatos, CA.
    I have a set of punches (like socket heads) that plug onto a handle that's 6" long, 7/8" diameter hex, with a round shaft sticking out on the 'socket end', a black 'O' ring to hold the punch sockets on.
    It sits in a cut out section of white cardboard (!) with no name...
    I think any tool truck vendor would have a similar set...
    Wife Joey used this for 1/4"-3/4" holes, any smaller get punched with her wheeled leather punch.
    She sometimes uses the old ball-pein hammer as mentioned above, and I bought her a set of Medical scalpel tools, with 4 different blade sets. (blades came in boxes of 100, surprisingly cheap: Amazon.com. Look up surgical knives...)
    Joey's gaskets look as nice as Fel-Pro. She just doesn't paint 'em blue.
    brad2v likes this.
  8. tubman
    tubman
    I make a lot of my own gaskets. After a while, you can pretty much determine what material and thickness you need. Sometimes using a small hammer to mark the bolt holes doesn't produce a nice clean cut. In cases like this, a set of hollow punches are invaluable. They're pretty cheap, so everyone should have a set. A funny thing; my first set was from Harbor Freight. After a few years, they got dull and didn't work as well. Since I really liked how the worked, I went out and replaced them with an expensive American made set.. They really disappointed me, and I am now back to using the Harbor Freight set, which can be easily sharpened on a bench grinder.
    bedwards and Atwater Mike like this.
  9. BamaMav
    BamaMav
    from Berry, AL
    I made some punches out of some old Chinese 1/4" deep well sockets. Put an edge on them with the grinder, they cut fine.
    What I do if I can is lay the part down on the gasket material and trace around it and in every hole I color them solid. Of course some thinks like carb upper bodies you can't do that until you cut out the center a little bit for any protrusions like the float hanger.
    Hnstray and Atwater Mike like this.
  10. In the old days, telephone book covers were the correct material to use.
    bobss396 likes this.
  11. Binger
    Binger
    from wyoming
    I have used many of the techniques listed above. The hollow punches are the best. A few years ago I was working on a motor cycle and I scanned the side covers and ran the thin gasket material through my printer. Then just cut them out. Only limitation is the size of your printer and scanner.
    Jet96, Atwater Mike, kbgreen and 2 others like this.
  12. flatheadgary
    flatheadgary
    from boron,ca
    this may seem like a dumb question but what do you hammer the hollow punches on. steel or wood or some thing else?
  13. tubman
    tubman
    I have a foot long piece of 2 X 6 regular old wood. I have to replace it after it gets used to much.
    Atwater Mike likes this.
  14. Boneyard51
    Boneyard51
    I first glue the gasket to the part, with various adhesives. Then take the small hammer and tap out the gasket. Then add a thin coat of silicone sealer... wala.... perfect gasket and a no leak seal. Just the way I do it.
    Bones
  15. Kerrynzl
    Kerrynzl
    Do it the easy way! [from a tube:D]
    Jet96, bobss396, Johnny Gee and 4 others like this.
  16. jchev1953
    jchev1953
    I make gaskets as well and use empty shell casings to cut out the bolt holes. Different calibers for different sizes. They make nice free punches and I can usually pick up replacements from my friends who shoot at the range regularly.
  17. Terrible80
    Terrible80
    Same as everyone said: I use cheap hole punches, they last a long time if you punch into the end grain of a pine block. I use manilla folder, shoebox cardboard. At work for packagi g they have some 24 x 24 chipboard sheets which work great. " Real " gasket material as needed.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
    Atwater Mike and tb33anda3rd like this.
  18. Doc.
    Doc.
    I make my own gaskets for lots of things. If the part is not too big, I like to put it on the copy machine and press copy. It makes a perfect full size template which I then transfer over to the gasket material. I also use different size hole punches to make perfect holes. Works great.
    Atwater Mike and pitman like this.
  19. carbking
    carbking
    The offshore punches work, for a while.
    An "arch-punch" set, if you punch LOTS of gaskets, as they are expensive. They are also available in sizes not available in the offshore stuff.
    A good ball-peen hammer if you use the "hammer method".
    Your wife's (or significant other's) fingernail scissors for cutting curves.
    The copy machine method mentioned by Doc in the post above. If you have a laser printer, and flatten the gasket sheets, you can print the form directly on the gasket, and then cut it out.
    Unless there is a reason for using thicker gaskets, the thinnest gasket will do the best job. Some jobs require a gasket that will "crush", requiring a thicker gasket or a different material.
    We use mostly Armstrong N-8090 gasket material (1/32, 1/16, 1/8). Totally impervious to gasoline, oil, deathanol, and many acids.
    Fiberboard makes a good base to use for cutting the gaskets. Common brand name Masonite.
    Jon.
  20. blowby
    blowby
    from Nicasio Ca
    I've gotten pretty good with the hollow punches but getting them lined up with the center mark of the hole can be tricky, especially on a small gasket with little margin. Any tricks?
  21. bct
    bct
  22. kbgreen
    kbgreen
    My dad taught me to put a thin coat of oil on the part where the gasket is used, then press the oiled part onto the gasket material. From there it's a matter of cutting and punching. This works well for carburetors, but I trace larger parts like stamped steel valve covers and timing chain covers.
    Hnstray, tractorguy, Truck64 and 2 others like this.
  23. adam401
    adam401
    I was just gonna post the oil outline technique but you beat me too it. Learned that one from my Dad as well
    kbgreen likes this.
  24. woodiewagon46
    woodiewagon46
    from New York
    Believe it or not I use a 1/4" sheet of lead as a backer when I punch out gasket holes. The punch can drive thru the gasket material and into the lead. It makes a clean cut every time and it's a lot easier on my punches.
  25. Mr48chev
    I've got a little ball peen hammer that I bought at a yard sale or estate sale that works perfect for the lay it on and tap it. I've had a small set of gasket punches for years that I bought off a tool peddler who came around to the shops I worked at but have a large set I picked up off Ebay in the other tool box.
    Just an old piece of 2x8 for the backer for the punch.
    pitman likes this.
  26. pitman
    pitman
    Often a thin steel (say valve) cover flange may need flattening, before reuse. On a steel surface, turn your SBC valve cover over, and tap the bolt holes flat w/the right dia. hammer.
  27. HuskerNation
    HuskerNation
    WOW, great information guys! I have a set of Lang Punches arriving today which will be put to work shortly thereafter.
    The use of a copier is brilliant & in definitely giving that a try this morning. While I’ve used the oil trick before & its worked great, I worried about using it with my steel water jacket application which has coolant flowing & potential for leaking. Is that a valid concern?
  28. HuskerNation
    HuskerNation
    This is great![​IMG]
    Truck64 likes this.
  29. HuskerNation
    HuskerNation
    Looks like 30.06 shells work quite well for 5/16” bolts!
    Jet96, Hnstray, pitman and 1 other person like this.
  30. 31Dodger
    31Dodger
    I make my gaskets two ways. One is with the small, ball peen hammer and two is if I have the old gasket, I lay it down on the new material and give it a quick spray of black paint....instant pattern.
    Hnstray, clem and kbgreen like this.
